Websphere Issuses [message #151460] |
Mon, 12 December 2005 13:18 |
Originally posted by: jtesser.bju.edu
I am using WTP 1.0RC2 and trying to get it connected to Websphere 6.
My first problem is I cannot see and output in the console. Is there a
setting for this?
Secondly it is very slow. It takes like 3 min to get it going.
Re: Websphere Issuses [message #151583 is a reply to message #151460] |
Tue, 13 December 2005 09:47 |
Martin Rohla Messages: 2 Registered: July 2009 |
> setting for this?
1) output problem - defaultly, the output is written to WAS log files.
To change it, run administrative console on the corresponding WAS
profile, go to server configuration, then "Logging and tracing", then
"JVM logs" and there change file name for both "System.out" and
"System.err" to "console". Restart WAS and it should start writing logs
to Eclipse console.
2) slowness problem - that's a problem with how the connector is written
- it completely redeploys whole application during publish, therefore it
forces you to redeploy the application after each update you make (where
especially EJB recompiling takes ages). Better solution would be to use
the system that Rational App. developer uses - deploy the application
with a parameter that leaves the uncompressed binaries inside Eclipse
workspace and then compile classes to this location. WAS is then able to
reload this classes ad-hoc.
Martin Rohla
Unicorn, a.s.
Re: Websphere Issuses [message #151769 is a reply to message #151583] |
Tue, 13 December 2005 19:22 |
could you elaborate more on how I would deploy with the the uncompressed
binaries with the parameter so I could go into RAD and deploy and debug.
thank you.
Re: Websphere Issuses [message #153010 is a reply to message #151769] |
Tue, 20 December 2005 12:51 |
--------------070205040208030003080905
> debug. thank you.
I have made a modification of the WTP Websphere connector that works the
way I suggest, i.e. the first time you publish a project to the server,
it does the full deploy and creates a subdirectory inside the Enterprise
project in your workspace, where the uncompressed ear is stored for
Websphere.
All subsequent deploys just copy the contents to this directory and
Websphere reloads the changed classes right away (I also added the
parameter during the first deploy for automatic reloading). It works
fine for me so far.
There are some other points to be said, however:
1) to make things faster I turned off EJB deploy codes generating during
deploy. I created an ant file, that can be addes as builder to each
EJB project and that will take care of the Websphere specific deploy
codes generating (see readme inside attachment zip on how to setup it).
With this, the "copy deploy" works fine, all you need to do is to make a
clean on a project where you want the EJB deploy codes to be regenerated
(this needs to be done when EJB interface is changed, maybe in some
other situations as well).
2) I use some ant-contrib (http://ant-contrib.sourceforge.net/) tasks in
