Home » Eclipse Projects » Virgo » java.lang.NoClassDefFoundError: org/codehaus/jackson/map/ObjectMapper
java.lang.NoClassDefFoundError: org/codehaus/jackson/map/ObjectMapper [message #1048350] |
Wed, 24 April 2013 10:44 |
Pedro Mendoza Messages: 5 Registered: April 2013 |
While trying to deploy a Spring MVC web app into Virgo I am getting the following exception that seems to be Jackson related, I have seen some older threads describing a similar issues due to version missmatch between the available Jackson bundles and the Spring Web bundles but it does not seems to be the case for me (see versions below)
I am using ...
OSGi Runtime: Apache Tomcat/7.0.35 on Eclipse Virgo 3.6.1.RELEASE
Virtual Machine: 1.6.0_29 - Java HotSpot(TM) 64-Bit Server VM 20.4-b02 (Sun Microsystems Inc.)
Operating System: Windows 7 6.1 (amd64)
I have downloaded (from SpringSource EBR) and successfully installed using Virgo Console Deployer the com.springsource.org.codehaus.jackson bundles (core and mapper) v1.4.3
Any ideas?
Thanks in advance!,
Pedro
log file:
[2013-04-24 12:18:37.117] ERROR start-signalling-9 org.springframework.web.context.ContextLoader Context initialization failed org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.web.servlet.view.ContentNegotiatingViewResolver#0' defined in ServletContext resource [/WEB-INF/spring-servlet.xml]: Cannot create inner bean 'org.springframework.web.servlet.view.json.MappingJacksonJsonView#5d5dbc89' of type [org.springframework.web.servlet.view.json.MappingJacksonJsonView] while setting bean property 'defaultViews' with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.web.servlet.view.json.MappingJacksonJsonView#5d5dbc89' defined in ServletContext resource [/WEB-INF/spring-servlet.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.springframework.web.servlet.view.json.MappingJacksonJsonView]: Constructor threw exception; nested exception is java.lang.NoClassDefFoundError: org/codehaus/jackson/map/ObjectMapper
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:281)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:120)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedList(BeanDefinitionValueResolver.java:353)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:153)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1360)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1118)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:384)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:283)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4797)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5291)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:633)
at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.startWebApplication(TomcatServletContainer.java:125)
at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:109)
at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:122)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardArtifactStateMonitor.onStarted(StandardArtifactStateMonitor.java:271)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.java:319)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.access$0(AbstractInstallArtifact.java:316)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal.signalSuccessfulCompletion(AbstractInstallArtifact.java:252)
at org.eclipse.virgo.nano.core.internal.BundleStartTracker$1.run(BundleStartTracker.java:140)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.web.servlet.view.json.MappingJacksonJsonView#5d5dbc89' defined in ServletContext resource [/WEB-INF/spring-servlet.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.springframework.web.servlet.view.json.MappingJacksonJsonView]: Constructor threw exception; nested exception is java.lang.NoClassDefFoundError: org/codehaus/jackson/map/ObjectMapper
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:997)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:943)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:270)
... 34 common frames omitted
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.springframework.web.servlet.view.json.MappingJacksonJsonView]: Constructor threw exception; nested exception is java.lang.NoClassDefFoundError: org/codehaus/jackson/map/ObjectMapper
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:162)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:76)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:990)
... 38 common frames omitted
Caused by: java.lang.NoClassDefFoundError: org/codehaus/jackson/map/ObjectMapper
at org.springframework.web.servlet.view.json.MappingJacksonJsonView.<init>(MappingJacksonJsonView.java:59)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:147)
... 40 common frames omitted
manifest.mf:
Manifest-Version: 1.0
Export-Package: com.pbs.gmap.authentication;uses:="
org.springframework.beans.factory.annotation
,org.springframework.security.access.expression
,org.springframework.security.authentication
,org.springframework.security.core
,org.springframework.security.web
,org.springframework.security.web.access.expression"
,com.pbs.gmap.controller;uses:="
com.google.gson
