| Problem deploying Apache CXF Webservice on Virgo: Cannot resolve XML Schema [message #1048415] |
Wed, 24 April 2013 08:41  |
Hello everyone.
I have created this topic because I am in quite some predicament here and I hope, that one of you is able to help me get out of it.
The problem is the following:
I am working in an OSGi-Environment with an Eclipse Virgo (Version 3.6) as the OSGi-Application Server.
The build is done using Maven Tycho to create and bundle the jars.
So far deploying and using the bundles worked quite well.
For a new feature in the application I need to specify and automatically deploy a JAX-WS Webservice on Virgo startup.
The Webservice-Content is deployed as a bundle as well.
Now, due to various reasons, it was decided to use the Apache CXF-Framework to specify the Webservice in a Contract-first approach.
If I now try to recreate one of the CXF-Samples (for example the Hello World) as a local Webservice without deploying it on Virgo everything works fine.
The problem occurs as soon as I try to change the local Webservice into a bundle and try to deploy it on my Virgo.
For this I create the necessary web.xml as well as the context.xml files, to specify the Endpoint-Implementation automatically, according to one of the CXF samples.
I placed all CXF-bundles in Virgos repository and specified the new repository in its configuration-file so that Virgo is able to find them.
In my webservice-bundle manifest I declare the required CXF-bundles so they will get started.
My manifest looks like this:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Version: 1.0.0.qualifier
Bundle-Name: CXFTest
Bundle-SymbolicName: CXFTest
Require-Bundle: org.apache.cxf.cxf-rt-frontend-jaxws;bundle-version="2.7.3",
org.apache.cxf.cxf-api;bundle-version="2.7.3",
org.apache.cxf.xjc-utils.cxf-xjc-runtime;bundle-version="2.6.1",
org.apache.cxf.cxf-rt-core;bundle-version="2.7.3"
Web-ContextPath: /cxf
Import-Package: javax.servlet;version="[2.4,4)",
javax.servlet.http;version="[2.4,4)",
org.apache.shiro.web.env;version="[1.2.1,2.0.0)"
Bundle-RequiredExecutionEnvironment: JavaSE-1.7
I am able to add the generated WAR to my Virgo and publish it.
If I then try to start the Virgo it will startup normally until it tries to start my web-bundle.
As soon as it tries to start it, I will get the following error message:
[2013-04-24 11:54:56.823] region-dm-6 <AG0000E> Application context creation failure for bundle 'org.apache.cxf.cxf-rt-transports-http' version '2.7.3'. org.springframework.beans.factory.xml.XmlBeanDefinitionStoreException: Line 27 in XML document from OSGi resource[bundleentry://168.fwk13933553/OSGI-INF/blueprint/osgiservlet.xml|bnd.id=168|bnd.sym=org.apache.cxf.cxf-rt-transports-http] is invalid; nested exception is org.xml.sax.SAXParseException; lineNumber: 27; columnNumber: 87; cvc-complex-type.2.4.c: The matching wildcard is strict, but no declaration can be found for element 'cm:property-placeholder'.
