Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Texo] Generator java version issue
[Texo] Generator java version issue [message #1022622] |
Fri, 22 March 2013 08:52 |
techteam Messages: 55 Registered: September 2010 |
Member |
this week I switch from my Eclipse Juno JEE SR1 to SR2
Yesterday, after some changes inside the model and xpand files I try to
generate my model again, and I've got an error about a java version issue.
After an update to the new Texo version it works.
Today, it fail's again and I have no idea why.
This is the complete error:
eclipse.buildId=M20130204-1200
java.version=1.6.0_23
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product
Error
Fri Mar 22 09:35:17 CET 2013
Unhandled event loop exception
java.lang.IllegalStateException: java.lang.reflect.InvocationTargetException
at
org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:87)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at
org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at
org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
at
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at
org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at
org.eclipse.ui.internal.progress.ProgressManager$3.run(ProgressManager.java:960)
at
org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:995)
at
org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:970)
at
org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1166)
at
org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:80)
... 29 more
Caused by: java.lang.IllegalStateException:
java.lang.IllegalStateException: package bar.foo;
* A representation of the model object '<em><b>Product</b></em>'.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public class Product
extends bar.foo.AbstractPojo
* A toString method which prints the values of all EAttributes of
this instance.
* @generated
public String toString() {
return "Product "
22: Syntax error, annotations are only available if source level is 1.5
or greater
at
org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromUri(GenerateCode.java:99)
at
org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromUris(GenerateCode.java:59)
at
org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:128)
at
org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:108)
at
org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction$1.execute(BaseGenerateAction.java:76)
at
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at
org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: java.lang.IllegalStateException: package bar.foo;
* @generated
this instance.
* @generated
return "Product "
or greater
at
org.eclipse.emf.texo.generator.ArtifactGenerator.run(ArtifactGenerator.java:145)
at
org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromUri(GenerateCode.java:96)
... 8 more
* @generated
this instance.
* @generated
return "Product "
or greater
at
org.eclipse.emf.texo.generator.ImportResolver.setSource(ImportResolver.java:494)
at
org.eclipse.emf.texo.generator.SourceMerger.organizeImports(SourceMerger.java:147)
at
org.eclipse.emf.texo.generator.SourceMerger.mergeImportAndFormat(SourceMerger.java:98)
at org.eclipse.emf.texo.generator.SourceMerger.merge(SourceMerger.java:70)
at
org.eclipse.emf.texo.generator.MergingOutputHandler.beforeWriteAndClose(MergingOutputHandler.java:63)
at org.eclipse.xpand2.output.Outlet.beforeWriteAndClose(Outlet.java:98)
at
org.eclipse.xpand2.output.FileHandleImpl.writeAndClose(FileHandleImpl.java:137)
at org.eclipse.xpand2.output.OutputImpl.closeFile(OutputImpl.java:172)
at
org.eclipse.emf.texo.generator.ArtifactGenerator.run(ArtifactGenerator.java:98)
... 9 more
Re: [Texo] Generator java version issue [message #1022639 is a reply to message #1022622] |
Fri, 22 March 2013 09:20 |
Hi Heiko,
Hmm can you check the project properties > Java Compiler there is a jdk compliance option with a setting for source
compatibility.
Let me know what it says (I hope something < 1.5, then it is easy to solve :-).
gr. Martin
On 03/22/2013 09:52 AM, Heiko wrote:
> Yesterday, after some changes inside the model and xpand files I try to generate my model again, and I've got an error
> Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product
> Error
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:87)
> at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
> at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
> at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
> at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
> at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
> at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
> at org.eclipse.ui.internal.progress.ProgressManager$3.run(ProgressManager.java:960)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:995)
> at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:970)
> at org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1166)
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:80)
> ... 29 more
> Caused by: java.lang.IllegalStateException: java.lang.IllegalStateException: package bar.foo;
> * @generated
> * A toString method which prints the values of all EAttributes of this instance.