,com.pbs.gmap.pojo
,com.pbs.gmap.util
,javax.servlet.http
,org.springframework.beans.factory.annotation
,org.springframework.stereotype
,org.springframework.ui
,org.springframework.validation
,org.springframework.web.bind.annotation
,org.springframework.web.client,org.springframework.web.servlet"
,com.pbs.gmap.pojo;uses:="
javax.persistence"
,com.pbs.gmap.service;uses:="
com.pbs.gmap.pojo"
,com.pbs.gmap.util;uses:="
com.pbs.gmap.pojo
,org.springframework.beans.factory.config
,org.springframework.stereotype"
Tool: Bundlor 1.1.2.RELEASE
Import-Package: com.google.gson
,javax.persistence
,javax.servlet,javax.servlet.http
,org.apache.commons.logging
,org.apache.log4j
,org.springframework.security.core.authority
,org.springframework.security.core.context
,org.springframework.security.config
,org.springframework.security.web.authentication
,org.codehaus.jackson.map
Import-Library: org.springframework.spring;version="[3.0.0,3.2.0)"
Bundle-SymbolicName: com.pbs.telenor.adminwebapp
Bundle-Version: 1.0.0
Bundle-Name: AdminWebApp
Bundle-Classpath: .,WEB-INF/classes
Web-ContextPath: AdminServices
web.xml:
<web-app ...>
<display-name>PB Maps</display-name>
<welcome-file-list>
<welcome-file>index.jsp</welcome-file>
</welcome-file-list>
<servlet>
<servlet-name>spring</servlet-name>
<servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>*.html</url-pattern>
</servlet-mapping>
<!-- <context-param> <param-name>contextConfigLocation</param-name> <param-value>
/WEB-INF/spring-servlet.xml </param-value> </context-param> <listener> <listener-class>
org.springframework.web.context.ContextLoaderListener </listener-class> </listener> -->
<context-param>
<param-name>log4jConfigLocation</param-name>
<param-value>classpath:log4j.properties</param-value>
</context-param>
<listener>
<listener-class>org.springframework.web.util.Log4jConfigListener</listener-class>
</listener>
<context-param>
<param-name>contextClass</param-name>
<param-value>org.eclipse.virgo.web.dm.ServerOsgiBundleXmlWebApplicationContext</param-value>
</context-param>
<context-param>
<param-value>
/WEB-INF/spring-servlet.xml,
/WEB-INF/spring-security.xml
</param-value>
</context-param>
<listener>
<listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
</listener>
<!-- Spring Security -->
<filter>
<filter-name>springSecurityFilterChain</filter-name>
<filter-class>org.springframework.web.filter.DelegatingFilterProxy</filter-class>
</filter>
<filter-mapping>
<url-pattern>/*</url-pattern>
</filter-mapping>
<!-- <servlet> <servlet-name>jersey-serlvet</servlet-name> <servlet-class>com.sun.jersey.spi.container.servlet.ServletContainer</servlet-class>
<init-param> <param-name>com.sun.jersey.config.property.packages</param-name>
<param-value>com.mkyong.rest</param-value> </init-param> <init-param> <param-name>com.sun.jersey.api.json.POJOMappingFeature</param-name>
<param-value>true</param-value> </init-param> <load-on-startup>1</load-on-startup>
</servlet> <servlet-mapping> <servlet-name>jersey-serlvet</servlet-name>
<url-pattern>/rest/*</url-pattern> </servlet-mapping> -->
<session-config>
<session-timeout>15</session-timeout>
</session-config>
</web-app>
mvc spring context:
<beans ...>
<!-- Auto scan the components -->
<bean id="applicationURL" class="com.pbs.gmap.util.ServicesURLProvider">
<constructor-arg
value="${application.url}:${application.port}/${application.deployedApplicationName}" />
</bean>
<bean id="restTemplate" class="org.springframework.web.client.RestTemplate" />
<bean id="gson" class="com.google.gson.Gson" ></bean>
<mvc:annotation-driven />
<context:annotation-config />
<aop:aspectj-autoproxy />
<context:component-scan base-package="com.pbs.gmap" />
<bean
class="org.springframework.web.servlet.view.ContentNegotiatingViewResolver">
<property name="mediaTypes">
<map>
<entry key="html" value="text/html" />
<entry key="json" value="application/json" />
</map>
</property>
<property name="viewResolvers">
<list>
<bean class="org.springframework.web.servlet.view.UrlBasedViewResolver">
<property name="viewClass"
value="org.springframework.web.servlet.view.JstlView" />
<property name="prefix" value="/WEB-INF/jsp/" />
<property name="suffix" value=".jsp" />
</bean>
</list>
</property>
<property name="defaultViews">
<list>
<bean
class="org.springframework.web.servlet.view.json.MappingJacksonJsonView">
<property name="prefixJson" value="true" />
</bean>
</list>
</property>
</bean>
<bean id="propertyConfigurer" class="com.pbs.gmap.util.PropertyConfigurer">
<property name="locations">
<list>
<value>classpath:environment.properties</value>
<value>classpath:configuration.properties</value>
</list>
</property>
</bean>
</beans>
Re: java.lang.NoClassDefFoundError: org/codehaus/jackson/map/ObjectMapper [message #1058713 is a reply to message #1058250] |
Tue, 14 May 2013 18:28 |
Hi Glyn,
Thank you for the pointer, really useful tools
I have been trying to reproduce/test the issue (producing JSON content using a Spring MVC app) in a simpler (trivial) app and I am still getting a NoClassDefFoundError for one of the Jackson classes
The first error in the log says ...
