Using UML profile as metamodel [message #1027965] |
Wed, 27 March 2013 16:51 |
Dave Carlson Messages: 402 Registered: July 2009 |
I am new to ATL and attempting to write some transformation of UML to UML, where different profiles are applied to the input and output models, and the models are restructured. My UML profiles are generated as Ecore static profiles, and they do show in the list of available ATL metamodels.
The problem I have is always getting OclUndefined when attempting to access toe base_* attributes of the stereotype instance. I have seen other forum posts where this worked. Are the other posters using only dynamic UML profiles (as annotations within UML profile model)?
I have been working in eclipse 3.7.2, but just tried 4.3M6 with the same problem.
My ATL source looks something like the fragment below, where StereotypeA is applied to a UML Enumeration. I get a runtime error that base_Enumeration is undefined. However, if I use a modified rule where MyProfile!StereotypeA is replaced with UML!Enumeration, then the rule (with modified output) works fine.
I really like the idea of writing ATL transformations using static UML profiles, which allows me to ass additional methods onto the stereotypes to be implemented in the generated Ecore, and used by ATL. Any help is appreciated!
module TestProfiles;
create OUT : UML from IN : MyProfile;
rule ResolvedValueSet {
from
s : MyProfile!StereotypeA
to
t : UML!Enumeration (
name <- s.debug('stereotype A: ').base_Enumeration.debug('baseEnum: ').name
Re: Using UML profile as metamodel [message #1027972 is a reply to message #1027965] |
Wed, 27 March 2013 17:03 |
I'll tell you the way I use it, I'm not an expert, but it works for me
rule myRule{
from myElement: UML!Class in IN (
myElement.hasStereotype('myStereotype')
to
target : UML!Class(
name <- 'name'
do{
target.applyStereotype(thisModule.getStereotype('targetStereotype'));
using these helpers:
helper context UML!Element def: hasStereotype(stereotype : String) : Boolean =
self.getAppliedStereotypes()->exists(e|e.name=stereotype);
helper def : getStereotype(name : String) : UML!Stereotype =
UML!Stereotype.allInstances()->any(p | p.name = name);
helper def: getProfile(name: String): UML!Profile =
UML!Profile.allInstances()->any(p | p.name = name);
Hope it helps!
Re: Using UML profile as metamodel [message #1035832 is a reply to message #1027965] |
Sun, 07 April 2013 13:55 |
I'm not familiar with Ecore static profiles, just the regular (dynamic?) UML
profiles with embedded parts of Ecore in there.
If you can already manage to trigger ATL rules on your stereotype
applications, you've covered the problem of providing ATL with the right
metaclasses for your stereotypes. All I can say from here is that the ATL code
does not do anything special with the "base_*" references: they are treated
the same as other references. Also, getting OclUndefined as a value means that
ATL did find the actual reference, but it wasn't set for some reason.
Please also show us the modified rule.
This is indeed a nice idea, and would tackle one of the major drawbacks of UML
profiles vs. Ecore metamodel extensions!
Dennis
> from
> to
Dennis
FUDForum. Page generated in 0.03533 seconds
