SWT Problem [message #1019325] |
Fri, 15 March 2013 12:54 |
gold spm Messages: 1 Registered: March 2013 |
Hello everyone. I want to learn Java and i am new to eclipse.
Hi just did this "hello world" application.
when i say "run as java programm" the problem gives me the "hello world"-text.
when i return to eclipse it gives me an error every time i click into the center window.
Error is this :
eclipse.buildId=M20130204-1200
java.version=1.7.0_17
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
Error
Fri Mar 15 12:52:43 CET 2013
Unhandled event loop exception
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4387)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.SWT.error(SWT.java:4247)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.Control.createHandle(Control.java:704)
at org.eclipse.swt.widgets.Label.createHandle(Label.java:199)
at org.eclipse.swt.widgets.Control.createWidget(Control.java:744)
at org.eclipse.swt.widgets.Control.<init>(Control.java:112)
at org.eclipse.swt.widgets.Label.<init>(Label.java:101)
at org.eclipse.ui.texteditor.StatusLineContributionItem.fill(StatusLineContributionItem.java:182)
at org.eclipse.jface.action.SubContributionItem.fill(SubContributionItem.java:59)
at org.eclipse.jface.action.StatusLineManager.update(StatusLineManager.java:327)
at org.eclipse.ui.internal.WorkbenchPage.updateActivations(WorkbenchPage.java:265)
at org.eclipse.ui.internal.WorkbenchPage.access$15(WorkbenchPage.java:243)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:172)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$2.run(PartServiceImpl.java:193)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:191)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:596)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:549)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:105)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:61)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1447)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2328)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4572)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4989)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2541)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3129)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3753)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
FUDForum. Page generated in 0.13016 seconds
