Unhandled loop exception when moving frames around [message #1045332] |
Sat, 20 April 2013 04:38 |
d grin Messages: 12 Registered: June 2012 |
If I start at my standard java view and then I move one of my open programs to the side (so I can see 2 open programs at once, side to side), and then I click on either of the frames, I get
unhandled event loop exception
Item not added
I then get the following in the event detail's stack trace -
eclipse.buildId=M20130204-1200
java.version=1.7.0_17
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
Error
Sat Apr 20 00:36:50 EDT 2013
Unhandled event loop exception
org.eclipse.swt.SWTError: Item not added
at org.eclipse.swt.SWT.error(SWT.java:4387)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.SWT.error(SWT.java:4247)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.ToolBar.createItem(ToolBar.java:392)
at org.eclipse.swt.widgets.ToolItem.<init>(ToolItem.java:128)
at org.eclipse.jface.action.ActionContributionItem.fill(ActionContributionItem.java:332)
at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353)
at org.eclipse.ui.internal.ActionSetActionBars.setActive(ActionSetActionBars.java:306)
at org.eclipse.ui.SubActionBars.activate(SubActionBars.java:151)
at org.eclipse.ui.SubActionBars.activate(SubActionBars.java:138)
at org.eclipse.ui.internal.ActionPresentation.setActionSets(ActionPresentation.java:141)
at org.eclipse.ui.internal.WorkbenchWindow.updateActionSets(WorkbenchWindow.java:1886)
at org.eclipse.ui.internal.WorkbenchPage$ActionSwitcher.updateActionSets(WorkbenchPage.java:772)
at org.eclipse.ui.internal.WorkbenchPage$ActionSwitcher.updateActivePart(WorkbenchPage.java:610)
at org.eclipse.ui.internal.WorkbenchPage$ActionSwitcher.updateTopEditor(WorkbenchPage.java:637)
at org.eclipse.ui.internal.WorkbenchPage.updateActiveEditorSources(WorkbenchPage.java:348)
at org.eclipse.ui.internal.WorkbenchPage.updateActivations(WorkbenchPage.java:251)
at org.eclipse.ui.internal.WorkbenchPage.access$15(WorkbenchPage.java:243)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:172)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$2.run(PartServiceImpl.java:193)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:191)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:596)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:549)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:105)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:61)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1447)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2328)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4572)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4989)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2541)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3129)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3753)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Why is this happening and how can I fix it? If I go back to a single program view at once it seems to work fine, but I really want to see both at the same time.
[Updated on: Sat, 20 April 2013 04:39] Report message to a moderator
FUDForum. Page generated in 0.04626 seconds
