Home » Modeling » ATL » I need to submit my project omorrow,but there are some errors!
I need to submit my project omorrow,but there are some errors! [message #1029270] Fri, 29 March 2013 08:07 Go to next message
module Activites2PetriNets2;
create OUT : PetriNets from IN : UML;
helper context UML!Package def:isTopLevelPackage:Boolean=
	if self.refImmediateComposite().oclIsUndefined() then
	true
	else
		false
    endif;
rule Package
	from
	    s: UML!Package(s.isTopLevelPackage)
	to
		t1:PetriNets!PetriNet
		 name <- s.packagedElement->collect(e|e.name).first()+'_PetriNets'
rule InitialNode
	from
	    s:
	      UML!InitialNode
	to
	    t1:
	    	PetriNets!Place
			 name <- s.name+'_InitialNode',
			 outgoing <- t2,
			 token <-1
		t2:
			PetriNets!PlaceToTransition
			 name <- s.name+'_PlaceToTransition',
			target <- t3
		 t3:
		 	PetriNets!Transition
			 name <- s.name+'_Transition',
			 outgoing <- s.outgoing.first()//error
rule OpaqueAction
	from
	    s:
	      UML!OpaqueAction
     to
	    t1:
			 incoming <- thisModule.resolveTemp(s.incoming,'t3'),//error
rule ActivityFinalNode
	from
	    s:UML!ActivityFinalNode
	to
	    t1:PetriNets!Transition
		(incoming <- thisModule.resolveTemp(s.incoming,'t3'),//error
		 outgoing <- t2
		t2:PetriNets!TransitionToPlace
		 name <- s.name+'_TransitionToPlace',
		 target <- t3,
		 Guards <- t4,
		 Weights <- t5
		t3:PetriNets!Place
		 name <- s.name+'_Place',
		 token <- 0
		t4:PetriNets!Guard
		  name <- 'null',
		  value <- 'true'
		t5:PetriNets!Weight
		    name <- 'null',
			value <- '0'
rule ControlFlowEdge
	from
	    s:UML!ControlFlow
	to
	    t1:PetriNets!TransitionToPlace
		 target <- t2
		t2:PetriNets!Place
		 outgoing <- t3
		t3:PetriNets!PlaceToTransition
I have marked the wrong place with the error.The references can not work.I also want to generate default id(like xmi:id= or id=) corresponding to reference.
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns="PetriNets">
  <PetriNet name="Activity1_PetriNets"/>
  <Place name="Begin_InitialNode" token="1" outgoing="/2"/>
  <PlaceToTransition name="Begin_PlaceToTransition" source="/1" target="/3"/>
  <Transition name="Begin_Transition" incoming="/2" outgoing="/8"/>
  <Transition name="eat_Transition" outgoing="/11"/>
  <Transition name="over_Transition" outgoing="/6"/>
  <TransitionToPlace name="over_TransitionToPlace" target="/7" source="/5">
    <Guards name="null" value="true"/>
    <Weights name="null" value="0"/>
  </TransitionToPlace>
  <Place name="over_Place" incoming="/6"/>
  <TransitionToPlace name="First_TransitionToPlace" target="/9" source="/3"/>
  <Place name="First_Place" outgoing="/10" incoming="/8"/>
  <PlaceToTransition name="First_PlaceToTransition" source="/9"/>
  <TransitionToPlace name="Second_TransitionToPlace" target="/12" source="/4"/>
  <Place name="Second_Place" outgoing="/13" incoming="/11"/>
  <PlaceToTransition name="Second_PlaceToTransition" source="/12"/>
</xmi:XMI>
Re: I need to submit my project omorrow,but there are some errors! [message #1029945 is a reply to message #1029270] Sat, 30 March 2013 08:19 Go to previous messageGo to next message
In the error line, instead of s.incoming you have to write the navigation
expression to reach *in the source model* the element to translate.
Re: I need to submit my project omorrow,but there are some errors! [message #1029946 is a reply to message #1029945] Sat, 30 March 2013 08:20 Go to previous messageGo to next message
Dear Massimo Tisi,
> Thank you for your reply !I know that incoming in the OpaqueAction of
> UML metamodel is a sequence ,so that I modify the sentence like
> :incoming <- thisModule.resolveTemp(s.incoming.first(),'t3')and then
> it works .
> The following is the part of my output code:
> <Place name="Begin_InitialNode" outgoing="/2"/>
> I want to automatically generate the value of identifier Id in each
> element ,which correspond to incoming or outgoing reference .
> I want to get the file like:
> <Place name="Begin_InitialNode" Id="/1" outgoing="/2"/>
> <PlaceToTransition name="Begin_PlaceToTransition" Id="/2" source="/1"
> target="/3"/>
> <Transition name="Begin_Transition" Id="/3" incoming="/2" outgoing="/8"/>
> How can I do ?
> Look forward to your reply!
> Best Wishes!
> YeshengChai
Re: I need to submit my project omorrow,but there are some errors! [message #1029947 is a reply to message #1029946] Sat, 30 March 2013 08:20 Go to previous messageGo to next message
you can add a binding like this:
__xmiID__ <- newvalueoftheid
Re: I need to submit my project omorrow,but there are some errors! [message #1029950 is a reply to message #1029947] Sat, 30 March 2013 08:21 Go to previous messageGo to next message
The values of outgoing and incoming are automatically generated by the
> system. I also want to the value of id is automatically generated and
> the value of outgoing and incoming are determined by id.
> binding :__xmiID__ <- newvalueoftheid
> I do not know that what expression represent "newvalueoftheid".
> Can you describe it in detail!
> Thank you very much !
> Best Wishes !
> YeshengChai
Re: I need to submit my project omorrow,but there are some errors! [message #1029951 is a reply to message #1029950] Sat, 30 March 2013 08:22 Go to previous messageGo to next message
__xmiID__ allows you to manually decide what would be the id of each
element. You can for instance copy it from the __xmiID__ of the source,
like:
__xmiID__ <- s.__xmiID__
however you will not get the same ID numbering as the default XMI
serializer. To do this is more complicated and requires some java
programming for configuring the serializer.
Re: I need to submit my project omorrow,but there are some errors! [message #1029952 is a reply to message #1029951] Sat, 30 March 2013 08:22 Go to previous messageGo to next message
Dear Massimo Tisi,
> From the output code :
> I think the id of Place ,PlaceToTransition,Transition respectively seen
> as 1,2 ,3 in ATL_VM .I want to get those values because the the values of
> outgoing and incoming come from them .
> If I assign the source id to target id, but the value of incoming and
> outgoing do not come from them so that I can not know the relationship
> of elements .
> Outgoing and incoming are references pointing to elements.
> Best Wishes!
> YeshengChai
Re: I need to submit my project omorrow,but there are some errors! [message #1029953 is a reply to message #1029952] Sat, 30 March 2013 08:23 Go to previous message
when you set ids with __xmiID__ all the other references (like incoming and
outgoing) are updated.
Previous Topic:How can I get the MARTE Metamodel
Next Topic:How I can get the hierarchy of the events on a UML lifeline?
Current Time: Sat Jul 26 19:57:59 EDT 2025
Powered by FUDForum. Page generated in 0.07065 seconds
