Re: XML File generation [message #1041627 is a reply to message #1041577] |
Mon, 15 April 2013 10:40 |
Ed Merks Messages: 33142 Registered: July 2009 |
Julia,
Comments below.
On 15/04/2013 11:10 AM, Julia Blon wrote:
> Well ye, you are right. It's not really a JDT question, but i didnt
> find any java-only forum. I thought since I m using and extending the
> eclipse framework, i wanted to ask my question in a forum which is the
> most related to it. I m really sorry about this mistake.
It's not a big problem, you're just less likely to get answers if your
question doesn't fit the forum topic.
> About your answer and web tools: it seems to me that it does completly
> the opposite of that, what i m trying to do.
It lets you edit XML instances that conform to a XML Schema.... That
sounds like what you're doing...
> I would like to generate an xml file having and xsd and some value
> information which is extracted from my emf model. The tutorial is
> about generationg emf model using an xml or xsd.
Well yes, that would be the idea. You'd use the model generated from
the XSD to populate the information you want saved as XML, i.e., create
instances and set their feature's values. You'd put those model
instances into a resource (an XMLResourceImpl) and you'd save that; it
would produce XML that conforms to the schema. That sounds exactly like
what you're trying to do.
Ed Merks
FUDForum. Page generated in 0.04232 seconds