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:396)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:334)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:302)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:174)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:209)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:180)
at org.eclipse.gemini.blueprint.context.support.OsgiBundleXmlApplicationContext.loadBeanDefinitions(OsgiBundleXmlApplicationContext.java:170)
at org.eclipse.gemini.blueprint.context.support.OsgiBundleXmlApplicationContext.loadBeanDefinitions(OsgiBundleXmlApplicationContext.java:140)
at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:131)
at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:527)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$800(AbstractDelegatedExecutionApplicationContext.java:60)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$3.run(AbstractDelegatedExecutionApplicationContext.java:242)
at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.startRefresh(AbstractDelegatedExecutionApplicationContext.java:220)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.stageOne(DependencyWaiterApplicationContextExecutor.java:224)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.refresh(DependencyWaiterApplicationContextExecutor.java:177)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.refresh(AbstractDelegatedExecutionApplicationContext.java:157)
at org.eclipse.gemini.blueprint.extender.internal.activator.LifecycleManager$1.run(LifecycleManager.java:211)
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:722)
Caused by: org.xml.sax.SAXParseException: cvc-complex-type.2.4.c: The matching wildcard is strict, but no declaration can be found for element 'cm:property-placeholder'.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:198)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.error(ErrorHandlerWrapper.java:134)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:437)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:368)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:325)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator$XSIErrorReporter.reportError(XMLSchemaValidator.java:453)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.reportSchemaError(XMLSchemaValidator.java:3232)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.handleStartElement(XMLSchemaValidator.java:1912)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.startElement(XMLSchemaValidator.java:741)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(XMLNSDocumentScannerImpl.java:376)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2717)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:607)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:116)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:489)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:835)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:764)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:123)
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:237)
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:300)
at org.springframework.beans.factory.xml.DefaultDocumentLoader.loadDocument(DefaultDocumentLoader.java:75)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:388)
... 21 common frames omitted
And somewhat later the following error:
[2013-04-24 14:11:32.839] start-signalling-1 <DE0006E> Start failed for bundle 'CXFTest' version '1.0.0.qualifier'. org.eclipse.virgo.nano.deployer.api.core.DeploymentException: Web application failed to start
at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:132)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardArtifactStateMonitor.onStarted(StandardArtifactStateMonitor.java:271)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.java:319)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.access$0(AbstractInstallArtifact.java:316)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal.signalSuccessfulCompletion(AbstractInstallArtifact.java:252)
at org.eclipse.virgo.nano.core.internal.BundleStartTracker$1.run(BundleStartTracker.java:140)
Caused by: org.eclipse.gemini.web.core.WebApplicationStartFailedException: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/cxf' failed to start. Check the logs for more details.
at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:137)
at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:122)
... 8 common frames omitted
Caused by: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/cxf' failed to start. Check the logs for more details.
at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.startWebApplication(TomcatServletContainer.java:133)
at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:109)
... 9 common frames omitted
(I think this error can be ignored because it happens due to the missing dependencies from the first one?)
The faulty XML file (according to the error) can be found in the cxf-rt-transports-http-2.7.3.jar and looks like this:
Licensed to the Apache Software Foundation (ASF) under one
or more contributor license agreements. See the NOTICE file
distributed with this work for additional information
regarding copyright ownership. The ASF licenses this file
