Home » Archived » BIRT » Exception when trying to set the timeout for the Dataset(NoClassDefFoundError: oracle/jdbc/driver/OracleTimeout)
Exception when trying to set the timeout for the Dataset [message #1039843] Fri, 12 April 2013 13:22 Go to next message
I am currently using BIRT 3.7.1. I have the reports running in a web application on the server. The reports are generated and either saved to the database or displayed as PDF's. I am trying to set a timeout so that if the report generation takes too long, let's say more than 2 minutes, then it will timeout. The way I do this is by going to the report template data set and going to the property binding tab where it says "Query timeout in seconds" and setting the timeout to 120. When I then hit the preview tab in eclipse to try and generate a sample report I get the ReportServiceException. When I show the stack trace it says NoClassDefFoundError: oracle/jdbc/driver/OracleTimeout which is typically when a library is missing.The driver class for my data source is OracleDriver (v11.2). When I go to manage drivers I see ojdbc6.jar there, which I believe is where the class is supposed to be. What do I have to do to get the report generation to work within Eclipse? If you need any more information please ask. When I deploy the application with the updated template, the report runs fine and no exception is thrown. Here is the stack trace.
org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
   at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1107)
   at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:935)
   at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
   at org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)
   at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
   at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
   at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
   at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)
   at sun.reflect.GeneratedMethodAccessor135.invoke(Unknown Source)
   at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
   at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
   at sun.reflect.GeneratedMethodAccessor134.invoke(Unknown Source)
   at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
   at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
   at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
   at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
   at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
   at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
   at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
   at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
   at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
   at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
   at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
   at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
   at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
   at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
   at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
   at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
   at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
   at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
   at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
   at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
   at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
   at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
   at org.mortbay.jetty.Server.handle(Server.java:326)
   at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
   at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:939)
   at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:218)
   at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
   at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
   at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
   at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:209)
   at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
   at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:929)
... 47 more
Caused by: java.lang.NoClassDefFoundError: oracle/jdbc/driver/OracleTimeout
   at oracle.jdbc.driver.PhysicalConnection.getTimeout(PhysicalConnection.java:3324)
   at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1271)
   at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3576)
   at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3620)
   at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1491)
   at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:460)
   at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doExecuteQuery(OdaQuery.java:469)
   at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.executeQuery(OdaQuery.java:433)
   at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.execute(PreparedStatement.java:575)
   at org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:927)
   at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:441)
   at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1124)
   at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
   at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:173)
   at org.eclipse.birt.report.engine.data.dte.QueryResultSet.(QueryResultSet.java:98)
   at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
   at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:267)
   at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1905)
   at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
   at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
   at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
   at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
   at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
   at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
   at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
   at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
   at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
... 49 more
Re: Exception when trying to set the timeout for the Dataset [message #1043308 is a reply to message #1039843] Wed, 17 April 2013 10:37 Go to previous message
Is there no way to set the timeout of a report or report engine?
Previous Topic:Iterate over data cube from java application
Next Topic:BIRT Line Chart
Current Time: Fri May 16 20:54:29 EDT 2025
Powered by FUDForum. Page generated in 0.03944 seconds
