Problem with toolkit example for rcp [message #1043354] |
Wed, 17 April 2013 15:42 |
I would like to test an RCP application and I need to create some toolkit. So, I tried to make a toolkit with the example for RCP integrated in Jubula. I followed the steps in the "extending Jubula" document and now Jubula highlight the component (SWT Group). But when I want to check the property of this component, my check failed and I have a "Configuration error".
So, I would like to know what does it mean by "configuration error" and how I can fix this problem ?
I hope you can help me.
Elise Ruelle
ALL4TEC
Re: Problem with toolkit example for rcp [message #1044872 is a reply to message #1043354] |
Fri, 19 April 2013 12:48 |
I'm using the version 2.0.
But after some try I find the problem. Actually, the fragment ( in the example for extending RCP) has the host plugin org.eclipse.jubula.rc.swt but like it's for an RCP application the host plugin must be org.eclipse.jubula.rc.rcp.swt. After the deployment, I have no problem to test the new composant.
Thanks for your answer,
Best regards
Elise Ruelle
ALL4TEC
FUDForum. Page generated in 0.03308 seconds
