Home » Eclipse Projects » EclipseLink » Eclipselink not reconnecting to database, after database-server downtime(INFO: Communication failure detected when attempting to perform read query outside of a transaction. Attempting to retry query.)
Eclipselink not reconnecting to database, after database-server downtime [message #1046711] |
Mon, 22 April 2013 09:04 |
Reiner Lott Messages: 7 Registered: April 2013 |
Hello all !
It's my goal, to achieve a jpa provider change in our development team...
We're actually using openjpa with dbcp, but eclipselink seems more mainstream and performs even better in a j2se application (lazy loading with exclusive read connection is really a neat feature)
But there is a big problem:
If the db-server has shutdown (at night) and a java se client has not closed his program, eclipe link does not reconnect itself to our db2 server.
I tried to find something about this behaviour (not recconecting to database) in google, but there are only poor postings with no solutions in the www.
Also using the customizer (session) with optional parameter settings "connectionPool.setCheckConnections();" did not help (see attached files).
Dear EclipseLink Team: Is this a bug? OpenJpa with dbcp does a reconnect to our db (validationQuery=SELECT 1 FROM TEST, TestOnBorrow=true, removeAbandoned=true)!
@EveryoneElse: Similar problems? What would be the solution?
-EclipseLink - 2.1.0.v20100614-r7608
Thanks a lot!
-Reiner
[EL Fine]: 2013-04-22 10:55:23.095--Connection(8713574)--SELECT NEUBAU, MANDANT, BEZEICHNUNG, ATTRIBUT2, ATTRIBUT1, LASTUPDATE FROM Y_TEST WHERE ((NEUBAU = ?) AND (MANDANT = ?))
bind => [638, 100]
[EL Fine]: 2013-04-22 10:55:23.095--SELECT 1 FROM TEST
[EL Info]: 2013-04-22 10:55:23.095--Communication failure detected when attempting to perform read query outside of a transaction. Attempting to retry query.
bind => [638, 100]
[EL Fine]: 2013-04-22 10:55:28.123--Connection(8713574)--SELECT NEUBAU, MANDANT, BEZEICHNUNG, ATTRIBUT2, ATTRIBUT1, LASTUPDATE FROM Y_TEST WHERE ((NEUBAU = ?) AND (MANDANT = ?))
bind => [638, 100]
[EL Fine]: 2013-04-22 10:55:28.123--SELECT 1 FROM TEST
[EL Info]: 2013-04-22 10:55:28.123--Communication failure detected when attempting to perform read query outside of a transaction. Attempting to retry query.
[EL Fine]: 2013-04-22 10:55:33.119--Connection(8713574)--SELECT NEUBAU, MANDANT, BEZEICHNUNG, ATTRIBUT2, ATTRIBUT1, LASTUPDATE FROM Y_TEST WHERE ((NEUBAU = ?) AND (MANDANT = ?))
bind => [638, 100]
[EL Fine]: 2013-04-22 10:55:33.119--SELECT 1 FROM TEST
[EL Info]: 2013-04-22 10:55:33.119--Communication failure detected when attempting to perform read query outside of a transaction. Attempting to retry query.
[EL Fine]: 2013-04-22 10:55:38.131--Connection(8713574)--SELECT NEUBAU, MANDANT, BEZEICHNUNG, ATTRIBUT2, ATTRIBUT1, LASTUPDATE FROM Y_TEST WHERE ((NEUBAU = ?) AND (MANDANT = ?))
bind => [638, 100]
[EL Fine]: 2013-04-22 10:55:38.131--SELECT 1 FROM TEST
[EL Info]: 2013-04-22 10:55:38.131--Communication failure detected when attempting to perform read query outside of a transaction. Attempting to retry query.
[EL Warning]: 2013-04-22 10:55:38.131--Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.1.0.v20100614-r7608): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: The connection does not exist.
Error Code: -99999
Call: SELECT NEUBAU, MANDANT, BEZEICHNUNG, ATTRIBUT2, ATTRIBUT1, LASTUPDATE FROM Y_TEST WHERE ((NEUBAU = ?) AND (MANDANT = ?))
bind => [638, 100]
Query: ReadObjectQuery(referenceClass=Z_Test sql="SELECT NEUBAU, MANDANT, BEZEICHNUNG, ATTRIBUT2, ATTRIBUT1, LASTUPDATE FROM Y_TEST WHERE ((NEUBAU = ?) AND (MANDANT = ?))")
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:333)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.processExceptionForCommError(DatabaseAccessor.java:1419)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:675)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:526)
at org.eclipse.persistence.sessions.server.ServerSession.executeCall(ServerSession.java:529)
at org.eclipse.persistence.internal.sessions.IsolatedClientSession.executeCall(IsolatedClientSession.java:133)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:206)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:192)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectOneRow(DatasourceCallQueryMechanism.java:664)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRowFromTable(ExpressionQueryMechanism.java:2582)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRow(ExpressionQueryMechanism.java:2553)
at org.eclipse.persistence.queries.ReadObjectQuery.executeObjectLevelReadQuery(ReadObjectQuery.java:439)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1074)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:736)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1034)
at org.eclipse.persistence.queries.ReadObjectQuery.execute(ReadObjectQuery.java:407)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1112)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2909)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1291)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1364)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1273)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1233)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.executeQuery(EntityManagerImpl.java:759)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.findInternal(EntityManagerImpl.java:703)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.find(EntityManagerImpl.java:597)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.find(EntityManagerImpl.java:476)
at test.eclipseLink.TestJPA.jlm_read_SingleRow(TestJPA.java:166)
at test.eclipseLink.TestJPA.initialize(TestJPA.java:80)
at test.eclipseLink.TestJPA.main(TestJPA.java:44)
Caused by: java.sql.SQLException: The connection does not exist.
at com.ibm.as400.access.JDError.throwSQLException(JDError.java:408)
at com.ibm.as400.access.AS400JDBCConnection.checkOpen(AS400JDBCConnection.java:460)
at com.ibm.as400.access.AS400JDBCConnection.prepareStatement(AS400JDBCConnection.java:2154)
at com.ibm.as400.access.AS400JDBCConnection.prepareStatement(AS400JDBCConnection.java:1965)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.prepareStatement(DatabaseAccessor.java:1401)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.prepareStatement(DatabaseAccessor.java:1350)
at org.eclipse.persistence.internal.databaseaccess.DatabaseCall.prepareStatement(DatabaseCall.java:652)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:576)
... 29 more
[Updated on: Mon, 22 April 2013 18:36] Report message to a moderator
Current Time: Mon Sep 23 16:22:52 GMT 2024
Powered by FUDForum. Page generated in 0.03189 seconds