the main ant file for server deploys. I didn't figure out any way to
make the ant see the ant-contrib jar apart from adding it to the whole
workspace ant configuration (also mentioned in the readme).
Hope this will help.
I included sources in the plugin zip, so if anyone wants to enhance this
further, go on :)
Martin Rohla
UNICORN
http://www.unicorn.cz
Content-Type: application/x-zip-compressed;
name="was_mod.zip"
Content-Disposition: inline;
filename="was_mod.zip"
UEsDBBQAAgAIAL1rlDNSdQFaIQIAAEIHAAAMAAAAYnVpbGRFSkIueG1srVVN bxoxEL3zK1yr
J6S1AaWHol2iRqVVI6WHtlIvSJHZHcDErC3bG0Ir/ntmP9gAWcIKxaeVx++N 573xbHj9tFLk
EayTOo1on/Xo9agTfggCEr3L6pB8DT6zfp8Ner1PpH81HFwNe/1OGbkT1suU /NILJcqd98lL
ggDrMFYvIfYkFSuIKCync0gpSWAmMuUjWn3QUZE5TMDFVhqPUpQ7u/UdUrDC Axnf3iDaKL1x
ZKYtESkZx0oaV4aqdKyk4418hbZ40ID1m+piaycSttAroETpWPjCi3jInZ75 tbDA1zB1ZgH4
JQwms2gY5XmFNWsTo5JTt8/48X+daMsxSAkflTa0M3xPEy/sHPxwJ+VLpJ0x Rc6So7rwzgqy
J1pEa+H9Yl98EusE6KFHlYMK8PRMKsjLXYpHwaRmfmUSabcTbAAPK8OWwha1 H2BxM0/u24Bf
p65p/kmTMzisDGERZZNpJlUyiZVwDtwb0JpCprHKEqiU6XZ5lxVoyi8B343/ fAl+/PyGLN1W
DPB0xDC+/X0x9v4MMuQvgjUYylHtI5/+uvFy+rXog0ZWmZrMI+ych41gnfmz 6Hs8dJphLVz+
wA5f24mj2j7IdI7cODS03TTkPNEuYdEPRvjF256EB61Y3SgfC9sWfdjUTkXd Zxoh5Cf9LMMn
Lh/yPWuPQlmaP09n44t9yZ/269fY3AQ4XtdWeizY2wx29Ya8nFj4X+HVpMfx +QxQSwMEFAAA
AAAAk2uUM9330W4iMgAAIjIAAEgAAABvcmcuZWNsaXBzZS5qc3Quc2VydmVy LndlYnNwaGVy
ZS5jb3JlXzEuMC4wX21vZGlmaWVkX2J5X01hcnRpbl9Sb2hsYS56aXBQSwME CgAAAAAAnXaQ
MwAAAAAAAAAAAAAAAAgAAABwbHVnaW5zL1BLAwQKAAAAAACTa5QzAAAAAAAA AAAAAAAANAAA
AHBsdWdpbnMvb3JnLmVjbGlwc2UuanN0LnNlcnZlci53ZWJzcGhlcmUuY29y ZV8xLjAuMC9Q
SwMECgAAAAAAk2uUMwAAAAAAAAAAAAAAAD0AAABwbHVnaW5zL29yZy5lY2xp cHNlLmpzdC5z
ZXJ2ZXIud2Vic3BoZXJlLmNvcmVfMS4wLjAvTUVUQS1JTkYvUEsDBAoAAAAA AJNrlDMAAAAA
AAAAAAAAAAA6AAAAcGx1Z2lucy9vcmcuZWNsaXBzZS5qc3Quc2VydmVyLndl YnNwaGVyZS5j
b3JlXzEuMC4wL2ljb25zL1BLAwQKAAAAAACTa5QzAAAAAAAAAAAAAAAAQAAA AHBsdWdpbnMv
b3JnLmVjbGlwc2UuanN0LnNlcnZlci53ZWJzcGhlcmUuY29yZV8xLjAuMC9p Y29ucy9vYmox
Ni9QSwMECgAAAAAAk2uUMwAAAAAAAAAAAAAAAD4AAABwbHVnaW5zL29yZy5l Y2xpcHNlLmpz
dC5zZXJ2ZXIud2Vic3BoZXJlLmNvcmVfMS4wLjAvc2VydmVyZGVmL1BLAwQK AAAAAACTa5Qz
AAAAAAAAAAAAAAAARgAAAHBsdWdpbnMvb3JnLmVjbGlwc2UuanN0LnNlcnZl ci53ZWJzcGhl
cmUuY29yZV8xLjAuMC9zZXJ2ZXJkZWYvc2NyaXB0cy9QSwMECgAAAAgAk2uU M0HJMDtTAQAA
ywMAAEgAAABwbHVnaW5zL29yZy5lY2xpcHNlLmpzdC5zZXJ2ZXIud2Vic3Bo ZXJlLmNvcmVf
MS4wLjAvTUVUQS1JTkYvTUFOSUZFU1QuTUadk8tOwzAQRfeR8g/+AGJBl0Es SqnYUFQRqawd
Z5I6+BHscVv4evIilNCX2PrMvXNnMlkwLXJwGK3AOmF0TG7odRjce51JiBY9 HeBkQM9MQUxe
IU2qNVggj6DBCk4SsBuw5AFyoQXWIjIzNV5KX0RCD/LkQ6VGCt7ZGFtQ4FJU DmjpkLrWhG4h
da075bXHLXFCFxKwDnKH1sNgtp99L/1MMueWDNcxGZwaI1oyOxRNOYoNQ2Mv TEGbcZpp9oZZ
gc4ag3kvro0G9mQ4k+KTYRuw6oUv8O6Fhagr+t267WK9RqHgKgwOMHDGWw5u TDNIfdHWjEmZ
4dF3ybzm63q1Y7j92cFB7XlcTuDo+0lRs/QT/Yru2M7F+i7zYlwEKqfdLezU H9jMzY1SRlNl
Mi/hUJv/fyWmsU4UBv21RFOPJkFmMSbdVc93lbEYLRl/Y8Wlf0cYfAFQSwME CgAAAAgAk2uU
M7gej0p6AgAA4gQAAD4AAABwbHVnaW5zL29yZy5lY2xpcHNlLmpzdC5zZXJ2 ZXIud2Vic3Bo
ZXJlLmNvcmVfMS4wLjAvYWJvdXQuaHRtbI1UXW/bMAx8XoD8By4P+wBiK01b oFsTA12aYgWy
