Missing pieces with xtext and eugenia [message #1038875] |
Thu, 11 April 2013 13:09 |
Hello folks
Well, since I already buried a post and this seems to be a half-big post I thought I should make a new thread instead.
(Still trying to get some forum-experience so I know when to make a new thread or continue in one )
I was following the step-by-step guide for using Eugenia on a new XText project in the following here by Dimitris Kolovos.
The thing is I only get to step 4 and then it crashes so I was wondering if I could get some help in figuring out where I am going wrong.
First off, step 3, "Annote MyDsl.ecore" does that mean "notice the file that is placed here" or do you do something on this step?
If so this might be my error because I don't do anything here.
Claudio thought it might be erroneous annotation but since I haven't really named anything and only used defaults I thought I might have missed something on step 3.
The errors I get is:
Method 'getContainmentReferences' not found (bundleresource://614.fwk161007621/transformations/ECore2GMF.eol@189:38)
at org.eclipse.epsilon.eol.execute.PointExecutor.executeOperation(PointExecutor.java:167)
Method 'getAnnotationValue' not found (bundleresource://614.fwk161007621/transformations/FixGMFGen.eol@13:33)
And I seem unable to get around them.
What I have done is download this epsilon-eclipse and I don't think I have installed anything else into eclipse, the picture shows what I have installed.
Created a new XText project with defaults.
Gone to the mwe2 file and ran it as a mwe2 workflow.
Tried to generate tool, graph and map models without any luck.
So I was just wondering if I am missing an installation or something?
Have a nice day
Write you later / Mårten
-----------EDIT-----------
Remade the test again and only got one of the error messages but I added a file with the complete error code in case it helps.
[Updated on: Thu, 11 April 2013 13:15] Report message to a moderator
FUDForum. Page generated in 0.03279 seconds
