Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Resolve][Teneo] - Howto copy EMF model from one database to another one
[Resolve][Teneo] - Howto copy EMF model from one database to another one [message #1019264] |
Fri, 15 March 2013 10:39 |
Philippe EUGENE Messages: 58 Registered: January 2011 |
Member |
I try to explain my problem.
Use Case:
Copy and share EMF model, persist with Teneo in derby database, between multi-users. And after re-import and merge datas.
Constraints:
Could not use a CDO server to share model througth the network.
Solution:
Adding teneo annotations to the EMF model to generate a primary key and use a UUID strategy to generate ID. The goal of this strategy is to limit the risk of colision between ID.
The Problem:
- I copy the root element of my EMF model => all ID are well copied.
- I save the root element to the new DB. The save action change all ID.
I think my way to proceed is bad. I use an hibernate Session.
Using an hibernate session not work.
The object don't exist in the new database and then Hibernate change all id.
This is the contract of the Hibernate Session (save, saveOrUpdate and so on).
There is an other way to do that with Teneo ?
// Here i initialize a new HbDataStore
// uri: the uri of the new database (derby)
// datastoreName: a new name for this datastore.
// There is a first datastore register with an other name in my application.
HbDataStore datastore = init(uri, dataStorename);
// After i proceed with an hibernate session
final SessionFactory sessionFactory = datastore.getSessionFactory();
// Open a new Session and start transaction.
final Session session = sessionFactory.openSession();
session.beginTransaction();
// Copy the the root element of my EMF model.
// here all ID of the copy are good.
Root copy = EcoreUtil.copy(root);
... do some stuff with the copy => remove some datas ...
// call the save or update
session.saveOrUpdate(copy);
// here all the ID in the new databases will be changed by hibernate.
// I try: save, saveOrUpdate and persist the behavior is the same.
Thanks for help and reply,
Philippe
[Updated on: Fri, 15 March 2013 13:08] Report message to a moderator
Re: [Teneo] - Howto copy EMF model from one database to another one [message #1019308 is a reply to message #1019264] |
Fri, 15 March 2013 12:16 |
Hi Philippe,
Yes that the id changes is standard behavior from hibernate. To solve this, create a UUID generator class (see below).
Then add this annotation to the id efeature:
@GeneratedValue(generator="MyIDGenerator")
and this one to the epackage:
@GenericGenerator(name="MyIDGenerator", strategy="class.MyUUIDGenerator")
(where class.MyUUIDGenerator is the custom uuid generator)
public class MyUUIDGenerator extends UUIDGenerator {
public Serializable generate(SessionImplementor session, Object obj) throws HibernateException {
// get the id from the object, if it is there (not null)
// then return this id
// otherwise do:
return super.generate(session, obj);
gr. Martin
On 03/15/2013 11:39 AM, peugene Mising name wrote:
> Use Case: Copy and share EMF model, persist with Teneo in derby database, between multi-users. And after re-import and
> merge datas.
> Constraints: Could not use a CDO server to share model througth the network.
> Solution:
> The Problem:
> I think my way to proceed is bad. I use an hibernate Session. Using an hibernate session not work.
> Philippe
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] - Howto copy EMF model from one database to another one [message #1037316 is a reply to message #1019308] |
Tue, 09 April 2013 12:08 |
J. Michael Dean, M.D. Messages: 218 Registered: July 2009 |
On 3/15/13 6:16 AM, Martin Taal wrote:
> Hi Philippe,
> this, create a UUID generator class (see below). Then add this
> @Override
> // otherwise do:
> gr. Martin
>> Hi,
>> merge datas.
>> network.
>> Solution:
>> The Problem:
>> all id.
>> so on).
>> application.
>> Philippe
I am trying to move an old Hibernate project into EMF and have a related
issue. The original code includes the following snippets:
@MappedSuperclass
@org.hibernate.annotations.GenericGenerator(name="hibernate-uuid",
strategy = "uuid")
public class BaseEntity implements Identifiable {
private String id;
private int version;
protected Boolean valid = true;
public BaseEntity() {
this.valid = true;
@Id
@GeneratedValue(generator="hibernate-uuid")
public String getId() {
return id;
@Entity
strategy = "uuid")
public class Patient extends ModelObject{
etc.