NljTDXuUbSbWJkuuJMf1vx9lx222BsOeBIrU3ZFHaPL68na2+rGcw+fVlwUs 7z8trmcwCBj7
fjxj7HJ12SZOwhFj85tB1O9NMpfL5kSe+tMJJzG6iHXpJqwN6DZHxyFzrgjw oRTb6Uwrh8oF
q7pASNpgOnD46JgHPIck48aim17f3QZnZ6cfgqOGjXU0sU5rkFxtpoP5TXB/ 12oZt8SwyoSF
HQe9GVMSKF9EVxibkpsaxidDGI9GpxNWRK/80+NoIRJUFqn+mOqb8lWGME+k KCzClS5Vyp3Q
CnL+Cy3wLReSxxKBS9k1AUKB8+yFLDcBBe/ePJTane/EtMH7EOBeSbQWtMvQ VILwhUpFwh2m
EKPU1ZBgsOsBPKDRW5FS2mmodQmkBk1T5NDkJEelXkQqvEQCXvtcv9fJX5ax FAnsmoRvaKxv
5SgcdRLny8WzvAvCKuodClDKS9jr2MGEDDW4ng68rR8Zq6oqxJYs1GbDJG64 ZFjIYHs0Cr2r
g+i/SyeMR2G/d6UNFKUptEW7p2UIrdCl0RvD8zaASpANOXK1P7nQG7xz83rd DC4VKSjtwGCC
YoutXd2gU0HXTtawNjpv+V74/8KaGIXaEF4qrDMiLhsTa3KkcRcKblzdTfnr c5U2u3k33qVi
vUbjEQ/6mfO63+NFQdLaBTBQkioaClfkU/yTZFN9iu0GPg8AYJZh8qu5+4P8 rQW52waXkaEV
31uySrjsLxgan9JgyyR7eoePBGeHzfJz4n/BcWDR+72Dm/6PJW7Wzzpv79MA fNOWhpDgwaaf
XGf+o2h/Dv9R/QZQSwMECgAAAAgAk2uUM6nQYZp6AgAAhAIAAE0AAABwbHVn aW5zL29yZy5l
Y2xpcHNlLmpzdC5zZXJ2ZXIud2Vic3BoZXJlLmNvcmVfMS4wLjAvaWNvbnMv b2JqMTYvd2Vi
c3BoZXJlLmdpZnP3dLOwTBRgEGB4xsDw/8//rauPNRQtb69elR2zICl4bmHK Ij+H/pKMtbFB
syvyVx7ed3fBzNMMDDIMDBIMDOIMDGIMDIKr1+zff/Ttuo3Hl6073z1l69R5 +5avPfTmw//o
lIbdx993T143f8WRKXO2Hr/44di5F6cuvY5Nb0rIao3PbFm/98nOoy+mzN3W N23d6w//33z8
H5ZUH5XWHJfZkpjdmpDVMmHmhoNnX7399D8qvTk6oyU6vTkqrSk2szUpryM5 r2P6oi1rdpy6
dPv52b//z/3/f+H//4v//1/+///K///X/v+/8f//rf//v/7///3//w8/fvz4 D/Tc/7///694
emzloyOOM1JcZqYyNDEwNDK09GXVtSfXd6S09WfVtiU392TUd6S29We39mU1 dWe09mW39ec0
92S19uXUdcTVdyQ096Q2dafWtaU0dqY3d2cWV4c2tKc0daZXNkaU1oQ1diS2 dGW1dGY2dyQ3
taecPrv7////DMCwBZP4geJPFkYGhhIGHRAHFCcM7A8bSkq4mdmYuUsKU/Jy MyOCC5vZeKaw
cYcV+fgWFSmElDBxLFrElFoUGCCsJhFewsa+YQNbGoOfP6OQSFQJC+e+fSxx GQX5OYnJ8c3s
XGfYuaOLNCW1jBSDSvS4WdlZuaXuP5AVjSlRdnZydLS3tXtrJ5WQFFui72LF x+fuZl1s7SHl
rZOiGX6kcY6yZ98Zx00Bh9n5Ql9MUPi0oLFP1evZiYsrFNm6OpTqJFoOeC4+ Jqqa0PCm0L99
DofNr5MbNx50dhFysHh5p/LxkVbTkqItGxKbj/ZImWZc2dHofHamR9Mir7le 6gIM1gBQSwME
CgAAAAgAk2uUMxRqJ+gzAQAA1wIAAEUAAABwbHVnaW5zL29yZy5lY2xpcHNl LmpzdC5zZXJ2
ZXIud2Vic3BoZXJlLmNvcmVfMS4wLjAvcGx1Z2luLnByb3BlcnRpZXO9UrFq AzEM3Q/uHwSd
a5pSMgS8NAltCg2BDF26+HzKReDYxval5O+rO5s0oRk61YNA1ntPT7K96Tuy a3VACR/YbP0e
A8ILWgykYYvhiAEWuCNLiZyFuePyhkn3ZOvKB3ekFsPIX2pDPqJwoePKqLvA qAP5gSk3GRsh
ZtH2R3T1/H7RXHlvSKuxkrF11WVDc5Wwc+EkmVFXdXUH8uLAFzYxa8gbp67O dTEVobeJDijs
YP3awHEqHm6D28t5+sZQ3PNAyrbAiAhvj8slTMQTHFzbG67wBAqM08qUSQR8 1tV5E42KvOSy
j11v9SCsDKXTdfvC/ZPVgv1Hp9xfxVf3y9vKxqSMyQ+5oIA68dPN+G+4kOSG w2ykcpMdGZTl
s5X0isGoORojh5DTtWtRDiGnmVsk+OobUEsDBAoAAAAIAJNrlDOd5mMtDAQA ANMSAAA+AAAA
cGx1Z2lucy9vcmcuZWNsaXBzZS5qc3Quc2VydmVyLndlYnNwaGVyZS5jb3Jl XzEuMC4wL3Bs
dWdpbi54bWzNWEtv3DYQPm+A/AdVaG9ZyWs3Rg7aGI0Btz4EMBIHOXMlrpaG RBIkZcf99R1K
lEhK4j6yLVAdZHk4/ObBmeHMZjc/6ip6xkISRtfxKrmII0xzVhBaruNvj3fL D/HNx7dvshuc
V4RLbHmvgLdd4lVTEgpfb99EUYZ/KEw1R8QZoWodM1EmZnPyIlUisQCMJGcC J6KhitT48ZVj
GX/U+wHBIXYUeEjhAz1ZoBJTLEjeYyUveCP5DgP6dTzsp6jG6/g3Z23g10uW scAyF4Sr1sRZ
fofDbnvGtGACdhhtbpHCJROvLofx2zX4baDmFZLyoGmtr8CZWFBUJX921K8t z5dOq9554L6a
FU3ley+KlPbwOtbYYFPsrBi9YPEyuXwXXSZX+vV7nB6PiJ8CiKtkpcEu9Gt1 EiISIUTQcaV1
XJ2mY84oxbliQdwLDfnegTyM2ShSEfUaROzBTFynTmC3C1k6JIvJnhPTp/se ssfokVmyo1kU
