Home » Eclipse Projects » Eclipse 4 » ECommandService injection Exception when requested in a Processor
ECommandService injection Exception when requested in a Processor [message #1036569] Mon, 08 April 2013 10:54 Go to next message
I am trying to inject the ECommandService in a Processor.
It throws an Exception. Do I need to do anything special?
Processor Declaration:
-----------8<---------------------
<extension
id="id2"
point="org.eclipse.e4.workbench.model">
<fragment
uri="xmi/ide_fragment.e4xmi">
</fragment>
<processor
beforefragment="false"
class="org.eclipse.emf.examples.extlibrary.presentation.EditorContributionProcessor">
<element
id="org.eclipse.emf.examples.library.e4editor.menu.emf">
</element>
</processor>
</extension>
Processor Class:
-----------8<------------------------
@SuppressWarnings("restriction")
public class EditorContributionProcessor {
private static final String VALIDATE_COMMAND =
"org.eclipse.e4mf.edit.ui.command.validateCommand";
@Inject
@Named("org.eclipse.emf.examples.library.e4editor.menu.emf")
private MMenu emfMenu;
@Inject
ECommandService commandService;
@Execute
public void execute() {
// // Get the commands.
// Command validateCommand = commandService
// .getCommand(VALIDATE_COMMAND);
ParameterizedCommand validateCommand = commandService
.createCommand(VALIDATE_COMMAND, null);
MHandledMenuItem validateMenuItem = MMenuFactory.INSTANCE
.createHandledMenuItem();
validateMenuItem.setWbCommand(validateCommand);
emfMenu.getChildren().add(validateMenuItem);
Exception:
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-04-08 16:49:17.173
!MESSAGE Unable to create class
'org.eclipse.emf.examples.extlibrary.presentation.EditorContributionProcessor'
from bundle '72'
!STACK 0
org.eclipse.e4.core.di.InjectionException: Unable to process
"EditorContributionProcessor.commandService": no actual value was found
for the argument "ECommandService".
org.eclipse.e4.core.internal.di.InjectorImpl.reportUnresolvedArgument(InjectorImpl.java:396)
org.eclipse.e4.core.internal.di.InjectorImpl.resolveRequestorArgs(InjectorImpl.java:387)
org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:102)
org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:321)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:255)
org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:186)
org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:49)
org.eclipse.e4.ui.internal.workbench.ModelAssembler.runProcessor(ModelAssembler.java:224)
org.eclipse.e4.ui.internal.workbench.ModelAssembler.processModel(ModelAssembler.java:191)
org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:213)
org.eclipse.e4.ui.internal.workbench.swt.E4Application.loadApplicationModel(E4Application.java:389)
org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:238)
org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:144)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
!ENTRY org.eclipse.e4.ui.workbench 2 0 2013-04-08 16:49:17.175
!MESSAGE Could not run processor
!STACK 0
org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:208)
org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:107)
org.eclipse.e4.ui.internal.workbench.ModelAssembler.runProcessor(ModelAssembler.java:226)
Re: ECommandService injection Exception when requested in a Processor [message #1036661 is a reply to message #1036569] Mon, 08 April 2013 13:07 Go to previous messageGo to next message
IIRC the command service is created through an Addon so it is not there
when processor are running!
Tom
On 08.04.13 16:54, Christophe Bouhier wrote:
> Hello,
> <extension
> id="id2"
> <fragment
> </fragment>
> <processor
> <element
> </element>
> </processor>
> </extension>
> Processor Class:
> @Inject
> @Inject
> @Execute
> Exception:
> from bundle '72'
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: ECommandService injection Exception when requested in a Processor [message #1036750 is a reply to message #1036661] Mon, 08 April 2013 15:11 Go to previous message
Thanks Tom, that explains it :-)
> Tom
>> Hello,
>> <extension
>> id="id2"
>> <fragment
>> </fragment>
>> <processor
>> <element
>> </element>
>> </processor>
>> </extension>
>> Processor Class:
>> @Inject
>> @Inject
>> @Execute
>> Exception:
>> from bundle '72'
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:Add Icon to Part in PartStack Container
Next Topic:Menu contributions to e4 IDE, insertion ID's fixed?
Current Time: Mon Nov 10 05:17:51 EST 2025
Powered by FUDForum. Page generated in 0.04154 seconds
