Re: [Texo] Persist already deleted objects [message #1033395 is a reply to message #1033367] |
Thu, 04 April 2013 07:36 |
Hi Bastian,
Yes this is expected behavior from the persistence layer and your solution is fine also. You can also try by setting the
db version (if you have that property) to null (instead of the id). That could be enough to.
gr. Martin
On 04/04/2013 08:59 AM, Bastian Wagenfeld wrote:
> Hi Martin,
> I ran into another problem, which I could bypass. But I thought this could be interesting for you, or you could tell me
> how to deal with it in another way.
> A user has an option to delete an object. After that, these changes will be committed to the database immediately. Now,
> he can undo these deletion. So the object (and its ID) will be restored and committed immediately, also. That leads to
> an exception, because this object cannot be merged:
> [EL Warning]: 2013-04-04 08:40:50.332--UnitOfWork(20501487)--javax.persistence.OptimisticLockException: Exception
> [EclipseLink-5006] (Eclipse Persistence Services - 2.4.1.v20121003-ad44345):
> org.eclipse.persistence.exceptions.OptimisticLockException
> Exception Description: The object [Customer [name: Customer] [description: Description for Customer]] cannot be updated
> because it has changed or been deleted since it was last read. Class> de.test.test.texo.model.Customer Primary Key> 1.722
> at
> org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitToDatabase(RepeatableWriteUnitOfWork.java:636)
> at
> org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabaseWithPreBuiltChangeSet(UnitOfWorkImpl.java:1565)
> at
> org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.writeChanges(RepeatableWriteUnitOfWork.java:445)
> at org.eclipse.persistence.internal.jpa.EntityManagerImpl.flush(EntityManagerImpl.java:798)
> at org.eclipse.emf.texo.server.store.EntityManagerObjectStore.flush(EntityManagerObjectStore.java:267)
> at org.eclipse.emf.texo.server.service.UpdateInsertModelOperation.internalExecute(UpdateInsertModelOperation.java:109)
> at org.eclipse.emf.texo.server.service.ModelOperation.execute(ModelOperation.java:59)
> at org.eclipse.emf.texo.server.web.WebServiceHandler.doPost(WebServiceHandler.java:111)
> at org.eclipse.emf.texo.server.web.WebServiceServlet.doPost(WebServiceServlet.java:65)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
> at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
> at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
> at de.test.test.filter.DatabaseSwitchFilter.doFilter(DatabaseSwitchFilter.java:38)
> at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
> at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
> at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
> at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
> at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
> at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
> at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:936)
> at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
> at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
> at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1004)
> at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
> at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
> at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
> at java.lang.Thread.run(Thread.java:722)
> To avoid this I manually remove all IDs, which seems to work.
> Best regards
> Bastian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.02750 seconds
