Home » Modeling » Papyrus » What happened to auto-profile update?
What happened to auto-profile update? [message #1021059] Tue, 19 March 2013 08:58 Go to next message
I'm using the 15-March 0.10 N-build.
My recollection was that when you edited a diagram whose profile had
changed you got a pop-up notifying you and helping you to update.
This doesn't seem to happen any more.
I seem to need to use the UML Model Editor to make progress.
Any clues?
Ed Willink
Re: What happened to auto-profile update? [message #1021061 is a reply to message #1021059] Tue, 19 March 2013 09:01 Go to previous messageGo to next message
Hi Ed,
This shouldn't have changed. I will check that.
Camille
Re: What happened to auto-profile update? [message #1021066 is a reply to message #1021061] Tue, 19 March 2013 09:12 Go to previous messageGo to next message
Ed,
I have the expected behavior in the latest build. The dialog pops up when the profile has been redefined. If you don't want to update again now, you can also use the "Refresh" button in the profile tab, which re-applies the selected profile(s).
With M6 approaching, the current nightly builds can be really unstable, depending on what components you update. We have noticed non-trivial changes in Junit, EMF and CDO.
Camille
Re: What happened to auto-profile update? [message #1021159 is a reply to message #1021066] Tue, 19 March 2013 11:25 Go to previous messageGo to next message
It seems no different in the 19-March 0.10 N-build. (I'm using an M6(a)
EMF).
The pop-up appears when saving the profile but niot when loading its
coinsumer.
The Refresh icon is greyed out, but the profile can be manually applied
(again).
Ed
On 19/03/2013 13:12, Camille Letavernier wrote:
> Ed,
> Camille
Re: What happened to auto-profile update? [message #1021309 is a reply to message #1021159] Tue, 19 March 2013 17:13 Go to previous message
Ed,
The dialog appears when the profile has been reapplied and reloaded (i.e. you have to reopen the diagram on which the profile is applied for the dialog to open).
If the dialog doesn't appear and the refresh button is disabled, then the profile definition has not changed. Maybe the profile definition actually failed when you defined the profile?
I'm also using the latest M6 builds (Actually, the ones published in releases/staging, which means at least one aggregation build needs to run before I can update), and the Papyrus nightly builds. I will check that properly tomorrow, when building Papyrus M6.
Camille
Previous Topic:papyrus 09 activity diagram
Next Topic:Cannot delete Composite Structure Diagram from model
Current Time: Fri Nov 07 15:03:45 EST 2025
Powered by FUDForum. Page generated in 0.03503 seconds
