| Create XML Data source using DE API [message #1021631] |
Wed, 20 March 2013 08:33  |
HI,
I have a requirement and I guess BIRT supports it. Explained the scenario briefly.
In ReportDesigner ( Eclipse Perspective )
1. Created a Report using ReportDesigner in Eclipse
2. Created a XML Datasource by giving XSD alone ( Not XML file )
3. Created a Data Set for the above data source
4. Dragged and dropped the Data Sets in layout.
Now i have to input a XML file to the data source which got created by giving XSD alone, through a java code.
So Is there a option to deal with DesignEngine API for this scenario???
Any help will be really appreciated..
Thanks in advance,
Vinoth
| Re: Create XML Data source using DE API [message #1029786 is a reply to message #1027606] |
Sat, 30 March 2013 02:00  |
I do not have an example of this but if your xml data source is nested in a table that contains clob xml you may be able to set the xml stream in the oncreate of the data item. As a simple example in a beforeOpen script on an xml data source you can do something like:
importPackage( Packages.java.io );
var mystr = "<?xml version=\"1.0\"?>";
mystr = mystr + "<library>";
mystr = mystr + "<book category=\"COOKING\">";
mystr = mystr + "<title lang=\"en\">The test3 Cook Book</title>";
mystr = mystr + "<author name=\"Miguel Ortiz\" country=\"es\"/>";
mystr = mystr + "<sold>10,312</sold>";
mystr = mystr + "<year>2005</year>";
mystr = mystr + "</book>";
mystr = mystr + "<book category=\"CHILDREN\">";
mystr = mystr + "<title lang=\"en\">Everyone is Super Special</title>";
mystr = mystr + "<author name=\"Sally Bush\" country=\"uk\"/>";
mystr = mystr + "<sold>8,222</sold>";
mystr = mystr + "<book category=\"AUTOBIOGRAPHY\">";
mystr = mystr + "<title lang=\"en\">Japanese Greetings</title>";
mystr = mystr + "<author name=\"Taro Yamada\" country=\"uk\"/>";
mystr = mystr + "<sold>7,852</sold>";
mystr = mystr + "<book category=\"WEB\">";
mystr = mystr + "<title lang=\"en\">Query Kick End</title>";
mystr = mystr + "<author name=\"James McGovern\" country=\"us\"/>";
mystr = mystr + "<sold>15,111</sold>";
mystr = mystr + "<year>2006</year>";
mystr = mystr + "<audio format=\"CD\" category=\"MUSIC\">";
mystr = mystr + "<title lang=\"en\">Feels Like Home</title>";
mystr = mystr + "<artist name=\"Norah Jones\" country=\"us\"/>";
mystr = mystr + "<sold>9,675</sold>";
mystr = mystr + "</audio>";
mystr = mystr +"</library>";
JavaStr = new java.lang.String( mystr );
bais = new ByteArrayInputStream( JavaStr.getBytes());
appcon = reportContext.getAppContext();
appcon.put("org.eclipse.datatools.enablement.oda.xml.inputStream", bais);
In your case you would read the value in the oncreate of the data item containing the clob and then then nested dataset should pickup the new inputStream for each row.
FUDForum. Page generated in 0.04014 seconds