> * @generated
> @Override
> return "Product "
> 22: Syntax error, annotations are only available if source level is 1.5 or greater
> at org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromUri(GenerateCode.java:99)
> at org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromUris(GenerateCode.java:59)
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:128)
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:108)
> at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction$1.execute(BaseGenerateAction.java:76)
> at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
> at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
> at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
> * @generated
> * @generated
> @Override
> return "Product "
> at org.eclipse.emf.texo.generator.ArtifactGenerator.run(ArtifactGenerator.java:145)
> at org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromUri(GenerateCode.java:96)
> ... 8 more
> * @generated
> * @generated
> @Override
> return "Product "
> at org.eclipse.emf.texo.generator.ImportResolver.setSource(ImportResolver.java:494)
> at org.eclipse.emf.texo.generator.SourceMerger.organizeImports(SourceMerger.java:147)
> at org.eclipse.emf.texo.generator.SourceMerger.mergeImportAndFormat(SourceMerger.java:98)
> at org.eclipse.emf.texo.generator.MergingOutputHandler.beforeWriteAndClose(MergingOutputHandler.java:63)
> at org.eclipse.xpand2.output.FileHandleImpl.writeAndClose(FileHandleImpl.java:137)
> at org.eclipse.emf.texo.generator.ArtifactGenerator.run(ArtifactGenerator.java:98)
> ... 9 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Generator java version issue [message #1022648 is a reply to message #1022639] |
Fri, 22 March 2013 09:34 |
Member |
Hi Martin,
thank for your quick answer.
No it's JDK Compliance level 1.6.
These point I also checked yesterday as first option.
Do some more tests:
old Juno SR1 with the old texo version -> works
old Juno SR1 with current texo version -> works
do this also with a very very simple model.
I seems, that the are a problem with the jdt compilation unit
Greetings
Heiko
Am 22.03.2013 10:20, schrieb Martin Taal:
> Hi Heiko,
> compliance option with a setting for source compatibility.
> solve :-).
> gr. Martin
>> Hi,
>> Error
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 29 more
>> * @generated
>> of this instance.
>> * @generated
>> @Override
>> return "Product "
>> 1.5 or greater
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> * @generated
>> of this instance.
>> * @generated
>> @Override
>> return "Product "
>> 1.5 or greater
>> at
>> at
>> ... 8 more
>> * @generated
>> of this instance.
>> * @generated
>> @Override
>> return "Product "
>> 1.5 or greater
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 9 more
Re: [Texo] Generator java version issue [message #1022653 is a reply to message #1022648] |
Fri, 22 March 2013 09:41 |
Hi Heiko,
I am on sr1 still I see now. The texo build is done against the latest juno. But still let me download sr2 and try it
also. If you have not heard back from on this thread in a few days then feel free to ping me!
gr. Martin
On 03/22/2013 10:34 AM, Heiko wrote:
> Hi Martin,
> Do some more tests:
> Greetings
> Heiko
>> Hi Heiko,
>> solve :-).
>> gr. Martin
>>> Hi,
>>> Error
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 29 more
>>> * @generated
>>> of this instance.
>>> * @generated
>>> @Override
>>> return "Product "
>>> 1.5 or greater
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> * @generated
>>> of this instance.
>>> * @generated
>>> @Override
>>> return "Product "
>>> 1.5 or greater
>>> at
>>> at
>>> ... 8 more
>>> * @generated
>>> of this instance.
>>> * @generated
>>> @Override
>>> return "Product "
>>> 1.5 or greater
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 9 more
The Netherlands
Re: [Texo] Generator java version issue [message #1022669 is a reply to message #1022653] |
Fri, 22 March 2013 10:19 |
Member |
Hi Martin,
I've found a solution:
After switch the jdk complicance to 1.5 rebuild workspace and than back
again to 1.6, it works fine.
But why I've got the error - I don't know. :/
Greetings
Heiko
Am 22.03.2013 10:41, schrieb Martin Taal:
> Hi Heiko,
> juno. But still let me download sr2 and try it also. If you have not
> gr. Martin
>> Hi Martin,
>> Do some more tests:
>> Greetings
>> Heiko
>>> Hi Heiko,
>>> solve :-).
>>> gr. Martin
>>>> Hi,
>>>> Error
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 29 more
>>>> * @generated
>>>> of this instance.
>>>> * @generated
>>>> @Override
>>>> return "Product "
>>>> 1.5 or greater
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> * @generated
>>>> of this instance.
>>>> * @generated
>>>> @Override
>>>> return "Product "
>>>> 1.5 or greater
>>>> at
>>>> at
>>>> ... 8 more
>>>> * @generated
>>>> of this instance.
>>>> * @generated
>>>> @Override
>>>> return "Product "
>>>> 1.5 or greater
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 9 more
Re: [Texo] Generator java version issue [message #1022670 is a reply to message #1022648] |
Ed Willink Messages: 7670 Registered: July 2009 |
Make sure you do a clean all and a full rebuild.
Make sure you haven't got a 1.5 JRE in use for some projects and a
1.6/1.7 for others,. When you have problems disable all but one recent
JRE and clean and rebuild and clean again.
Ed Willink
On 22/03/2013 09:34, Heiko wrote:
> Hi Martin,
> Do some more tests:
> Greetings
> Heiko
>> Hi Heiko,
>> solve :-).
