Home » Modeling » TMF (Xtext) » [TCS] problem XML2
[TCS] problem XML2 [message #14458] Tue, 20 May 2008 08:27 Go to next message
Originally posted by: romain.perruchon.thalesgroup.com
I have a problem using XML2 (http://wiki.eclipse.org/TCS/Zoo).
It works with the examples but not with my file.
He re is a sample of my file :
<?xml version="1.0"?>
<log>
<logentry
revision="17327">
<author>she</author>
<date>2008-05-16T07:11:04.507637Z</date>
<msg>Déplacement des war de test en dehors de l'ear</msg>
</logentry>
</log>
The problem is from the first line (the mark '?') and from the word
Déplacement (the letter 'é').
I think i can fix the first problem but i don't know how to fix the second.
Re: [TCS] problem XML2 [message #14489 is a reply to message #14458] Tue, 20 May 2008 08:44 Go to previous messageGo to next message
I see also that I have problems with the text between tag.
for exemple <a> aaa </a> report an error
Re: [TCS] problem XML2 [message #14519 is a reply to message #14489] Tue, 20 May 2008 08:48 Go to previous messageGo to next message
We abord with TCS and we will work with the injector.
Re: [TCS] problem XML2 [message #14550 is a reply to message #14519] Fri, 23 May 2008 04:38 Go to previous message
You are right: the XML injector is the best solution to inject XML files.
The XML2 TCS Language Project is really just a partial proof-of-concept.
It merely illustrates that XML-like syntaxes may be injected with TCS.
The XML injector is more powerful because it relies on the sax XML parser.
Frédéric Jouault
Previous Topic:[TCS] Eclipse Freeze
Next Topic:TEF - any links to this project?
Current Time: Fri Nov 07 18:23:38 EST 2025
Powered by FUDForum. Page generated in 0.04636 seconds
