| @XmlInverseReference with interface field [message #1020523] | Mon, 18 March 2013 07:17  |  |
| Eclipse User  |  |  |  |  | Hello,
 I was wondering if the @XmlInverseReference also works on entities with fields that refer to an interface since the @XmlElement gives an instantiation error for those types of fields.
 I am using MOXy with Spring and follow the instructions here  http://wiki.eclipse.org/EclipseLink/Examples/MOXy/Spring/JAXBAnnotation. I have for example a Sensor class that has a SensorReading field, which is an interface.
@XmlRootElement
@XmlAccessorType(XmlAccessType.FIELD)
@Entity
@Table(name = "sensor")
@PrimaryKeyJoinColumn(name = "sensor_id")
public class Sensor extends LowLevelEntity implements Serializable
	@XmlInverseReference(mappedBy = "sensor")
	@OneToOne(targetEntity = ConcreteSensorReading.class, cascade = CascadeType.ALL,
			fetch = FetchType.EAGER, orphanRemoval = true)
	@JoinColumn(name = "concrete_sensor_reading_id")
	protected SensorReading sensorReading;
// getters and setters
 The ConcreteSensorReading class is an implementatition of the SensorReading interface
@XmlRootElement
@Entity
@Table(name = "concrete_sensor_reading")
public class ConcreteSensorReading implements SensorReading
	@XmlID
	@Id
	@GeneratedValue(strategy = GenerationType.IDENTITY)
	@Column(name = "concrete_sensor_reading_id")
	private long uuid;
	@XmlInverseReference(mappedBy = "sensorReading")
	@XmlElement
	@OneToOne(mappedBy = "sensorReading", fetch = FetchType.EAGER )
	protected Sensor sensor;
The SensorReading interface is annotated like so
@XmlRootElement
@XmlSeeAlso(ConcreteSensorReading.class)
public interface SensorReading
	public Sensor getSensor();
	public void setSensor(Sensor sensor);
 Using this configuration I get no errors but the ConcreteSensorReading is not mapped to the xml when I marshall the Sensor object using the XmlHelper save method. Is there a correct way of doing this? I'm very new to MOXy and I might not have understood how this must be done. Thank you for your help.
FUDForum. Page generated in 0.27509 seconds
