Home » Eclipse Projects » Virgo » Declarative Transaction Demarcation using AOP pointcuts
Declarative Transaction Demarcation using AOP pointcuts [message #1033651] Thu, 04 April 2013 09:32
I'm using @Transactional for transaction demarcation which makes my service implementation code dependent to org.springframework.transaction. To resolve this I tried using declarative transaction demarcation as described in the Spring documentation.
<beans ...>
	<osgi:reference id="entityManagerFactory"
		interface="javax.persistence.EntityManagerFactory" filter="(osgi.unit.name=my.persistence.unit)" />
	<bean
		class="org.springframework.orm.jpa.support.PersistenceAnnotationBeanPostProcessor" />
	<bean id="transactionManager" class="org.springframework.orm.jpa.JpaTransactionManager">
        <property name="entityManagerFactory" ref="entityManagerFactory" />
    </bean>
	<bean id="simpleBean"
		class="test.service.impl.SimpleServiceImpl"/>
	<osgi:service ref="simpleBean" interface="test.service.SimpleService"/>
	<aop:config>
    <aop:pointcut id="productServiceMethods" expression="execution(* test.service.impl.SimpleServiceImpl.*(..))"/>
    <aop:advisor advice-ref="txAdvice" pointcut-ref="productServiceMethods"/>
  </aop:config>
  <tx:advice id="txAdvice" transaction-manager="transactionManager">
    <tx:attributes>
      <tx:method name="persist*" propagation="REQUIRED"/>
    </tx:attributes>
  </tx:advice>
</beans>
The code seems to work. At least all my entities are persisted. But I'm getting the following error in the log at startup:
Schwerwiegend: Unable to create application context for [test.service.conf], unsatisfied dependencies: none
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.eclipse.gemini.blueprint.service.exporter.support.OsgiServiceFactoryBean#0': Initialization of bean failed; nested exception is java.lang.IllegalArgumentException: warning no match for this type name: test.service.impl.SimpleServiceImpl [Xlint:invalidAbsoluteTypeName]
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
	at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
	at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:567)
	at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913)
	at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:60)
	at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:325)
	at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
	at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:290)
	at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:137)
	at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.IllegalArgumentException: warning no match for this type name: test.service.impl.SimpleServiceImpl [Xlint:invalidAbsoluteTypeName]
	at org.aspectj.weaver.tools.PointcutParser.parsePointcutExpression(PointcutParser.java:301)
	at org.springframework.aop.aspectj.AspectJExpressionPointcut.buildPointcutExpression(AspectJExpressionPointcut.java:207)
	at org.springframework.aop.aspectj.AspectJExpressionPointcut.getFallbackPointcutExpression(AspectJExpressionPointcut.java:358)
	at org.springframework.aop.aspectj.AspectJExpressionPointcut.matches(AspectJExpressionPointcut.java:255)
	at org.springframework.aop.support.AopUtils.canApply(AopUtils.java:209)
	at org.springframework.aop.support.AopUtils.canApply(AopUtils.java:263)
	at org.springframework.aop.support.AopUtils.findAdvisorsThatCanApply(AopUtils.java:295)
	at org.springframework.aop.framework.autoproxy.AbstractAdvisorAutoProxyCreator.findAdvisorsThatCanApply(AbstractAdvisorAutoProxyCreator.java:117)
	at org.springframework.aop.framework.autoproxy.AbstractAdvisorAutoProxyCreator.findEligibleAdvisors(AbstractAdvisorAutoProxyCreator.java:87)
	at org.springframework.aop.framework.autoproxy.AbstractAdvisorAutoProxyCreator.getAdvicesAndAdvisorsForBean(AbstractAdvisorAutoProxyCreator.java:68)
	at org.springframework.aop.framework.autoproxy.AbstractAutoProxyCreator.wrapIfNecessary(AbstractAutoProxyCreator.java:359)
	at org.springframework.aop.framework.autoproxy.AbstractAutoProxyCreator.postProcessAfterInitialization(AbstractAutoProxyCreator.java:322)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsAfterInitialization(AbstractAutowireCapableBeanFactory.java:407)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1461)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
	... 13 more
I've already posted a similar question here http://www.eclipse.org/forums/index.php/t/430564/. But I'm wondering why persisting the entities works while at the same time the PointcutParser does not find the SimpleServiceImpl class. Did anyone use declarative transaction demarcation with Blueprint/Virgo?
Previous Topic:Weekly calls?
Next Topic:virgo in the cloud
Current Time: Sun Oct 19 20:20:43 EDT 2025
Powered by FUDForum. Page generated in 0.04518 seconds
