Re: Slave on Raspberry PI (Could not initialize class com.sun.jna.Native) [message #1033848 is a reply to message #1033815] |
Thu, 04 April 2013 18:07 |
Winston Prakash Messages: 534 Registered: August 2011 Location: Fremont, CA USA |
Basically, what happening is when the build finishes, Hudson tries to kill all the processes started by the job. For this it uses Native support to find the process. BTW, this error is not happening on Raspberry PI, but on the master. Hudson is preparing to load the Native Support and send it to Raspberry PI to execute. Though the message says "Remote call on Raspberry failed", it appears while master load and prepare the remote call it failed.
Which machine your Hudson master is installed, MAC? Do you have the JNA support plugin installed correctly?
The error says "Could not initialize class com.sun.jna.Native", java.lang.NoClassDefFoundErro. Looking at jna.Native, it could happen if the Java does not have AWT.
Winston Prakash
Eclipse Hudson team
FUDForum. Page generated in 0.11289 seconds
