Home » Eclipse Projects » DSDP - Target Management » RSE 2.0.0 (TM 2.0.1) FTP STOR ignores ASCII/binary preferences saving remote files
RSE 2.0.0 (TM 2.0.1) FTP STOR ignores ASCII/binary preferences saving remote files [message #14054] Tue, 07 August 2007 13:57 Go to next message
Originally posted by: davisons.qwest.com
I'm in the process of moving to Eclipse 3.3 with RSE 2.0.0 (with the TM
2.0.1 patches) and have noticed that the STOR operation to save remote files
always uses a binary transfer, regardless of the transfer type specified in
the preferences. The RETR operation to open files transfers according to
the settings in the preferences page. The same thing occurs when copying
files between the Local connection and a remote host. Should this be the
expected behavior? I've been using Eclipse 3.2.2 with RSE 1.0.1 and it uses
the preferences settings to open and save files. The consequence of this
new behavior is that I'm getting unexpected line break characters.
My connections are setup as FTP only connections for both versions of RSE.
Has anyone else experienced this? I looked for a bug description and
couldn't find anything like what I'm seeing -- perhaps I should open one?
Stephen Davison
Re: RSE 2.0.0 (TM 2.0.1) FTP STOR ignores ASCII/binary preferences saving remote files [message #14072 is a reply to message #14054] Tue, 07 August 2007 14:06 Go to previous messageGo to next message
I should have written RSE 2.0.0.1 instead of TM 2.0.1. I apologize for the
sloppiness.
"Stephen Davison" <davisons@qwest.com> wrote in message
news:f9abqn$106$1@build.eclipse.org...
> files always uses a binary transfer, regardless of the transfer type
> specified in the preferences. The RETR operation to open files transfers
> according to the settings in the preferences page. The same thing occurs
> when copying files between the Local connection and a remote host. Should
> this be the expected behavior? I've been using Eclipse 3.2.2 with RSE
> 1.0.1 and it uses the preferences settings to open and save files. The
> consequence of this new behavior is that I'm getting unexpected line break
> characters.
> Stephen Davison
Re: RSE 2.0.0 (TM 2.0.1) FTP STOR ignores ASCII/binary preferences saving remote files [message #14089 is a reply to message #14072] Wed, 08 August 2007 13:09 Go to previous messageGo to next message
There was a bug related to ASCII / Binary transfer and especially line
endings: https://bugs.eclipse.org/bugs/show_bug.cgi?id=189352
That one is marked fixed, if you still see an issue please file a new
bug. Perhaps the patch attached to the old bug helps understanding
what's going on.
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> sloppiness.
>> characters.
>> Thanks,
>> Stephen Davison
Re: RSE 2.0.0 (TM 2.0.1) FTP STOR ignores ASCII/binary preferences saving remote files [message #14106 is a reply to message #14089] Mon, 13 August 2007 11:49 Go to previous message
Martin, thanks for the response and the link to the previous bug. There is
still an issue with the file transfer type for FTP Only connections. I've
submitted bug id 199773 for this issue.
Stephen
"Martin Oberhuber" <martin.oberhuber@windriver.com> wrote in message
news:f9ctd9$vac$1@build.eclipse.org...
> That one is marked fixed, if you still see an issue please file a new bug.
> what's going on.
> Martin Oberhuber
>> the sloppiness.
>>> transfers according to the settings in the preferences page. The same
>>> thing occurs when copying files between the Local connection and a
>>> remote host. Should this be the expected behavior? I've been using
>>> Eclipse 3.2.2 with RSE 1.0.1 and it uses the preferences settings to
>>> open and save files. The consequence of this new behavior is that I'm
>>> RSE.
>>> one?
>>> Thanks,
>>> Stephen Davison
Re: RSE 2.0.0 (TM 2.0.1) FTP STOR ignores ASCII/binary preferences saving remote files [message #569692 is a reply to message #14054] Tue, 07 August 2007 14:06 Go to previous message
sloppiness.
> characters.
> Stephen Davison
Re: RSE 2.0.0 (TM 2.0.1) FTP STOR ignores ASCII/binary preferences saving remote files [message #569708 is a reply to message #14072] Wed, 08 August 2007 13:09 Go to previous message
what's going on.
Martin Oberhuber
> sloppiness.
>> characters.
>> Thanks,
>> Stephen Davison
Re: RSE 2.0.0 (TM 2.0.1) FTP STOR ignores ASCII/binary preferences saving remote files [message #569743 is a reply to message #14089] Mon, 13 August 2007 11:49 Go to previous message
Stephen
> what's going on.
> Martin Oberhuber
>> the sloppiness.
>>> RSE.
>>> one?
>>> Thanks,
>>> Stephen Davison
Previous Topic:RSE 2.0.0 (TM 2.0.1) FTP STOR ignores ASCII/binary preferences saving remote files
Next Topic:Programatically creating a connection?
Current Time: Wed Nov 05 00:41:01 EST 2025
Powered by FUDForum. Page generated in 0.04050 seconds
