Problem while connecting to the ORACLE Database [message #1022273] |
Thu, 21 March 2013 15:37 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Yuga M![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=yuga.mannava%40gmail.com) Messages: 7 Registered: October 2012 |
i installed the Oracle XE 11g release 2 and i want to use it as a database for all my test cases.
Oracle DB ---> choose "Preferences", select the "Test/Database Connections" tab and click "Add" to get the DB registration dialog. Select Oracle from the combo box and provide the necessary data for your db instance. Afterwards you can choose this connection in the "Select Database" dialog.
after following all these steps, i got exception as below.
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: No suitable driver found for jdbc:oracle:thin:@localhost:1521:SAL1
Error Code: 0
what are all the requirements do i need to follow for connecting to oracle thru jubula.
i just installed oracle and connected to database with default user name(SYSTEM) and password.
[Updated on: Fri, 22 March 2013 06:15] Report message to a moderator
FUDForum. Page generated in 0.03779 seconds