GfHrWIkGx97S2WHow4WzVc6nZ7uJEkVQ9VVB6qxjqRjnuACWxQIWpUJCPYL2 rAGfXF3ox9+u
NwwMq/fT9YZzJpT8gmum8F9MKjB4iyo5coVzSPdnFh39hOuJQZotJ/qpUEPz 3S2jW1IeoUl7
OO6eRiANqg3xgTd4h54Ja8Ttuaf+qUfyBcwUW4Pp11r97JD01J09k86sz6zQ mQcuf1fgTVOO
zx8i5BPegrYPzaYicmcCvU/oLLV50dOGP4txLma/LJfRt/voltWcUUyVXC77 C2rgHBTYn6sN
SV7I30gUdwKVtcZys3VriNaa4y87xwWqDdjDx7k/Yo8rBGDQ3tvou2ctlEHn nM4yW46LzQGr
Q+XmTDPn7LPg09JuaMfWdpDbfd3XqLSNkec+opcc+hHOa7e4SUNynW/6LVO2 eVpdp9ZbJdm6
rCf5ORou0f+ZmnuTIG1zcjE9ubYUdAffCoCavm0vK1Ao6qvC/sMNldWOZvH0 US8W2Zj8s+2v
o+mWVFCT0wE5nVZnoBr56VgBY+Op/UrIbPMP7+o0JLTt48ZLXo0/kLfWpFbK H1Q9DBJ8nCP8
acEQVVbTNOSKw9mds7pmNOGCPUEnmmxRjpU3Bk1GoGXe3z5Lde40NGCn8+DD jTQj3HS1g3zN
/xMazM9CqZWMCsSh3tpomKhyWimZquBMDOB/GAdeHcT90eX3Qeama1sojtTu QbBnUmDx610H
60pSficeEBMOj/uJlAE9S63PDMU0urj4D904nXjsWVr34rGc8PjZTZ96+BzN niGY+ZmzGzn1
xDkaOIMws4NmN2fqMdOfMiPnmg9CIs7BlbovOAH4MGx42OxnTTto+iHwr9Uq 3Q95HUl3vUfz
BeWMsNKhvu/GT2fsylLzO9Q/UEsDBAoAAAAIAJNrlDOCRjB3pQQAAH8WAABX AAAAcGx1Z2lu
cy9vcmcuZWNsaXBzZS5qc3Quc2VydmVyLndlYnNwaGVyZS5jb3JlXzEuMC4w L3NlcnZlcmRl
Zi9zY3JpcHRzL3dlYnNwaGVyZS42LngueG1s3VhLb9w2ED4rQP4DIeS0yEpo ivS0NpA2aeui
W/TUHNIeKGnWpkyRCknZ3gb73zsUKe3qGSULN0Hsi8XhvGe+4XhTKplDaoig BVyEGZRc7uHB
gNBMipCQDHa04qYhRfkLgOgeEiQlVEPG1EUYhZdPnzx9EmxQWAnK7L20e6qj G1lASO4or/Dg
2Qc8+hVPDmGMLEHNQ80NYdlFaKTk9sMKC4LNjnHQYEitoWasZR1izhJ3Jdgw kfIqA69uFeVU
hSR2/LEX4L6sYOBQgDDE/j0QGXvbGehWxDyTLA2GiPLfWaKoQr4435sbKU6s 2MSWzQfHUH2L
0SQKtKxUigYLMLHexVSYVAqj0Aj8E22JHgreGHHKmXKqtZWoYHcSrybammYF w5zV19xZKouI
JYVNmC5vQEGEGiIrT0dv9St335m6VAnkiSuFT1D0Jk9ee574MvCJX6qQCW0o 57QsF2u8ciyv
ypKzlJq6kp3iYKRMEyao2ke+wJ3ytmALmVUcIkXva8rh7/bIMh8iOCab3lHG acKB2NKzzEPJ
h5CYfWk7jSFfYwiWglzvKs7XWRumpmjUNXS789iCrkqx3LBLtWmUdsy7R/Mu ieuWf1nZayp/
Fb8OvqUGPbWKV9HKdaulwsOAalV4+iY+6vBdiNa5v3x5EmcMtpHtok5HhaTO UHDsRE/+U0kr
9HDSo7EXF522bc2NdVFQgXjyrC5vrAFSCV9DpBsdz7HDtEkBSkkMyo5yDT6y jRKXC4I/y7wI
gkdyZNwNmwHyYY0NYj97RLK22IKIrqQ0ZECsEMIdwmOtZkxc69GoGFWNBGUk JISMx8TRzgoI
Ib2I/GRBU3KMyp28BfKue/q+ArX/A73UruNOwGBLBb0G9Xz1D8F4KnNCGq0Q QsaDUbvfxsNl
fRO7lr1sUW6igRFHlzRw/kkNTPzPXBs3V0abOUcQW9bN7RxwxgVMlJX5japR D/wdP/1HamOq
lxxtYkQ4oqzMuOa1lXOiPZUZXINwCSTN6S1A+QtgbqmBzCfXk95XDEwDCf5M yL8oZxle7t4V
8i1VwjbQgOFK7KQqesdYy+gDw2nx/cseaVhsnmAUTXtq87tiSx+2UEiFU+TF yx+2fhq5DHbh
ajbG54HVZ8DuJO72gXcMeT8GvY/gzgT45rPgO42vUwA78L6fxTmIPRdjvyDI TqJsH2YHIDsP
s7b/8QBEhgHBr+Y1Zp9bIWG7wdvLAVwqyz0x0uPs2EPOZ+v/Q+TZa51XWBe0 rSu+ljaIREDT
G+LidRFWAhnXdkUrqaKF3dlUnZWF7k28GGes8Ra0y80xlYM8tsY5Vrtv1k3W DMrG1sPpS9oe
2pvOC7/J1ZKIVmmPzY7difzG7mIr6tDudDMDflBflUDf9USNzQ5++AoH/8hD fn6onAvDnzNW
lr7nl3pynCmP4c3EVIHZqSKk/0dNnoyNGLJWwCXN3gi7jWbN5xXuAQoXW/Jd zbQFQ19TQ39W
svixrn+y9tZAFrlK1gYJXchuN+GJgE+sCoNoz46xs+fYlxxkM5NsbowNwG98 3V+ygdakr3aX
7vg95/RxRfqWnA4+nu0a+79Fx+3vJvb/c0bif1BLAwQKAAAACACTa5QzSumV G6gFAACLFwAA
UwAAAHBsdWdpbnMvb3JnLmVjbGlwc2UuanN0LnNlcnZlci53ZWJzcGhlcmUu Y29yZV8xLjAu
MC9zZXJ2ZXJkZWYvd2Vic3BoZXJlLjYuc2VydmVyZGVm1Vjbbts4EH12gf6D IHQfQyYpGnQd
2UXioGiBpAnqFulbQUuMTS8lCiTlS4v8+w5JXW3ZsVN3sc1LrOFcDoczh5fg 3SLm3oxKxUTS
80/Qse/RJBQRS8Y9/+uX90dv/Xf9ly8CnajukErQ/JwlmsX05YsOmIIURnr+ ROu0izENOUsV
