Re: Artifact type exists but can't create instance [message #574394 is a reply to message #16177] |
Fri, 17 July 2009 02:22 |
Ryan D. Brooks Messages: 100 Registered: July 2009 |
Mark,
Currently, when importing type data, it is necessary to import a directory
containing all the spreadsheets with relevant type data. For example,
since the Default Hierarchical relationship is defined in
/org.eclipse.osee.framework.skynet.core/support/OseeTypes_Pr ogramAndCommon.xml
you need that spreadsheet to be read as part of the import along your your
custom type definitions in order for the inheritance to work. This is
because the inheritance is at import time only. There are plans to
support true type inheritance in the database schema in the future.
Ryan
Ryan Brooks
FUDForum. Page generated in 0.04623 seconds
