Home » Modeling » OCL » Complete OCL file used for GMF validation
Re: Complete OCL file used for GMF validation [message #1265840 is a reply to message #1265754] |
Thu, 06 March 2014 16:24 |
Klaas Gadeyne Messages: 165 Registered: July 2009 |
Hi Ed,
Ed Willink wrote on Thu, 06 March 2014 09:06Hi
There should be no change in Kepler SR2.
Indeed, if I revert my OCL examples and editors to the Kepler versions.
OCL Examples and Editors 3.3.2.v20140210-1137 org.eclipse.ocl.examples.feature.group Eclipse Modeling Project
I can run the command both in the standard EMF editor and the GMF editor.
For Luna, as a minor contribution to Eclipse IDE integrity, I have been
moving all OCL contributions in communal contexts to OCL->, so Load
Complete OCL Resource is now OCL->Load Resource. Hopefully other
projects will behave similarly so we are not left wondering where on
earth the "Exexcute Transformation" option came from and what it does.
This works fine for the basic EMF editor, however, the "OCL -> Load Resource" menu is not available (anymore) using
OCL Examples and Editors SDK 3.4.0.v20140303-1745 org.eclipse.ocl.examples.feature.group Eclipse Modeling Project
in the GMF editor (running on top kepler SR2, that is). You mean this this would only work using a full Luna installation?
Klaas
Re: Complete OCL file used for GMF validation [message #1265895 is a reply to message #1265840] |
Thu, 06 March 2014 18:02 |
Ed Willink Messages: 7655 Registered: July 2009 |
HI
I have also tried to avoid poking irrelevant menu actions into all
possible views and then using a can-i-find-a-ResourceSet expression
filter by instead using only known editor names. Maybe I need to know
some more or give up trying to avoid wasting UI resources.
Ed Willink
On 06/03/2014 16:24, Klaas Gadeyne wrote:
> Hi Ed,
>> Hi
> Quote:
>> been moving all OCL contributions in communal contexts to OCL->, so
>> Load Complete OCL Resource is now OCL->Load Resource. Hopefully other
> Regards,
> Klaas
Re: Complete OCL file used for GMF validation [message #1268186 is a reply to message #1265840] |
Mon, 10 March 2014 06:54 |
The latest OCL I-build has the OCL-> menu available (again) for all
editors. (M6 is today so maybe you can wait).
Ed
> Hi Ed,
>> Hi
> Quote:
> Regards,
> Klaas
Current Time: Fri Apr 26 17:25:31 GMT 2024
Powered by FUDForum. Page generated in 0.03325 seconds
