Home » Language IDEs » Java Development Tools (JDT) » Java Package Explorer Oddity
Java Package Explorer Oddity [message #1041908] Mon, 15 April 2013 14:47 Go to next message
We have one Java package, com.ibm.tivoli.ccm.sr that, in the Java Package Explorer displays as com.ibm.tivoli.ccm with an sr folder underneath and the set of Java source files in the sr folder. Picture is attached.
All of the files in this directory tree have:
package com.ibm.tivoli.ccm.sr;
Of the many Java packages in our project, this is the only one that does this. Any ideas as to why this is so?
Chris
  • Attachment: Snap18.jpg
    (Size: 4.95KB, Downloaded 163 times)
Re: Java Package Explorer Oddity [message #1041983 is a reply to message #1041908] Mon, 15 April 2013 17:13 Go to previous messageGo to next message
Click on the .java and hit mouse button 2 and select Properties. This
will tell you exactly where on your file system this file is found.
Is the file within a jar, and what path in the jar is the file located?
If not that then someone messed up and put the java file under the sr
folder instead of the real folder for the class.
Rich Kulp
Re: Java Package Explorer Oddity [message #1042039 is a reply to message #1041983] Mon, 15 April 2013 19:19 Go to previous message
Just figured it out. These files aren't currently used. Someone added an "excluded" entry for the package in the .classpath file.
Chris
Previous Topic:XML File generation
Next Topic:Formatting Source Code programmatically with JDT
Current Time: Mon Oct 27 03:57:38 EDT 2025
Powered by FUDForum. Page generated in 0.05388 seconds
