Home » Newcomers » Newcomers » configuring jre's javadocs: How use local version rather than web?
configuring jre's javadocs: How use local version rather than web? [message #149292] Wed, 19 April 2006 12:53 Go to next message
On Mac OS X, I've configured Eclipse 3.1.2 to use the JDK 1.5 that is
available from the developer connection at apple.com.
The JRE seems to be found and used just fine by eclipse. But when I ask
to look at the javadocs for classes in the JDK, it does not use the
local version of the javadocs, instead it goes to the sun web site.
The help docs claim that in the JRE edit dialog, there should be a
Javadoc URL entry which should be browsable within the local file system.
There is not such a dialog entry visible that I can see! Here is a
screen shot of the dialog:
http://backspaces.net/files/Eclipse001.png
Does anyone know how I can associate my local javadocs with the JRE?
Owen
Re: configuring jre's javadocs: How use local version rather than web? [message #149295 is a reply to message #149292] Wed, 19 April 2006 12:59 Go to previous messageGo to next message
Owen,
the javadoc and source location can be set individually for each JAR
file that makes up your JRE. Simply select the jars and press the 'Edit'
button visible on your screenshot, or expand the tree notes and edit the
javadoc locations directly.
HTH, tom
> Thanks
> Owen
Re: configuring jre's javadocs: How use local version rather than web? [message #149382 is a reply to message #149295] Thu, 20 April 2006 19:25 Go to previous message
Thanks Tom, worked like a charm.
Owen
Tom Eicher wrote:
> Owen,
> HTH, tom
>> ask to look at the javadocs for classes in the JDK, it does not use
>> the local version of the javadocs, instead it goes to the sun web site.
>> Thanks
>> Owen
Previous Topic:Installing WTP
Next Topic:Can the Product export wizard be automated?
Current Time: Mon Oct 27 03:57:41 EDT 2025
Powered by FUDForum. Page generated in 0.11664 seconds