RUKO8VRprKwFHtOEShZi5+DLMqVX9IElTENQv3S0UKx0NJ/P0fy19XN6fHyC v91cD8MJjckR
S5QmSUitnWJdZcXXIiTaTuH5SLw2oYuKFiryTMSExLTnf7y88e7paJhOqKTe mV8lcHYGGYR8
dYJUipRKvfRY1PPnRH0QscXc4WREec//qy7TELPnR0zSUAu5tLJQJJoudM+X LuFWGNEHknEQ
4qXI5Hc3q+9SCI3B35GJ7mGIv4YgFVI3wpcCF1tpCUveDOy8N+P+ffx2UwgA cCfFA+Nr86yL
t061LeLGmeLUuVU4192Ma0A5XwVVyvZLgILim9Afn0REj0+sj41Rjc5q1FL2 C1FdxPV4w8qw
FrEm3TOmlZ3U5gclYwJ3gkT0X/00n48Bht9OBq3R/wDdByLz0woBohah4P2J HSg/jTuc+zO/
YxFlPLcxKPvQs2hORwG2X85XNuJMTa6YhOB590D8mriuBkRFH6A9gSr6QAKo IATj2M0M5WRg
4ijbyogkujQvPdc9WdwV2HbcdPqH4iby/407L/opUIeLHXKiVEr0pLIAoCjX CXDLuKu8yon5
hh2lqOyYsGRgrPqhiBEbxWiu0AhYB7qGpOh+eE0y04oAt1K1lnMh/4G+uiqY zSUtpz7I29p4
0SBjSeILOc5imuhG2Jz40X3ew57fcImhex/Y2M/Fhoseiw9DFOWHs3707byb 0SyGWXxHQEo1
7GJ9/+gqg/VCdp/lHBnG7TXi+p4HSvmabho2y7DuwpaQb8aLaTKdIl5s3pUO HrHE6kEagKAQ
7BeqPjwlM4I5G52vZMQsB1XnNc0WUWnnPnOYNBpMSJJQvqqLAUBdBOWLJ5Sn dVlEUy6WWgiO
YUY45dkY3OJiltSMKEMMThEXe7rnHX0z1VUWKk67q9OcSlrAwOBMyBGaEnn+ hJrJGqiB/1i9
OY7N/8Xpm7O4nvzB7efLCzSwZfT183XPJLHbzGi+xzDYZRUsKTQ11I1psFQ1 1nF4e3G3uycB
rdR0ZYvGzANlmnEoiTEkcIxikpAxlb32ZlTXYnzjNPx2e9cimaSXS9cFPS0z apWtu5KJUkm5
IBHKyyVXK51CYiWRS2SWaK0OoVbPm6W7tjhtMrNgpswD3GjALcS2mdAKBnNs JtLfQ2b5DrA/
k7llNGLkOqGgtCFg9dpYzas4zasYzavz2U509iSbQQdu5jIzuIXJvB356Q9g IjPT3SodnQ+6
+P7jp6vb+yEeLpWm8evTmuwXWuG/J8NDcaF3KCb0yoV4Hg+2WrezoLcLB+5e F89f9sMQoCM9
e0QszpH2YvTEYbR+BPVXTrQR0cSKOoH5aa81o4zxCJmFDHAprHRmhGe0nz83 wFUKq1CyVCtc
pfkMLdAi5s7c6duweD3udijA+WMKdeN00PSUUndn2ojL9fyK5qEh2OvPThBK zQNAyJI98pAl
vysTKzC256IJ45DZKEEU17rd1qPQPGwinsSwkoenUXQ67hpXCPOTT0kOxYuI 7xlz4FQvIDKc
sBn1LH/5NSaq2Dh/V9mubnaVinphU3FWXv633dDOb08bHgPCxXJfs0zy4rVF VbadGoNuSlpx
fc7ZcI8JrXjvBNMkYrAVJuAN7nflOXHGIiq/St5nTJjH2lc/HV9eRJGkSj12 zZuvPd6VmtbU
vskSPnCvVu+JO30aghcjgxgaGYVECo5MYKRShm4yrtmtHH1sMw1wu0cbzLi4 y1/Y8oq1xVt7
3oKzpi1R2MBqpbpq6CSNNAR47T29/y9QSwMECgAAAAgAk2uUM0V3nJmnCQAA JQ0AAEUAAABw
bHVnaW5zL29yZy5lY2xpcHNlLmpzdC5zZXJ2ZXIud2Vic3BoZXJlLmNvcmVf MS4wLjAvd2Vi
c3BoZXJlY29yZS5qYXKdlgs0lPkbxweDSSPCjDLuShn3y9DFpImZhpnRuJbL TIw7M2jGdSPJ
38RMI6yVy2Bdckmx0gVZubfuIWFLS8itZjdCRVrtbm216XT+z3t+73nf93y/ 3+d33vec5/0Q
cQJAEcC7SvZL0Qd8VJsAQAABbYvSNLfEaK+1AwDEf6QgQNK6dBkHmSSv3/mu L6n19UFKQFma
Y9A2tloEzAKhswOP09TqFcVpwrs7eyqtde7pj07SO00lTmhg8d1YOwCLb2fX C3x4NZdtLYmz
tgnKgqNmCYvgx6L44O/BeIjBGdyCVIT+9+x5tjobZ81gQ4wXkhcNwqvDqj/s 579bB66vALqX
9sYK8D8KDzeqTyDD4ytK8c+Uvoygr6ilv6BmeNBDPOhfMSltbAr1oDACvT3o X9uh6rfY3QI+
ygD9lbHrV/GSQ4IAgMD6y9jzzRko/yBiMIXqw1h/pOVGdWUwLtr7HJX0kjpF lsBi87wv3Y9s
0DyN17Dz4/yKiZPIPJgB3H2dtm9TQHKDq+c+di+PHXI8Cm0yJ+w9uxf55qHC QP9Kt9mORKKv
2Nn0zqxbxsuPph6Frr1eWTYBYF/GuuKN/E6QrSBNj5+jOxKcHtY2dYXFXNDM 7ybIl08HmfuG
dKuVstB5gG1NZtK3ZAarSmyN1dGV1SVtvg/DKH5XFibc4iY8yzz6Ytts61Ky XeI8oZP76c4/
XHesdclk2eN0qLBBREcq4qS9vVx3YHYe7sq0BPpC7bS1es01Flk5c2AUBdwu dLVfUj/dVi2H
qz6Z3GKerDGzOaF9p40/lkkdjAHpvyDZG7TUtY+yRbv0Xt5ZFJRvMKSKNZyX c0+xMjgwqfFD
tUNKB1y6fpF1ubu9UDnb6dBt0lENJiP9LdnTYuV0C+2Ooism5JpFFoto55ug 9oBVpruDQiNL
hw2XhPv3yb2YClowhDCcjXg7zTD7fR9qVSnOJ3iq44CGENgss5LhFBDWZ2gU D1qiHAchh3oS