>> gr. Martin
>>> Hi,
>>> Error
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 29 more
>>> * @generated
>>> of this instance.
>>> * @generated
>>> @Override
>>> return "Product "
>>> 1.5 or greater
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> * @generated
>>> of this instance.
>>> * @generated
>>> @Override
>>> return "Product "
>>> 1.5 or greater
>>> at
>>> at
>>> ... 8 more
>>> * @generated
>>> of this instance.
>>> * @generated
>>> @Override
>>> return "Product "
>>> 1.5 or greater
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 9 more
Re: [Texo] Generator java version issue [message #1384178 is a reply to message #1022669] |
Wed, 28 May 2014 10:25 |
Atang Sutisna Messages: 4 Registered: May 2014 |
I am also getting this issue with Eclipse Kepler 4.3SR2 and Texo 0.1.0.v201312121235.
Strangely, the stack trace seem to be inconsistent on some (?) invocations.
Is there a workaround?
JRE in Eclipse: java-8-oracle 1.8.0-b132
Project level: JavaSE-1.7
eclipse.buildId=4.3.2.M20140221-1700
java.version=1.8.0
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.jee.product
EMFT Texo (Incubation) 0.1.0.v201312121235 org.eclipse.emf.texo.feature.group Eclipse Modeling Project
EMFT Texo Runtime Libraries (Incubation) 0.1.0.v201312121235 org.eclipse.emf.texo.runtime.core.feature.group Eclipse Modeling Project
EMFT Texo SDK (Incubation) 0.1.0.v201312121235 org.eclipse.emf.texo.sdk.feature.group Eclipse Modeling Project
* A representation of the model object '<em><b>StorageBin</b></em>'.
* @generated
@javax.persistence.Entity(name="InventoryBalance_StorageBin")
public class StorageBin
* @generated
@javax.persistence.Basic(optional=false)
private java.lang.String id = null;
* <!-- begin-model-doc -->
* It uses GeneralInventoryStatus instead of GenericStatus in order to avoid dependency to an "shared" enum type in PostgreSQL,
so the Inventory module maintains its own Status enum type.
* <!-- end-model-doc -->
* @generated
@javax.persistence.Enumerated(javax.persistence.EnumType.STRING)
private id.co.bippo.schema.inventorybalance._1.GeneralInventoryStatus status = null;
* @generated
private java.lang.String name = null;
* @generated
@javax.persistence.ManyToOne(cascade={javax.persistence.CascadeType.MERGE,javax.persistence.CascadeType.PERSIST,javax.persistence.CascadeType.REFRESH})
private id.co.bippo.schema.inventorybalance._1.Warehouse warehouse = null;
* @generated
@javax.persistence.Basic()
private org.joda.time.DateTime creationTime = null;
* @generated
private org.joda.time.DateTime modificationTime = null;
* Returns the value of '<em><b>id</b></em>' feature.
* @return the value of '<em><b>id</b></em>' feature
* @generated
public java.lang.String getId() {
return id;
* Sets the '{@link StorageBin#getId() <em>id</em>}' feature.
* @param newId the new value of the '{@link StorageBin#getId() id}' feature.
* @generated
public void setId(java.lang.String newId) {
id = newId;
* Returns the value of '<em><b>status</b></em>' feature.
* @return the value of '<em><b>status</b></em>' feature
* @generated
public id.co.bippo.schema.inventorybalance._1.GeneralInventoryStatus getStatus() {
return status;
* Sets the '{@link StorageBin#getStatus() <em>status</em>}' feature.
* @param newStatus the new value of the '{@link StorageBin#getStatus() status}' feature.
* @generated
public void setStatus(id.co.bippo.schema.inventorybalance._1.GeneralInventoryStatus newStatus) {
status = newStatus;
* Returns the value of '<em><b>name</b></em>' feature.
* @return the value of '<em><b>name</b></em>' feature
* @generated
public java.lang.String getName() {
return name;
* Sets the '{@link StorageBin#getName() <em>name</em>}' feature.
* @param newName the new value of the '{@link StorageBin#getName() name}' feature.
* @generated
public void setName(java.lang.String newName) {
name = newName;
* Returns the value of '<em><b>warehouse</b></em>' feature.
* @return the value of '<em><b>warehouse</b></em>' feature
* @generated
public id.co.bippo.schema.inventorybalance._1.Warehouse getWarehouse() {
return warehouse;
* Sets the '{@link StorageBin#getWarehouse() <em>warehouse</em>}' feature.
* @param newWarehouse the new value of the '{@link StorageBin#getWarehouse() warehouse}' feature.