to you under the Apache License, Version 2.0 (the
"License"); you may not use this file except in compliance
with the License. You may obtain a copy of the License at
h++p://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing,
software distributed under the License is distributed on an
"AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY
KIND, either express or implied. See the License for the
specific language governing permissions and limitations
under the License.
<blueprint xmlns="h++p://www.osgi.org/xmlns/blueprint/v1.0.0"
xmlns:xsi="h++p://www.w3.org/2001/XMLSchema-instance"
xmlns:cm="h++p://aries.apache.org/blueprint/xmlns/blueprint-cm/v1.0.0"
xsi:schemaLocation="
h++p://www.osgi.org/xmlns/blueprint/v1.0.0 h++p://www.osgi.org/xmlns/blueprint/v1.0.0/blueprint.xsd">
<cm:property-placeholder persistent-id="org.apache.cxf.osgi" id="cxfOsgiProperties">
<cm:default-properties>
<cm:property name="org.apache.cxf.servlet.context" value="/cxf"/>
<cm:property name="org.apache.cxf.servlet.name" value="cxf-osgi-transport-servlet"/>
<cm:property name="org.apache.cxf.servlet.hide-service-list-page" value="false"/>
<cm:property name="org.apache.cxf.servlet.disable-address-updates" value="false"/>
<cm:property name="org.apache.cxf.servlet.base-address" value=""/>
<cm:property name="org.apache.cxf.servlet.service-list-path" value=""/>
<cm:property name="org.apache.cxf.servlet.static-resources-list" value=""/>
<cm:property name="org.apache.cxf.servlet.redirects-list" value=""/>
<cm:property name="org.apache.cxf.servlet.redirect-servlet-name" value=""/>
<cm:property name="org.apache.cxf.servlet.redirect-servlet-path" value=""/>
<cm:property name="org.apache.cxf.servlet.service-list-all-contexts" value=""/>
</cm:default-properties>
</cm:property-placeholder>
<bean id="destinationRegistry" class="org.apache.cxf.transport.http.DestinationRegistryImpl"/>
<bean id="osgiServlet" class="org.apache.cxf.transport.servlet.CXFNonSpringServlet">
<argument ref="destinationRegistry"/>
<argument value="false"/>
</bean>
<service ref="osgiServlet" interface="javax.servlet.Servlet">
<service-properties>
<entry key="alias" value="${org.apache.cxf.servlet.context}"/>
<entry key="servlet-name" value="${org.apache.cxf.servlet.name}"/>
<entry key="hide-service-list-page" value="${org.apache.cxf.servlet.hide-service-list-page}"/>
<entry key="disable-address-updates" value="${org.apache.cxf.servlet.disable-address-updates}"/>
<entry key="base-address" value="${org.apache.cxf.servlet.base-address}"/>
<entry key="service-list-path" value="${org.apache.cxf.servlet.service-list-path}"/>
<entry key="static-resources-list" value="${org.apache.cxf.servlet.static-resources-list}"/>
<entry key="redirects-list" value="${org.apache.cxf.servlet.redirects-list}"/>
<entry key="redirect-servlet-name" value="${org.apache.cxf.servlet.redirect-servlet-name}"/>
<entry key="redirect-servlet-path" value="${org.apache.cxf.servlet.redirect-servlet-path}"/>
<entry key="service-list-all-contexts" value="${org.apache.cxf.servlet.service-list-all-contexts}"/>
</service-properties>
</service>
<service ref="destinationRegistry" interface="org.apache.cxf.transport.http.DestinationRegistry">
</service>
</blueprint>
I did not make any changes to this file or the bundle itself.
The xml looks fine to me and I can't see any errors with the Schema definition.
The import of the Apache Camel Schema (xmlns:cm="h++p://aries.apache.org/blueprint/xmlns/blueprint-cm/v1.0.0") is used throughout multiple CXF-bundles and every other bundle seems to work.
While the problem may look like an Apache CXF problem I am quite irritated by the fact, that no one elses seems to have the same problem.
This is why I'm assuming, that this is a problem due to the combination of Apache CXF with Eclipse Virgo.
I have attached a Zip containing the example project I used as well as the complete Virgo log.
I have invested quite some time trying to find a solution for the problem but was unable to solve it.
So I hope someone of you could help me find a solution.
Many thanks.
Kind regards,
Manuel Loth
Attachment: CXF.zip
(Size: 53.85KB, Downloaded 321 times)
| Re: Problem deploying Apache CXF Webservice on Virgo: Cannot resolve XML Schema [message #1057755 is a reply to message #1053310] |
Wed, 08 May 2013 11:12  |
Manuel,
I have an update. I upgraded to CXF-DOSGI 1.4. I added the following Aries Blueprint files to my usr directory:
- org.apache.aries.blueprint-0.3.2
- org.apache.aries.util_3.0.1
- org.apache.aries.proxy-0.3.1
These bundles are included with the CXF 1.4 download.Since I am using REST and jax-rs my bundle needs are a little different than yours, but I am sure there are corresponding bundles ( if not just version updates ) for yours. I then added any needed dependencies, also included in CXF-DOSGI 1.4 download, to the usr directory as well.
The NameSpaceService that aries exposes is picked up by CXF and the new schemas validate fine. I no longer get that SAX exception you were getting. It may be a good exercise for you to upgrade and see if it helps your situation at all.
Neil
[Updated on: Thu, 09 May 2013 08:52] by Moderator
FUDForum. Page generated in 0.03432 seconds
