Terminal not accessing .png files from Eclipse Project [message #1020324] |
Sun, 17 March 2013 23:14 |
David Taylor Messages: 1 Registered: March 2013 |
The project runs fine in Eclipse, but when I try to take the files and run it through Terminal, it seems like it is not accessing the .png files. I don't know what to do.
Here is my main class:
import javax.swing.*;
import java.awt.*;
public class Frame extends JFrame {
public static String title = "Tower Defense Alpha";
public static Dimension size = new Dimension(700, 550);
public Frame() {
setTitle(title);
setSize(size);
setResizable(false);
setLocationRelativeTo(null);
setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
init();
public void init(){
setLayout(new GridLayout(1,1,0,0));
Screen screen = new Screen(this);
add(screen);
setVisible(true);
public static void main(String args[]){
Frame frame = new Frame();
Here is how I am accessing the .png files in Eclipse, which isn't working in Terminal:
for (int i=0; i<tileset_ground.length; i++) {
tileset_ground[i] = new ImageIcon("res/tileset_ground.png").getImage();
tileset_ground[i] = createImage(new FilteredImageSource(tileset_ground[i].getSource(),
new CropImageFilter(0, 26*i, 26, 26)));
Re: Terminal not accessing .png files from Eclipse Project [message #1020759 is a reply to message #1020324] |
Mon, 18 March 2013 21:49 |
Heiner Westphal Messages: 18 Registered: July 2009 |
Hello David,
I cannot quite imagine your setup.
What kind of terminal are you running?
XTerm on an X server? PuTTy or some other ssh client?
Or is it a local terminal on a linux box, or on Windows?
And I cannot see if this is related to TPTP in any way.
Could you shed some more light on this?
Heiner
Am 18.03.2013 19:18, schrieb David Taylor:
> import java.awt.*;
> public Frame() {
> setTitle(title);
> setSize(size);
> init();
> public void init(){
> add(screen);
> setVisible(true);
> 26*i, 26, 26)));
FUDForum. Page generated in 0.03274 seconds
