Blank report in REMEDY 7.6 [message #1036729] |
Mon, 08 April 2013 18:37 |
vik zik Messages: 3 Registered: January 2013 |
Junior Member |
Hi All,
I'm using BIRT Designer 2.5. I have created a report in BIRT. I'm able to see the data in BIRT IDE, however, when I upload the design file in Remedy Mid Tier I do not see any data (only column headings).
I have tried every possible thing, any help on what could possibly be wrong, would be greatly appreciated. I have upload the RPT design file for reference.
Thank in advance
-vik
[Updated on: Tue, 09 April 2013 03:44] Report message to a moderator
Re: Blank report in REMEDY 7.6 [message #1037186 is a reply to message #1037021] |
Tue, 09 April 2013 09:04 |
Junior Member |
Hi Michael,
Thanks for your time. I have this document with me. It's a basic kick-start document to start developing web report for Remedy, not of much use. I have faced this issue randomly in some other reports too. Talking about this one, It worked fine for some time before it stopped displaying the data at a later stage.
I was able to see the output after redesigning the report from scratch in other cases. But for this one, nothing seems to be a working solution. I hope it helps in understanding the issue better. Any insight ?
-vik
[Updated on: Tue, 09 April 2013 09:05] Report message to a moderator
Re: Blank report in REMEDY 7.6 [message #1037594 is a reply to message #1037186] |
Tue, 09 April 2013 19:18 |
If the column headers are showing correctly and it's just not bringing in data, it sounds like a parameterized report that's sending a bad value or something, so no values come back. I'll take a look at the actual report and let you know if I see anything that might cause a hang-up. With your saying that it worked before and just stopped working though, that makes it seem less likely that there's a problem with the actual design.
Michael
Developer Evangelist, Silanis
Re: Blank report in REMEDY 7.6 [message #1037600 is a reply to message #1037594] |
Tue, 09 April 2013 19:29 |
The above presumed you didn't get any errors about connecting to your data. There are lots of joins. You might make sure that there are no issues with fields matching up correctly. If you run the report from the designer, does everything work as expected? Do you have other reports that use this same data that are working fine?
Michael
FUDForum. Page generated in 0.21234 seconds