[2013-05-14 19:08:37.834] ERROR start-signalling-4 org.springframework.web.servlet.DispatcherServlet Context initialization failed org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'messageAdapter' defined in ServletContext resource [/WEB-INF/spring/appServlet/servlet-context.xml]: Cannot create inner bean 'util:list#322885a2' of type [org.springframework.beans.factory.config.ListFactoryBean] while setting bean property 'messageConverters'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'util:list#322885a2': Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/codehaus/jackson/JsonProcessingException
So I tried following Hristos' suggestion and everything seems to be okay in terms of class (org.codehaus.jackson.JsonProcessingException) being exposed and reachable from consumer bundle (com.pbs.telenor.springmvc1), see Virgo console results below ...
export
osgi> clexport org.codehaus.jackson.JsonProcessingException
Bundles exporting [org.codehaus.jackson.JsonProcessingException]:
156 com.springsource.org.codehaus.jackson
load test
osgi> clload org.codehaus.jackson.JsonProcessingException 158
Successfully loaded [org.codehaus.jackson.JsonProcessingException] using class l
oader from:
158 com.pbs.telenor.springmvc1
[provided by 156 com.springsource.org.codehaus.jackson]
package export/import
osgi> vsh:packages examine org.codehaus.jackson 1.4.3
Exporter: com.springsource.org.codehaus.jackson 1.4.3 [156]
Attributes:
None
Directives:
uses:
org.codehaus.jackson.annotate, org.codehaus.jackson.io,
org.codehaus.jackson.type, org.codehaus.jackson.util
x-equinox-ee:
-1
x-internal:
false
Importer(s):
com.springsource.org.codehaus.jackson.mapper 1.4.3 [157]
Import-Package attributes:
bundle-version:
0.0.0
version:
[1.4.3,1.4.3]
Import-Package directives:
resolution:
static
com.pbs.telenor.springmvc1 1.0.0 [158]
bundle-version:
0.0.0
version:
0.0.0
resolution:
static
The "trivial" Spring MVC manifest looks like ...
Export-Package: com.pbs.telenor.springmvc1;uses:="org.springframework.stereotype,
org.springframework.ui,org.springframework.web.bind.annotation"
Import-Package: com.pbs.telenor.nameprovider
,org.apache.log4j
,org.slf4j
,org.apache.taglibs.standard.tlv
,org.apache.taglibs.standard.tei
,org.eclipse.virgo.web.dm
Bundle-SymbolicName: com.pbs.telenor.springmvc1
Bundle-Name: springmvc1
Web-ContextPath: springmvc1
And the Spring MVC context file is as follows ...
<beans:beans xmlns=...>
<!-- DispatcherServlet Context: defines this servlet's request-processing infrastructure -->
<!-- Enables the Spring MVC @Controller programming model -->
<annotation-driven />
<!-- Handles HTTP GET requests for /resources/** by efficiently serving up static resources in the ${webappRoot}/resources directory -->
<resources mapping="/resources/**" location="/resources/" />
<!-- Resolves views selected for rendering by @Controllers to .jsp resources in the /WEB-INF/views directory -->
<beans:bean class="org.springframework.web.servlet.view.InternalResourceViewResolver">
<beans:property name="prefix" value="/WEB-INF/views/" />
<beans:property name="suffix" value=".jsp" />
</beans:bean>
<context:component-scan base-package="com.pbs.telenor.springmvc1" />
<beans:bean id="messageAdapter" class="org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter">
<beans:property name="messageConverters">
<util:list>
<!-- Support JSON -->
<beans:bean class="org.springframework.http.converter.json.MappingJacksonHttpMessageConverter"/>
</util:list>
</beans:property>
</beans:bean>
</beans:beans>
I continue to try to dig out but if you have any other clue, will be much appreciated
Thanks!,
Pedro
Current Time: Wed Sep 25 17:49:19 GMT 2024
Powered by FUDForum. Page generated in 0.04506 seconds