V3/j8e/BBh9ryQjxIY7ttTGq8lHnsm5973KLe4KK5nh5xCjKtiaJbxnbbVqs 5FRAsrOVb1a0
KiEgTkveo9B7AuE3mOH9k2hyhaQpDL2V2zijY6mMQTgfGQAwS7Rp5tpDBYo1 qPLxmUz3u7l7
j0zTBAOZEhZQ9qs+6o2Uzt/S2goLWbEgUb/jJpitXkOVB6YRRY6Qyhf8TWW9 m85aaKg1Zl2y
KCx7cPRMWJJrKHXcWbRLBJMj5gqWjnt+1TWQFj2G3zUgqqwN/2FcmQyV19IF 0kZOHj5IgWli
l/XKQCSZ0s09mBEA+SIH5ZZ0rc1ruCL+RtH+0Wfcp4hzZ5OAtPRKP+m4fOxq 2R2U06Adjj6X
w4Wn0l/NOMOP44tEUM5FrcaT3QXUAdIanpkI3axk7SeAuA+5B8cZXV1CuAPr NExNwjtq/OKV
oLCaAcMLnKKYiYHO/h3C/b/Et53MGnsJBfPvvhtB3JEh1kCzal8SHfXNfNgn V9l4JazmIjbJ
UweG2cqYUw7WBblku+5Ht3eIVqj+LGg4pJthtOxuUZrGP9Lo5Fobf3P7loAy 2EG1c6GCNyOY
ptXOT3V6nLh/6MEpjT5QS2ouR6viUt4Js1UVEgpKHQ7xroeUu2fKHW/UinsA HsyJjEroL9W4
qVHdqjYt0UT2z6gZ3kdO9ktoAQVVOBtsAx91m+FsChW/kiQ1V/hIvIjkl5Om pNE4j6FuPpxd
n26TlZEnOBoWxB21G7YqiZ2qUcCSfiauyFTBGuUe5mdhHuntuz45VGirAtFb ASiIVJ7ftoV2
SaZ+V7OuXRVy+4Pm0sHAm/CcsQWdAy3SQe1BA9JqBTz7KiWmymlhMJIj0vvS QSycSY6xNMdF
lF7TT42Ov94n9x1MKtfSUugt0maW3CC3Oscacto/eKoLy8+f0Euf7y/yElvK lY50AVUdefNC
1nFBNjdKte7G9L6DyXtGto+cPHv0p4XcUomLfjnqsvWMIE6YyFDsSNCym1j2 8jkHk73Pdg7H
jHnIHmutmH6uyvzuj12YqyrnA5d0W5/kT9n/0ZfusSP1uYWkmgImz0heBXn7 TCYB/0oHIcNJ
DH5kdL8ZBibUqmhdrQpUeII9eS2+Ruw2JXBWFzolYDWwDPqdU1ZfN/FW9Hft 8fHINVXe8qhS
tAxf0W1tJ3Nu3lPUT/nAiP/VZUnYssOf7uIIFD9WrHglzhsvzpyws0iX8Nmp dioytrzNTQoq
NEMScxAbh0VsVhiWbw19mX0KUZxsMnoYLtJ0xP/5qTXhT+cyz0fKk8QPAGSt /8YMv3kum66f
iNRgLx//v6dylg2BIYESjxQARV92iRM/l5RWXKVRA0M4Oh6TP/fdoQ49e3qw kkp6lUPxm7jX
bHpLedr8qFXpqlUqspKqCNnrTbPrwYfeHhwJ8Ix6s7YkdzoeBlZHlvs9T1B5 feBmyGr9fPXN
O8g5zYCVNzTeidJ+lUrMk2rJkNhMPrdjsodLgNpBAhUdV/aotSXySpFNXfdv Q330JpC85UPl
TQpMXmrT9idO+5eyabHRgZel71BSsuq0nbcau2BnF0WZ9xwD2H6/KF8wFclg 2mC9kg5m596V
0IqC8m5UL/f54x5TSgcrskQfSM4bBxWeoY3pT9QYhzUff5ArqXN5dvFtujtz z2PmoMCRKhIz
Q54wPuQ/yOJ2vTa/wHTgdlmNM+74UAjQF6/d7Qy4TbXAHK9ifHv7KL9panE+ SwZq1Z3LYoM7
VDptxlakOLnnfwsOMxFH1kx5JK+KRmnbGfciSTgnSG9iQ8q9t/AmpPVdWbh3 8hnPgh/DC35U
gxgcFmlFv1G7l28/PtPVprxGOi9U1jZc1v9zWekvkkrhIvmUQjO3eEdCr0Ly Qcs62ev5m7wJ
0W1H0SEZlgTH7VccxtUtYTnElz9a9yR2qZjfMDutxzelY7pL0wJjZeU5ObIl XqsU1Btl5hrY
nGT/6FKjqlSeGXXrY0h4QTk9rp0P6shRSPPfJnzs18Pt26gyAu0dxFObLjCp aIQ1p3Zf+Fyz
++4n9GZTpHMuwrROJlhDOH9K356wSIlgrknuzPeWbVzlj1QYJsT0YoSE4F6p dVWe6RMC/lvn
4OEB/bWhcYu8NJmBXBlwagZ9UoyI4+OXEtiYG9+j0zMU4GM0/Jsi31u/zJHv qyBafQOq/Fpz
4Ierd81vfeDAjR3gTxwjgM+5cGOn+CdOYb4vceLGbulP3IgvuD9w48YhSp+E +G4c8jFHbhyn
+klcybfE/cOV/37TL5Hl+yqIfvbNmf/lzM+7fD4n/+0SK/z/Tk0iTlDoXYbI +jG8nm3414v6
E1BLAwQKAAAACACTa5Qz6JkY0soFAADUCAAASAAAAHBsdWdpbnMvb3JnLmVj bGlwc2UuanN0
LnNlcnZlci53ZWJzcGhlcmUuY29yZV8xLjAuMC93ZWJzcGhlcmVjb3Jlc3Jj LnppcAvwZmbh
YgCByI4JxgxIgAWI84vS9QNwquCBqkhNzsksKE7Fo1IATWVWcQke1eJYVBen FpWlFuHRpIhb
U3lqUnFBRmoRPheqEaM9OR/JDA4GmYwpxh/PMrAsYmJgOMXGwGBOtBmOeSUB pUk5mcVAIb2s
xLLEuaH3828ZCNQtC/rPrv3KeVHg9mo3mxTWrTN/CKpusPMRNnrIsSxT5ub0 S1m3/u/znsMU
m5nZHtB0/vnvd/t+14go7RTWNFgazOepxs1ckztB+gL/gp9sz5ZFNLLN0+Cd e3nyZeHKeI3e
HF05Fv3AtD9uM64GiMxljr625+4NdkHLopnKL2JS9kyxEU6dt2ZdyL4pmStZ vaZKy/2w5IvL
v3BIgdVgbvPC1SE79YqnfD+wPuNivc+CFXx1B+w7AhN+Tjzx3lIvIW7ZNVuL gANrL5Ub+a8P
+Vjy409VI6/yk2PN74+8eF5543Uyl2XGzBs927aE32mJnHnKvMNS6sGtqMe3 lneZsSR7+C17
