Syntax Color Comment Blocks Inside Comment [message #1019365] |
Fri, 15 March 2013 14:49 |
Patrick Vane Messages: 6 Registered: February 2013 |
I am making a plugin voor UnrealScript and I found out that in UnrealScript you can have comment blocks inside comment blocks.
In other words, the amount of
have to match the
in order to close a block.
Example:
also inside comment block
still inside comment block
outside comment blocks
My question is, how do you do this with Eclipse?
I am currently using this, but it doesn't work (it ignores comment block openings when inside a comment block, so the first comment block ending will end every comment block):
import java.util.ArrayList;
import org.eclipse.jface.text.rules.EndOfLineRule;
import org.eclipse.jface.text.rules.ICharacterScanner;
import org.eclipse.jface.text.rules.IPredicateRule;
import org.eclipse.jface.text.rules.IToken;
import org.eclipse.jface.text.rules.IWordDetector;
import org.eclipse.jface.text.rules.MultiLineRule;
import org.eclipse.jface.text.rules.RuleBasedPartitionScanner;
import org.eclipse.jface.text.rules.SingleLineRule;
import org.eclipse.jface.text.rules.Token;
import org.eclipse.jface.text.rules.WordRule;
import com.patrick_vane.unrealscript.editor.constants.TagConstant;
public class PartitionScanner extends RuleBasedPartitionScanner
private IToken commentLine = new Token( TagConstant.COMMENT_LINE );
private IToken commentBlock = new Token( TagConstant.COMMENT_BLOCK );
private IToken docsBlock = new Token( TagConstant.DOCS );
private IToken string = new Token( TagConstant.STRING );
public int commentBlockCount = 0;
public PartitionScanner()
ArrayList<IPredicateRule> rules = new ArrayList<IPredicateRule>();
rules.add( new EndOfLineRule("//", commentLine) );
rules.add( new SingleLineRule("\"", "\"", string, '\\') );
rules.add( new SingleLineRule("'", "'", string, '\\') );
rules.add( new EmptyCommentRule(commentBlock) );
rules.add( new MultiLineRule("/**", "*/", docsBlock, (char)0, true) );
rules.add( new MultiLineRule("/*", "*/", commentBlock, (char)0, true) );
setPredicateRules( rules.toArray(new IPredicateRule[0]) );
private static class EmptyCommentRule extends WordRule implements IPredicateRule
private IToken successToken;
public EmptyCommentRule( IToken successToken )
super
new IWordDetector()
public boolean isWordStart( char c )
return (c == '/');
public boolean isWordPart( char c )
return ((c == '*') || (c == '/'));
this.successToken = successToken;
addWord( "/**/", successToken );
public IToken evaluate( ICharacterScanner scanner, boolean resume )
return super.evaluate( scanner );
public IToken getSuccessToken()
return successToken;
FUDForum. Page generated in 0.03953 seconds