I am unclear how these annotations should be added to an eCore model in
which I am allowing EMF to automatically generate the e_id, etc. for
different objects. The name and strategy that I have shown above
results in errors that they are not recognized.
Unfortunately my knowledge of EMF is struggling up the steep part of the
learning curve; I interpret your advice to Phillipe to mean to hand
edit the generated code, but I am interested in getting as much as
possible into the eCore model itself.
Thanks for thinking about this.
- Mike
Re: [Teneo] - Howto copy EMF model from one database to another one [message #1037384 is a reply to message #1037316] |
Tue, 09 April 2013 13:39 |
Hi Mike,
No my proposal was not to change the generated code. It was all adding annotations to ecore.
The GenericGenerator annotation can be be added to the epackage using an eannotation there. For the @Id and
@GeneratedValue annotations these can be added/set in the eattribute, the @MappedSuperclass can be set on the EClass.
The @Entity annotation is not needed, teneo will generate it.
I am sure that you found the wiki documents on setting annotations in ecore:
http://wiki.eclipse.org/Teneo/Hibernate#Model_Relational_Mapping_with_EJB3.2FJPA_Annotations
And on another approach, if you like to have your annotations in the java code you can also try the texo project which
tries to combine the best of both worlds, EMF and standard java/JPA:
http://wiki.eclipse.org/Texo
gr. Martin
>> Hi Philippe,
>> @Override
>> // otherwise do:
>> gr. Martin
>>> Hi,
>>> merge datas.
>>> network.
>>> Solution:
>>> The Problem:
>>> all id.
>>> so on).
>>> application.
>>> Philippe
> I am trying to move an old Hibernate project into EMF and have a related issue. The original code includes the
> following snippets:
> @MappedSuperclass
> @org.hibernate.annotations.GenericGenerator(name="hibernate-uuid", strategy = "uuid")
> private String id;
> this.valid = true;
> @Id
> return id;
> @Entity
> etc.
> I am unclear how these annotations should be added to an eCore model in which I am allowing EMF to automatically
> generate the e_id, etc. for different objects. The name and strategy that I have shown above results in errors that
> Unfortunately my knowledge of EMF is struggling up the steep part of the learning curve; I interpret your advice to
> Phillipe to mean to hand edit the generated code, but I am interested in getting as much as possible into the eCore
> model itself.
> - Mike
The Netherlands
Re: [Teneo] - Howto copy EMF model from one database to another one [message #1039120 is a reply to message #1037384] |
Thu, 11 April 2013 19:43 |
On 4/9/13 7:39 AM, Martin Taal wrote:
> Hi Mike,
> eannotation there. For the @Id and @GeneratedValue annotations these can
> EClass. The @Entity annotation is not needed, teneo will generate it.
> ecore:
> java code you can also try the texo project which tries to combine the
> gr. Martin
>> following snippets:
>> @MappedSuperclass
>> strategy = "uuid")
>> private String id;
>> this.valid = true;
>> @Id
>> return id;
>> @Entity
>> strategy = "uuid")
>> etc.
>> model itself.
>> - Mike
Thanks for your response. I think I have annotated things correctly,
but the generated classes do not have annotations in the implementation
files, and the interface files don't seem right. I am undoubtedly doing
something ridiculous. When the code is generated and I exercise it with
an adaptation of your Quickstart.java tutorial application, the
hibernate mapping file is generated but does not indicate anything about
a uuid generator, etc. I also receive an exception that ids for this
class must be manually assigned before calling save() - this error
occurs when the hibernate session is committed.
My model is actually simple, so I am attaching it to this post, hoping
you might see something obviously wrong. The only place I have an ID is
in the Person class that is at the top; I have indicated the annotation
source as teneo.jpa, and called the key "body" and the value the text of
the annotation. I have also attached the console output and the
Quickstart.java code.
I understand if you do not have time to open the model, but again if you
get a chance, I appreciate your help!
- Mike
Apr 11, 2013 1:09:21 PM org.eclipse.emf.teneo.hibernate.HbHelper createRegisterDataStore
INFO: Creating emf data store and registering it under name: Glucose
INFO: Returning created emf data store, initialize this newly created data store!