VxV4znjmBhXhYwavUiLW8q7sPKjstM9gPrP2vH7pf0o33l+eHMbsmqOwd9qk P5E9s04kP/xy
W6Ej/9dFnRelc5U7rPcKr412WH5YT++c2+OLPzME5tfbVssXWLzzZf8b+eT+ Oaf6osul764u
OuNhnnSYu1F7udry0IzWCQo6N5oncacxnH604c5dZaGk2UdWR2aYSua0cG6N OsUTMX3ntRcP
vaRWCeduVtJOun57ZlOUD+eFi0wmXgZl10vLPsqsD36YI6TEV7vkxGehg7Za Ae/81S6+OV7w
zP365cR6k87b5yrXq3xbuf/JpNQY7dbY56f5Tm+22Rpgf/NVlImfxMUwCa3u II/4JQUpITd4
/lxMEXN7vEHet6nuTpplToTx/pjz166tEvTIffHv8kkz5SOJd32u/678udqr oSg2WFw3eOIN
npCk6meFIdN+5j4IX/M3/FRpldkjebeEk1079dtkmqN4c95f5jENEwyfmjM9 L/nZXw0p97d3
TR48TKiS7XlxaIv+7fx7hXxR2nfvONe/37Xl9bW3j+tf3E/NlwlN+ZageWpN YtmCDrd5Fz/v
/BIl/SXnavyvj+KIZP+z7JhR8Wt/yxeMDAxmrAwMpkQne2cgEZBTmp6ZB070 vVNO5902EHC9
brSgfkZa8k2NF7XMyg7yp5lcb8kveLnxbIQaZ9ELK41P7596X1P2E3CQLrT4 fs52ScoOi0+2
Tduq2xZNPaZYXXRE5pZx1Ddx83MyF5SEbz2qtV2d/illi2rFo/RzNien/Z1y znNrvcvyvaI/
HitdmHDl1b9j9/Iuh6/f9tYj38LhS9I17UnqKfuj9k/Xyo3Vnf6VZ9qH5w0F j4IaPU0FdMv5
PA6zHbS+4xSxeEN69zuPWxtubFmVfiw/SvPUu/yDyt7McRxXrzlW/g0/v+qq VtUO5u2eZwXD
mZr9UtfYFHOpPhLZwqa1bLaxSblh4uQiPunjLAf8GkMCFZ6t8QpY2Lz3a9OW 1MxS0atFU+7t
i1yyU/s57600wdZVTumyER7i4XFKRyYeVJ60/ZRqlPmlvjNx7veUa4/Lftct /Wb2kjci5fTt
upTDWxvnXl3+Zd7sZ+9OLbnwe0701tafgvOfK5QvMDno1/4q2vnfuVuJB/rK 4zK9FDmmdqo/
n6jLvNlOTfpYCvPJO0EJk2vPNck2L/OojWr+lLu7of2dGUunka/UY+85apl7 Gh6o8F3Y89WT
Ue+Y2vVz3wP395c15Ds9drvx5v5y3uUXe/QN13g/Clm/7Gin+5LALe/tvggn /T1Z4vUu76Nj
3fR591NWWXwUTW3//vW65KqHP/kDvBmZRJhx1zKwOuKtIwO8zsGtgwdFhxJG HYRbpwCKTh+s
dRJu3eIouqvw1VG4DVFEMWQ9cXUWbuPUUIx7R3RGRJiJvRaDgSWNRoxk12nI lmArMxCWaLKQ
WYIEeLOyMYAt4GCIAro/BcwDAFBLAQIUAwoAAAAAAJ12kDMAAAAAAAAAAAAA AAAIAAAAAAAA
AAAAEADtQQAAAABwbHVnaW5zL1BLAQIUAwoAAAAAAJNrlDMAAAAAAAAAAAAA AAA0AAAAAAAA
AAAAEADtQSYAAABwbHVnaW5zL29yZy5lY2xpcHNlLmpzdC5zZXJ2ZXIud2Vi c3BoZXJlLmNv
cmVfMS4wLjAvUEsBAhQDCgAAAAAAk2uUMwAAAAAAAAAAAAAAAD0AAAAAAAAA AAAQAO1BeAAA
AHBsdWdpbnMvb3JnLmVjbGlwc2UuanN0LnNlcnZlci53ZWJzcGhlcmUuY29y ZV8xLjAuMC9N
RVRBLUlORi9QSwECFAMKAAAAAACTa5QzAAAAAAAAAAAAAAAAOgAAAAAAAAAA ABAA7UHTAAAA
cGx1Z2lucy9vcmcuZWNsaXBzZS5qc3Quc2VydmVyLndlYnNwaGVyZS5jb3Jl XzEuMC4wL2lj
b25zL1BLAQIUAwoAAAAAAJNrlDMAAAAAAAAAAAAAAABAAAAAAAAAAAAAEADt QSsBAABwbHVn
aW5zL29yZy5lY2xpcHNlLmpzdC5zZXJ2ZXIud2Vic3BoZXJlLmNvcmVfMS4w LjAvaWNvbnMv
b2JqMTYvUEsBAhQDCgAAAAAAk2uUMwAAAAAAAAAAAAAAAD4AAAAAAAAAAAAQ AO1BiQEAAHBs
dWdpbnMvb3JnLmVjbGlwc2UuanN0LnNlcnZlci53ZWJzcGhlcmUuY29yZV8x LjAuMC9zZXJ2
ZXJkZWYvUEsBAhQDCgAAAAAAk2uUMwAAAAAAAAAAAAAAAEYAAAAAAAAAAAAQ AO1B5QEAAHBs
ZXJkZWYvc2NyaXB0cy9QSwECFAMKAAAACACTa5QzQckwO1MBAADLAwAASAAA AAAAAAAAAAAA
pIFJAgAAcGx1Z2lucy9vcmcuZWNsaXBzZS5qc3Quc2VydmVyLndlYnNwaGVy ZS5jb3JlXzEu
MC4wL01FVEEtSU5GL01BTklGRVNULk1GUEsBAhQDCgAAAAgAk2uUM7gej0p6 AgAA4gQAAD4A
AAAAAAAAAAAAAKSBAgQAAHBsdWdpbnMvb3JnLmVjbGlwc2UuanN0LnNlcnZl ci53ZWJzcGhl
cmUuY29yZV8xLjAuMC9hYm91dC5odG1sUEsBAhQDCgAAAAgAk2uUM6nQYZp6 AgAAhAIAAE0A
AAAAAAAAAAAAAKSB2AYAAHBsdWdpbnMvb3JnLmVjbGlwc2UuanN0LnNlcnZl ci53ZWJzcGhl
cmUuY29yZV8xLjAuMC9pY29ucy9vYmoxNi93ZWJzcGhlcmUuZ2lmUEsBAhQD CgAAAAgAk2uU
MxRqJ+gzAQAA1wIAAEUAAAAAAAAAAAAAAKSBvQkAAHBsdWdpbnMvb3JnLmVj bGlwc2UuanN0
LnNlcnZlci53ZWJzcGhlcmUuY29yZV8xLjAuMC9wbHVnaW4ucHJvcGVydGll c1BLAQIUAwoA
