Xtext: Referencing Elements of one DSL from another DSL Problem [message #1024370] |
Tue, 26 March 2013 06:59 |
Srinivas MV Messages: 16 Registered: February 2013 |
Hi ,
I was trying out an example of Referencing Elements of one DSL from another DSL . I followed this example from Christian.
http://christiandietrich.wordpress.com/2012/08/07/xtext-referencing-elements-of-one-dsl-from-another-dsl/
Here is my grammar
grammar org.xtext.example.definitions.Definitions with org.eclipse.xtext.common.Terminals
generate definitions "http://www.xtext.org/example/definitions/Definitions"
import "http://www.eclipse.org/emf/2002/Ecore"
Model:
definitions+=Definition*;
Definition:
'define' name=[EClass];
Referencing Grammar
grammar org.xtext.example.usages.Usages with org.eclipse.xtext.common.Terminals
generate usages "http://www.xtext.org/example/usages/Usages"
import "http://www.xtext.org/example/definitions/Definitions" as def
Model:
usages+=Usage*;
Usage:
'use' definition=[def::Definition];
Exception thrown while running
1593 [main] INFO ipse.xtext.generator.LanguageConfig - generating infrastructure for org.xtext.example.usages.Usages with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, EcoreGeneratorFragment, SerializerFragment, ResourceFactoryFragment, XtextAntlrGeneratorFragment, JavaValidatorFragment, ImportNamespacesScopingFragment, QualifiedNamesFragment, BuilderIntegrationFragment, GeneratorFragment, FormatterFragment, LabelProviderFragment, OutlineTreeProviderFragment, QuickOutlineFragment, QuickfixProviderFragment, JavaBasedContentAssistFragment, XtextAntlrUiGeneratorFragment, Junit4Fragment, RefactorElementNameFragment, TypesGeneratorFragment, XbaseGeneratorFragment, CodetemplatesGeneratorFragment, CompareFragment
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl.hasExtendedMetaData(GenPackageImpl.java:4388)
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl.initialize(GenPackageImpl.java:2777)
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenModelImpl.initialize(GenModelImpl.java:2265)
at org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment.getSaveAndReconcileGenModel(EcoreGeneratorFragment.java:652)
at org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment.generate(EcoreGeneratorFragment.java:207)
FUDForum. Page generated in 0.03450 seconds
