| NoClassDefFoundError for ResourcePlugin [message #1030070] |
Sat, 30 March 2013 12:37  |
Howdy,
I have nearly completed my first Eclipse plugin. It is a fairly simple plugin that
allows different configurations for the application that I support at my job to be
selected. It works fine from my home system, where I did all the development and
testing, but when I exported the plugin and installed it on my work machine, I get
the following exception:
java.lang.NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin
at zlc.xstore.config.editor.ConfigEditor.saveFile(ConfigEditor.java:640)
I suspect that I have not configured the plugin correctly, but I cannot see where
my error is. My MANIFEST.MF is as follows:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: XStoreConfig
Bundle-SymbolicName: XStoreConfig; singleton:=true
Bundle-Version: 1.0.1.beta
Bundle-Activator: zlc.xstore.config.Activator
Bundle-Vendor: Michael Laris
Require-Bundle: org.eclipse.ui,org.eclipse.core.runtime,org.eclipse.co
re.resources;bundle-version="3.8.0"
Bundle-RequiredExecutionEnvironment: JavaSE-1.7
Bundle-ActivationPolicy: lazy
Export-Package: zlc.xstore.config,zlc.xstore.config.editor,zlc.xstore.
config.preferences
Bundle-ClassPath: lib/jdom-2.0.4.jar,.
and my plugin.xml is:
<?eclipse version="3.4"?>
<plugin>
<extension
point="org.eclipse.ui.preferencePages">
<page
name="XStore"
class="zlc.xstore.config.preferences.XStoreConfigPreferencePage"
id="zlc.xstore.config.preferences.XStoreConfigPreferencePage">
</page>
</extension>
<extension
point="org.eclipse.core.runtime.preferences">
<initializer
class="zlc.xstore.config.preferences.PreferenceInitializer">
</initializer>
</extension>
</plugin>
I am not sure if I have an error in the declaration, or deployment.
Any assistance will be appreciated.
Mike Laris
mglaris@gmail.com
| Re: NoClassDefFoundError for ResourcePlugin [message #1031845 is a reply to message #1030070] |
Tue, 02 April 2013 05:15   |
On 30/03/2013 23:33, MIchael Laris wrote:
> Howdy,
> allows different configurations for the application that I support at my job to be selected. It works fine from my home system, where I did all the
> development and
> testing, but when I exported the plugin and installed it on my work machine, I get the following exception:
> config.preferences
> <plugin>
> <extension
> <page
> name="XStore"
> </page>
> </extension>
> <extension
> <initializer
> </initializer>
> </extension>
> </plugin>
> Mike Laris
> mailto:mglaris@xxxxxxxx
Is your work machine running Eclipse 3.8? If it is an earlier version the org.eclipse.core.resources bundle-version="3.8.0" will fail. Look in the
..log file in the .metadata folder in your workspace to see what has been logged.
FUDForum. Page generated in 0.05754 seconds
