Better singleton aspect [message #1034484] |
Fri, 05 April 2013 09:39  |
The following is a neat Java singleton pattern:
public class XXX {
private static XXX instance = new Singleton();
private XXX () {}
public static XXX getInstance() {
return instance;
I hoped that I could implement an 'aspect' which can be applied to singleton classes in order to avoid this overhead. However, I am unable to find or implement a good solution. Google can only find the following one: http://www.christianschenk.org/blog/singletons-with-aspectj/
But honestly, "new XXX()" for getting the singleton instance? This solution can also be found in the AspectJ cookbook. IMHO this is a no go! There is also a quote:
Quote:The presented implementation should be well documented, because nothing would be more irritating than a novice developer in your team who doesn't know about this magic behind the scenes and relies on different instances of the singleton class ("I thought new would be doing...").
I cannot believe that the trivial singleton code above cannot be weaved into some classes (e.g. with MySingletonAnnotation). Is there no solution which allows the writing of "XXX.getInstance()"?
FUDForum. Page generated in 0.07290 seconds
