Property View - Unhandled event loop exception [message #1032039] |
Tue, 02 April 2013 13:52 |
Dan Simkins Messages: 38 Registered: December 2012 |
Member |
I have a number of nodes on the canvas, each with a textual name. I have implemented a property section as per tutorial that extends GFPropertySection and implements ITabbedPropertyConstants.
If I select a node on the canvas and display the property view, I can edit the textual name. If I select another node on the canvas, the 'name' field for this other node is shown correctly in the property view, however, if I click in the 'name' field, I get the exception shown below.
I have established that after selecting the second node, if I click on the property 'tab', this activates the property view and I do not see the error.
I have also established that this same behaviour is exhibited in the graphiti tutorial; adding two classes to the canvas and clicking between them with the property view open, when attempting to click in the name field, the exception is thrown.
I would appreciate any assistance in understanding the behaviour and pointers to a resolution.
Many thanks
Dan
Graphiti Version: 0.9.2.v20130211-0913
Error
Tue Apr 02 14:10:44 BST 2013
org.eclipse.e4.core.di.InjectionException: org.eclipse.swt.SWTError: Item not added
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:88)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:107)
at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:318)
at org.eclipse.e4.core.internal.contexts.EclipseContext.set(EclipseContext.java:332)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activate(EclipseContext.java:630)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activateBranch(EclipseContext.java:635)
at org.eclipse.e4.ui.internal.workbench.PartActivationHistory.activate(PartActivationHistory.java:52)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:561)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:532)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:105)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:61)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1447)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2328)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4572)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4989)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2541)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2440)
at org.eclipse.swt.widgets.Text.callWindowProc(Text.java:260)
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2570)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3129)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3753)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.eclipse.swt.SWTError: Item not added
at org.eclipse.swt.SWT.error(SWT.java:4387)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.SWT.error(SWT.java:4247)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.ToolBar.createItem(ToolBar.java:392)
at org.eclipse.swt.widgets.ToolItem.<init>(ToolItem.java:128)
at org.eclipse.jface.action.Separator.fill(Separator.java:67)
at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353)
at org.eclipse.ui.internal.EditorActionBars.setVisible(EditorActionBars.java:478)
at org.eclipse.ui.internal.EditorActionBars.setActive(EditorActionBars.java:375)
at org.eclipse.ui.internal.EditorActionBars.deactivate(EditorActionBars.java:154)
at org.eclipse.ui.internal.PartSite.deactivateActionBars(PartSite.java:588)
at org.eclipse.ui.internal.EditorSite.deactivateActionBars(EditorSite.java:81)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.deactivateActionBars(CompatibilityPart.java:368)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partDeactivated(WorkbenchPage.java:186)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$3.run(PartServiceImpl.java:205)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartDeactivated(PartServiceImpl.java:203)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.setPart(PartServiceImpl.java:160)
at sun.reflect.GeneratedMethodAccessor20.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 143 more
FUDForum. Page generated in 0.03178 seconds