* @generated
public void setWarehouse(id.co.bippo.schema.inventorybalance._1.Warehouse newWarehouse) {
warehouse = newWarehouse;
* Returns the value of '<em><b>creationTime</b></em>' feature.
* @return the value of '<em><b>creationTime</b></em>' feature
* @generated
public org.joda.time.DateTime getCreationTime() {
return creationTime;
* Sets the '{@link StorageBin#getCreationTime() <em>creationTime</em>}' feature.
* @param newCreationTime the new value of the '{@link StorageBin#getCreationTime() creationTime}' feature.
* @generated
public void setCreationTime(org.joda.time.DateTime newCreationTime) {
creationTime = newCreationTime;
* Returns the value of '<em><b>modificationTime</b></em>' feature.
* @return the value of '<em><b>modificationTime</b></em>' feature
* @generated
public org.joda.time.DateTime getModificationTime() {
return modificationTime;
* Sets the '{@link StorageBin#getModificationTime() <em>modificationTime</em>}' feature.
* @param newModificationTime the new value of the '{@link StorageBin#getModificationTime() modificationTime}' feature.
* @generated
public void setModificationTime(org.joda.time.DateTime newModificationTime) {
modificationTime = newModificationTime;
* @generated
return "StorageBin "
+ " [id: " + getId() + "]"
+ " [status: " + getStatus() + "]"
+ " [name: " + getName() + "]"
+ " [creationTime: " + getCreationTime() + "]"
+ " [modificationTime: " + getModificationTime() + "]"
9: Syntax error, annotations are only available if source level is 1.5 or greater
20: Syntax error, annotations are only available if source level is 1.5 or greater
33: Syntax error, annotations are only available if source level is 1.5 or greater
34: Syntax error, annotations are only available if source level is 1.5 or greater
43: Syntax error, annotations are only available if source level is 1.5 or greater
52: Syntax error, annotations are only available if source level is 1.5 or greater
61: Syntax error, annotations are only available if source level is 1.5 or greater
70: Syntax error, annotations are only available if source level is 1.5 or greater
227: Syntax error, annotations are only available if source level is 1.5 or greater
at org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromModelFile(GenerateCode.java:101)
at org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromModelFiles(GenerateCode.java:60)
at org.eclipse.emf.texo.orm.annotator.GenerateModelJPACode.generateFromModelFiles(GenerateModelJPACode.java:38)
at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:127)
at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:107)
at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction$1.execute(BaseGenerateAction.java:75)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2345)
Caused by: java.lang.IllegalStateException: package id.co.bippo.schema.inventorybalance._1;
* @generated
* @generated
* @generated
* @generated
* @generated
* @generated
* @generated
* @generated
return id;
* @generated
id = newId;
* @generated
return status;
* @generated
status = newStatus;
* @generated
return name;
* @generated
name = newName;
* @generated
return warehouse;
* @generated
* @generated
* @generated
* @generated
* @generated
* @generated
at org.eclipse.emf.texo.eclipse.popup.actions.GenerateCode.generateFromModelFile(GenerateCode.java:98)
... 9 more
* @generated
* @generated
* @generated
* @generated
* @generated
* @generated
* @generated
* @generated
return id;
* @generated
id = newId;
* @generated
return status;
* @generated
status = newStatus;
* @generated
return name;
* @generated
name = newName;
* @generated
return warehouse;
* @generated
* @generated
* @generated
* @generated
* @generated
* @generated
at org.eclipse.emf.texo.generator.SourceMerger.merge(SourceMerger.java:77)
at org.eclipse.xpand2.output.OutputImpl.closeFile(OutputImpl.java:173)
... 10 more
at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:86)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1392)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3742)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3363)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:79)
... 30 more
Caused by: java.lang.IllegalStateException: java.lang.IllegalStateException: package id.co.bippo.schema.inventorybalance._1;
Re: [Texo] Generator java version issue [message #1384415 is a reply to message #1384254] |
Wed, 28 May 2014 23:52 |
This is strange, I tried it just now, I downloaded jdk8, started eclipse using this jdk, then did new java project,
select the jdk8 as the runtime environment and I get messages that the compiler compliance level of the new project is
1.4. Which should explains the error/exception message done by Texo.
Even stranger is that texo works fine also in case the compliance level is 1.4.
See the attachments, do you see the same? Does not seem to be a Texo issue though...
gr. Martin
On 28-05-14 19:50, Hendy Irawan wrote:
> We're already using Texo for JPA annotated model generation and we're planning to move from Java7 to Java8 soon.
> Is Java8 support currently planned?
The Netherlands
Current Time: Thu Sep 19 10:13:10 GMT 2024
Powered by FUDForum. Page generated in 0.07580 seconds
