Re: Exporting multiple XSD schemas to ecore programmatically [message #1024021 is a reply to message #1023999] |
Mon, 25 March 2013 16:54 |
Ed Merks Messages: 33141 Registered: July 2009 |
Skander,
Comments below.
On 25/03/2013 12:02 PM, Skander Turki wrote:
> Hi All,
> I am trying to export a group of interrelated XSD schemas to ecore
> programmatically(in order to get an ecore annotated with proper
> extended metadata for XML serialization). I am using the
> XSDEcoreBuilder but in the resulting ecore models, the external
> inheritance links are lost.
What do you mean by the external inheritance links?
> I tried using the XSDEcoreBuilder.generate(collection<URI>) but I also
> wanted to try XSDEcoreBuilder.generate(XSDSchema) but this method
> returns void, I didn't understand how to use it.
If you look at the implementations of these methods, you should get the
idea...
> If anyone have any idea, it would be very helpful.
> Here is my code using XSDEcoreBuilder.generate(collection<URI>):
> public void exportXSDToEcore(Collection<URI> sourceXSDFilePaths_p) {
> XSDEcoreBuilder xsdEcoreBuilder = new XSDEcoreBuilder();
> ResourceSet resourceSet = new ResourceSetImpl();
> resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi",
> new XMIResourceFactoryImpl());
> resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xsd",
> new XSDResourceFactoryImpl());
> resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("genmodel",
> new EcoreResourceFactoryImpl());
> resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("ecore",
> Collection<Object> eCorePackages =
> xsdEcoreBuilder.generate(sourceXSDFilePaths_p);
> Resource resource =
> resourceSet.createResource(URI.createFileURI("metamodel.generated.ecore"));
> for (Object element : eCorePackages) {
> if (element instanceof EObject) {
> resource.getContents().add((EObject) element);
> try {
> resource.save(null);
> } catch (IOException e) {
> e.printStackTrace();
Ed Merks
FUDForum. Page generated in 0.03340 seconds
