Home » Language IDEs » C / C++ IDE (CDT) » A defect of Eclipse
A defect of Eclipse [message #152235] Wed, 24 August 2005 21:13 Go to next message
Originally posted by: sanduoren.yahoo.com.cn
The following program will wait for an input to go on. Now while the
program is waiting, I modify the program's code and rebuild. The result is
the executing program can't be stopped from console(The button "terminate"
disappeared), so I must kill the process by windows task manager. I think
the behaviour doesn't seems convenient.
My environment: Eclipse3.1 + CDT 3.0 + Mingw 4.1.0
int main(void)
cout << "before" << endl;
cin.get();
cout << "after" << endl;
return 0;
Best wishes!
Re: A defect of Eclipse [message #152237 is a reply to message #152235] Wed, 24 August 2005 23:02 Go to previous messageGo to next message
Originally posted by: yassin.hotmail.com
assuming you did the built after you run your executable
unless you cash your output the linker will not be able to open
the executable file.
you should have two console outputs one for your executable and
the other for the built
you should be able to select between them and terminate whatever process
you like
Re: A defect of Eclipse [message #152367 is a reply to message #152235] Fri, 26 August 2005 05:19 Go to previous message
Originally posted by: steffen.heinzl.informatik.fh-fulda.de
"CDTBeginner" <sanduoren@yahoo.com.cn> schrieb im Newsbeitrag
news:a08879ae0cf0055cdbe357848636c7f5$1@www.eclipse.org...
You can change to the Debug perspective. There the stop button appears
again.
Steffen
Previous Topic:Temporary breakpoint insert
Next Topic:CDT 3.0 Now Available
Current Time: Wed Sep 17 05:20:24 EDT 2025
Powered by FUDForum. Page generated in 5.28452 seconds
