Equinox console error [message #1036264] |
Mon, 08 April 2013 06:41 |
John Connor Messages: 2 Registered: April 2013 |
Hi there.
I'm trying to run a set of bundles with Equinox, so I can run my bundles inside Eclipse, but I've found several problems.
What I've done to run my bundles is:
- Set the Eclipse Scope with the secondary bundles I'm using like felix.gogo.runtime, shell and command; the equinox console; osgi core and enterprise 5, and whatever bundles I need to fullfil the "java dependencies" I'm using in my project.
- Following this I've set a config.ini file to set the bundles configuration.
- Everything is set over Maven, althougth I don't think this is relevant.
So, I select run > OSGi framework within Eclipse and when it gets started I get the following:
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.console.command.adapter.Activator.start() of bundle org.eclipse.equinox.console.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:374)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1067)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:561)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:546)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:459)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:440)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
Caused by: java.lang.NoSuchMethodError: org.osgi.framework.BundleContext.registerService(Ljava/lang/Class;Ljava/lang/Object;Ljava/util/Dictionary;)Lorg/osgi/framework/ServiceRegistration;
at org.eclipse.equinox.console.command.adapter.Activator$CommandCustomizer.addingService(Activator.java:178)
at org.eclipse.equinox.console.command.adapter.Activator$CommandCustomizer.addingService(Activator.java:1)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:896)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:261)
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:184)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:339)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:273)
at org.eclipse.equinox.console.command.adapter.Activator.start(Activator.java:205)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
... 11 more
Root exception:
This is my config.ini, created in a configuration subfolder in my Target folder.
osgi.bundles=./org.apache.felix.gogo.runtime_0.8.0v<version>.jar@start,\
./org.apache.felix.gogo.command_0.8.0v<version>.jar@start,\
./org.apache.felix.gogo.shell_0.8.0v<version>.jar@start,\
./org.eclipse.equinox.console.jar@start,\
osgi.console.enable.builtin=false
osgi.console=<port>
I must say that I've already runned my bundles outside eclipse, but I wanted to start working the whole time inside Eclipse, without having to exit the eclipse environment to run my bundles by using the equinox console.
I feel that I'm missing smth that no one else is, because there's no other thread with this error in the entire Internet.
Thank you all for any advice you can give me.
Re: Equinox console error [message #1037880 is a reply to message #1036593] |
Wed, 10 April 2013 05:48 |
Thanks for your answer.
I've already found the solution.
The problem was that you need to load a few more org.eclipse.osgi bundles so it can work.
Here is the list of bundles you need to charge(it's the Dependencies list on the top of the page): docs. codehaus. org/ display/ GUMTREE/ Running+Equinox+OSGi
The problem I've found now is that when I run my OSGi bundles in Eclipse I get two consoles running at one time.
When I start running on the bundles, at first I get the osgi prompt "osgi>" (along with a huge amount of data from the bundle debugging) and when I write "ss" to get the bundle list, the gogo console starts, and I use lb to get the bundle list.
The gogo console manages to show me the bundle list, but when a try to start or stop a bundle, nothing happens. I've tried "start ID" and "felix:start ID" but without any result.
I can't really paste here my debugging code because I'm at work.
My best theory is that I'm loading two bundles that shouldn't be running together.
I figured out that excluding the org.eclipse.equinox.console and console.ssh I just get the OSGi prompt, but I still can't start/stop my bundles.
Here is a common bundle list that I've been using so far, I've already try a number of combinations, but I haven't really get any results, maybe you guys can help me, any suggestion or hint would be really appreciated.
org .eclipse .osgi .services
org .eclipse .osgi (I used to add directly the osgi.core, now I'm trying this one)
org .eclipse .equinox .registry
org .eclipse .equinox .preferences
org .eclipse .equinox .log
org .eclipse .equinox .launcher .win32 .win32 .x86 (wich doesn't get started I do not know why, It's just the one that matches my OS)
org .eclipse .equinox .console .ssh
org .eclipse .equinox .common
org .eclipse .equinox .app
org .eclipse .core .runtime .compatibility .auth
org .eclipse .core .jobs
org .eclipse .core .contenttype
org .apache .felix .gogo .shell
org .apache .felix .gogo .runtime
org .apache .felix .gogo .command
org .apache .felix .eventadmin
org .apache .felix .configadmin
Edit: spelling
[Updated on: Wed, 10 April 2013 05:56] Report message to a moderator
FUDForum. Page generated in 0.02818 seconds
