Home » Language IDEs » ServerTools (WTP) » Existing Web Application
Existing Web Application [message #154410] Sun, 01 January 2006 17:39 Go to next message
I have been using the Sysdeo Tomcat plugin to launch Tomcat and would like
to start using a WTP Tomcat server instead.
I don't see a way to make an existing project WTP enabled. I believe after
running through a tutorial this should be a Dynamic Web project.
Can I convert it? If so how?
My current project structure is as follows:
src/java for source code
webapp
webapp/classes
webapp/lib
webapp/html
webapp/html/*.jsp
webapp/WEB-INF
Thanks for the information
Re: Existing Web Application [message #154826 is a reply to message #154410] Wed, 04 January 2006 17:45 Go to previous messageGo to next message
> webapp
> webapp/classes
> webapp/lib
> webapp/html
> webapp/html/*.jsp
> webapp/WEB-INF
There was another thread on this topic a little while ago:
http://dev.eclipse.org/newslists/news.eclipse.webtools/msg08 792.html
The information was mostly refferring to WTP 0.7 however. I'd be very
interested to know if anyone has sucessfully integrated an existing web
app with WTP 1.0 and if so how it was done. I'd like to use WTP but if
this isn't possible without guessing the proper settings for configuration
files then I'll just go back to MyEclipse.
Re: Existing Web Application [message #155587 is a reply to message #154410] Tue, 10 January 2006 02:57 Go to previous message
Originally posted by: marx.nospam_wasko.pl
As I remember most important was to edit manually file
your-project\.settings\.component
and fix paths
Marx
Previous Topic:Multiple web services running simultaneously
Next Topic:Position on Allow Multiple modules per project
Current Time: Sun Nov 09 15:45:19 EST 2025
Powered by FUDForum. Page generated in 0.02559 seconds
