| Unknown extension point: 'org.eclipse.rap.ui.branding' [message #1031613] |
Mon, 01 April 2013 21:36  |
I am not sure this is the right forum for this question, but since it is RAP related I figured I kick it off here. More than happy to move it to another forum if deemed off-topic here.
So here is the issue: I created a branding entry point in plugin.xml, but Eclipse (3.7.2 and 3.8.2 RAP version) doesn't seem to like it. In both versions I get:
I created another workspace from scratch, as per some suggestions out there, but to no avail. I also found some suggestions to change the workspace class path, but I am not sure if that is still relevant for the current version(s).
Nor sure what else to try. Any suggestions are highly appreciated.
Kind Regards,
Erwin
| Re: Unknown extension point: 'org.eclipse.rap.ui.branding' [message #1031742 is a reply to message #1031613] |
Tue, 02 April 2013 02:21   |
Hi Erwin,
did you install and activate the RAP runtime target platform? Do you
have a dependency to "org.eclipse.rap.ui" bundle in your MANIFEST.MF?
Best,
Ivan
On 4/2/2013 4:36 AM, Erwin Hogeweg wrote:
> Kind Regards,
> Erwin
Ivan Furnadjiev
Twitter: @EclipseRAP
| Re: Unknown extension point: 'org.eclipse.rap.ui.branding' [message #1032427 is a reply to message #1031742] |
Tue, 02 April 2013 21:39  |
Ivan,
Thanks for the suggestions. When I added org.eclipse.rap.ui per your suggestion to the MANIFEST, I got an error that the bundle could not be found ...
I had assumed that all the rap bundles were part of the Eclipse RCP/RAP download. Apparently that is not the case. I found the bundle in the RAP-1.5 runtime. Problem solved.
Thanks for the help.
Erwin
FUDForum. Page generated in 0.04677 seconds
