| ValueProperty bind to XML text [message #1033041] |
Wed, 03 April 2013 15:51  |
i'm struggling all day to achieve the following. I have the following interface:
@GenerateImpl
@XmlBinding( path = "constrain" )
public interface ClassConstraint extends IModelElement
ModelElementType TYPE = new ModelElementType( ClassConstraint.class );
@ReadOnly
@InitialValue( text = "biz.facilityboss.core.api.dependency.ClassConstrain" )
@XmlBinding( path = "@type" )
ValueProperty PROP_TYPE = new ValueProperty( TYPE, "Type" );
Value<String> getType();
void setType( String value );
@Required
@MustExist
@Type( base = JavaTypeName.class )
@Reference( target = JavaType.class )
@JavaTypeConstraint( kind = { JavaTypeKind.INTERFACE, JavaTypeKind.CLASS }, type = "biz.facilityboss.core.api.IService" )
ValueProperty PROP_CLASSCONSTRAINT = new ValueProperty( TYPE, "Class" );
ReferenceValue<JavaTypeName,JavaType> getClassConstraint();
void setClassConstraint( String value );
void setClassConstraint( JavaTypeName value );
The output which i get is the following:
<constrain type="biz.facilityboss.core.api.dependency.ClassConstrain">
<Class>Whatever Java Type selected</Class>
</constrain>
But what i want is the following:
<constrain type="biz.facilityboss.core.api.dependency.ClassConstrain">whatever Java Type selected</constrain>
To write the PROP_CLASSCONSTRAINT without it surrounding element, just its value.
Is that possible?
best regards
Max Larsson
| Re: ValueProperty bind to XML text [message #1033818 is a reply to message #1033384] |
Thu, 04 April 2013 13:23   |
It looks like the issue causing this not to work is the declaration of ClassConstraint property. In particular, the name given in the ValueProperty constructor does not match the name of the field holding ValueProperty instance, so none of the annotations are found by the framework.
Actual:
Correct:
ValueProperty PROP_CLASS_CONSTRAINT = new ValueProperty( TYPE, "ClassConstraint" );
Here is the full test case that shows this working once the above issue is corrected:
public final class ForumTestCase extends SapphireTestCase
@GenerateImpl
@ReadOnly
@Required
@MustExist
@XmlBinding( path = "" )
@GenerateImpl
@XmlBinding( path = "dependency" )
public interface Dependency extends IModelElement
ModelElementType TYPE = new ModelElementType( Dependency.class );
@Label( standard = "Identifier" )
@Required
@MustExist
@XmlBinding( path = "@identifier" )
ValueProperty PROP_IDENTIFIER = new ValueProperty( TYPE, "Identifier" );
Value<String> getIdentifier();
void setIdentifier( String value );
@Type( base = ClassConstraint.class )
@XmlListBinding( path = "" )
ListProperty PROP_CONSTRAINTS = new ListProperty( TYPE,"Constraints" );
ModelElementList<ClassConstraint> getConstraints();
private ForumTestCase( final String name )
super( name );
public static Test suite()
final TestSuite suite = new TestSuite();
suite.setName( "ForumTestCase" );
suite.addTest( new ForumTestCase( "test" ) );
return suite;
public void test() throws Exception
final ByteArrayResourceStore byteArrayResourceStore = new ByteArrayResourceStore();
final XmlResourceStore xmlResourceStore = new XmlResourceStore( byteArrayResourceStore );
final Dependency dep = Dependency.TYPE.instantiate( new RootXmlResource( xmlResourceStore ) );
dep.setIdentifier( "123" );
final ClassConstraint constraint = dep.getConstraints().insert();
constraint.setClassConstraint( "org.something.ExampleClass" );
dep.resource().save();
final String actual = new String( byteArrayResourceStore.getContents(), "UTF-8" );
System.err.println( actual );
The test case prints out the following output:
<dependency identifier="123">
<constrain type="biz.facilityboss.core.api.dependency.ClassConstrain">org.something.ExampleClass</constrain>
</dependency>
- Konstantin
FUDForum. Page generated in 0.04534 seconds