AAAIAJNrlDOd5mMtDAQAANMSAAA+AAAAAAAAAAAAAACkgVMLAABwbHVnaW5z L29yZy5lY2xp
cHNlLmpzdC5zZXJ2ZXIud2Vic3BoZXJlLmNvcmVfMS4wLjAvcGx1Z2luLnht bFBLAQIUAwoA
AAAIAJNrlDOCRjB3pQQAAH8WAABXAAAAAAAAAAAAAACkgbsPAABwbHVnaW5z L29yZy5lY2xp
cHNlLmpzdC5zZXJ2ZXIud2Vic3BoZXJlLmNvcmVfMS4wLjAvc2VydmVyZGVm L3NjcmlwdHMv
d2Vic3BoZXJlLjYueC54bWxQSwECFAMKAAAACACTa5QzSumVG6gFAACLFwAA UwAAAAAAAAAA
AAAApIHVFAAAcGx1Z2lucy9vcmcuZWNsaXBzZS5qc3Quc2VydmVyLndlYnNw aGVyZS5jb3Jl
XzEuMC4wL3NlcnZlcmRlZi93ZWJzcGhlcmUuNi5zZXJ2ZXJkZWZQSwECFAMK AAAACACTa5Qz
RXecmacJAAAlDQAARQAAAAAAAAAAAAAApIHuGgAAcGx1Z2lucy9vcmcuZWNs aXBzZS5qc3Qu
c2VydmVyLndlYnNwaGVyZS5jb3JlXzEuMC4wL3dlYnNwaGVyZWNvcmUuamFy UEsBAhQDCgAA
AAgAk2uUM+iZGNLKBQAA1AgAAEgAAAAAAAAAAAAAAKSB+CQAAHBsdWdpbnMv b3JnLmVjbGlw
c2UuanN0LnNlcnZlci53ZWJzcGhlcmUuY29yZV8xLjAuMC93ZWJzcGhlcmVj b3Jlc3JjLnpp
cFBLBQYAAAAAEAAQAOQGAAAoKwAAAABQSwMEFAACAAgANW6UM3YlD1CqBAAA KgkAAAoAAABy
ZWFkbWUudHh0fVVhb9s2EP1uwP/hIAxYDNhy27XdFmwG0i4tkmFt4AQI9img pZPFhCY1kori
Dfvve0dZcoYN+ZAgoXh37967e7yO3ASKjtrAFGumnSt1pbmkW96EpmbP9J4K Zy0X0Xmq8HNe
GN3g+u3N1el0Mp28ntE1x7YZP3Q61vKVXuev1h/f0UnjQtAbw2S5Yz+nTRvp gjrnH1Ao3Y61
DvTIPmhnZ9PJmxmtuTGq6EE5r7faKoM/tjn3VfL7EPPAHkF5N2DNC+f5DmXz V9SYFkEp/XRC
1CeyTJV3O1IxqqJG9T91M518N6NfXGeNUyUpGxfoN3q96a/WMTany+Wz8zy4 1hcMLracW45L
BJXU2kYVD6TjPJULjvaupUJZUkXBITzPnN8rP528BXFR+TgQN528m9FnJ3Lc alu6brG68lyh
L4sEi9WlelSL1YUNURkD7Jfr85BqIRyVz8oy/aeCfKHa7ZhK7ZNwewps8Bf9 BFD+bhT3TvfZ
7nBxtbxHgZSi8zoyWkAGIH5kq9lGsmrHc+J8m1N28eE3EjzQ+G3+JktRXx+m k/czuhEwwvbG
PUHxpygNyf9Q3+xJlSWwD/Fz2qkHbbfgjUquVGvidPL9izScgcfVurVR77hX Vm0o+2hUCI2K
dY+Fhoazz8ZtMDosxHPI5pSBKAIs9jJSl2drOTzcFpjQJs35M72GlCCAOrWf SxPpXtYFXIsq
PATRNOtH5kWSzSFdQn3lXcM+CrDFKgFr+pP90IaQ/rOUKXNRdDh+VKbF+UuV MjpJWhWnyzzP
l7h0nS4tz5rmOi0ONu2HGV1YMM1YBzq//CD178HEHMI3+17GVpsSn/KnnaFK Y41PtC1MKzJi
wdLqYo2Q7McZfQJx/821dbiJKoeDoUktcn6Q9Nj8xeoLd0ndvmJqFOVMAlE5 Y1yHQTk9EPAF
vJxSNnaVCqbAgaKUWPDi2jd/pU93BwB/L583NQao8Gxj/icqOwq35spzGIet qJ07OGh2g1+Y
NuRJFoehLDgj10R425gAGzqGcvEwR6jqx2/cLNDaTyX3XHxMW/711/mwTH27 7CnUrjUlbZiw
BHE8PtEVWQf6d+6RZcGgwOHO/FBcxjySYQk7+3Rzvu5LHzQRd/8dJnbM71mV e8kDRa3r6HQm
d67FKNqgtiz1OECjBRzVfhspmWSqXDr4FMMOHRzx+XiQqrCLyS3hBYPt1Mpu OVBXawyTqipc
FMzSusRinNhXYBa7aOC1Xc1WtlKsRKjBnZBseXx7ZKUdwr00EZwNYpQdG5ML 2rMRQ9NujA6o
aUVF9o3XUFY1DehXouFgZ/3jgxH1IE/MCFCktsA8+m4nEwzmClSNaWOCLvtJ +Xf6fORjIVql
OLEfpe3Q+AaPoJhYPyzH0cekiDDSe1/Y7PumkCK0m8B/tOLfh86EVUl+3wL3 uOUMN5NyuBj6
DlHi2AaoFBTHmoeZ8JxeTclQiAMjuSoXtSsSAFmFNN8iOiRK9PezULXGLEo8 8m4vU3gEg2Z2
Cgy1DWL4SYcovk+uGlhQUJJ3smF4zssjxrm8uTCkQtbYVUIndN+F8R2O6KPE RsX+vZn3Cdsg
o1HImWCiAZPt364Dafk/UEsBAhQAFAACAAgAvWuUM1J1AVohAgAAQgcAAAwA AAAAAAAAAQAg
AAAAAAAAAGJ1aWxkRUpCLnhtbFBLAQIUABQAAAAAAJNrlDPd99FuIjIAACIy AABIAAAAAAAA
AAEAIAAAAEsCAABvcmcuZWNsaXBzZS5qc3Quc2VydmVyLndlYnNwaGVyZS5j b3JlXzEuMC4w
X21vZGlmaWVkX2J5X01hcnRpbl9Sb2hsYS56aXBQSwECFAAUAAIACAA1bpQz diUPUKoEAAAq
CQAACgAAAAAAAAABAIAAAADTNAAAcmVhZG1lLnR4dFBLBQYAAAAAAwADAOgA AAClOQAAAAA=
--------------070205040208030003080905--
FUDForum. Page generated in 0.03568 seconds