Apr 11, 2013 1:09:21 PM org.eclipse.emf.teneo.classloader.ClassLoaderResolver setClassLoaderStrategy
INFO: Class loader strategy set to: org.eclipse.emf.teneo.classloader.ContextClassLoaderStrategy
Apr 11, 2013 1:09:22 PM org.hibernate.annotations.common.Version <clinit>
INFO: HCANN000001: Hibernate Commons Annotations {4.0.1.Final}
Apr 11, 2013 1:09:22 PM org.hibernate.Version logVersion
INFO: HHH000412: Hibernate Core {4.1.1}
Apr 11, 2013 1:09:22 PM org.hibernate.cfg.Environment <clinit>
INFO: HHH000206: hibernate.properties not found
Apr 11, 2013 1:09:22 PM org.hibernate.cfg.Environment buildBytecodeProvider
INFO: HHH000021: Bytecode provider name : javassist
Apr 11, 2013 1:09:22 PM org.hibernate.internal.util.xml.DTDEntityResolver resolveEntity
WARN: HHH000223: Recognized obsolete hibernate namespace http://hibernate.sourceforge.net/. Use namespace http://www.hibernate.org/dtd/ instead. Refer to Hibernate 3.6 Migration Guide!
Apr 11, 2013 1:09:22 PM org.eclipse.emf.teneo.hibernate.HbDataStore setDefaultProperties
INFO: Hibernate property: hibernate.hbm2ddl.auto not set, setting to update
Apr 11, 2013 1:09:22 PM org.eclipse.emf.teneo.hibernate.HbDataStore logProperties
INFO: hibernate.connection.url: jdbc:mysql://127.0.0.1:3306/glucose
INFO: teneo.mapping.default_varchar_length: -1
INFO: teneo.mapping.set_default_cascade_on_non_containment:
INFO: teneo.naming.default_id_feature: e_id
INFO: teneo.naming.auditing.jointable.postfix: Auditing
INFO: teneo.mapping.auditing.prune.commit.interval: 1000
INFO: teneo.mapping.cascade_policy_on_non_containment: REFRESH,PERSIST,MERGE
INFO: teneo.mapping.always_version: true
INFO: e_container_column: e_container
INFO: teneo.mapping.fetch_one_to_many_extra_lazy: false
INFO: teneo.naming.sql_discriminator_version_immutable_eclass: true
INFO: teneo.runtime.update_schema: false
INFO: teneo.runtime.handle_unset_as_null: false
INFO: teneo.naming.version_column: e_version
INFO: teneo.mapping.set_proxy: false
INFO: teneo.naming.discriminator_column_name: DTYPE
INFO: teneo.mapping.auditing.enable: false
INFO: teneo.mapping.disable_econtainer: false
INFO: teneo.naming.sql_column_name_prefix:
INFO: teneo.naming.auto_adapt_manual_set_sql_names: true
INFO: teneo.mapping.set_entity_automatically: true
INFO: teneo.naming.join_column_naming_strategy: unique
INFO: teneo.naming.set_foreign_key_name: true
INFO: teneo.naming.set_generated_value_on_id_feature: true
INFO: teneo.mapping.auditing.prune.days: 0
INFO: teneo.mapping.emap_as_true_map: true
INFO: teneo.naming.id_feature_as_primary_key: true
INFO: e_container_feature_name_column: e_container_feature_name
INFO: hibernate.connection.password: root
INFO: teneo.mapping.UserTimeType: org.eclipse.emf.teneo.hibernate.mapping.XSDDateTime
INFO: teneo.mapping.UserDateTimeType: org.eclipse.emf.teneo.hibernate.mapping.XSDDateTime
INFO: teneo.mapping.hibernate_mapping_file: false
INFO: teneo.mapping.UserDateType: org.eclipse.emf.teneo.hibernate.mapping.XSDDate
INFO: teneo.mapping.add_index_for_fk: false
INFO: teneo.mapping.map_all_lists_as_idbag: false
INFO: hibernate.connection.username: root
INFO: teneo.naming.idbag_id_column_name: ID
INFO: teneo.mapping.ignore_eannotations: false
INFO: teneo.naming.econtainer_feature_persistence_strategy: FEATURENAME
INFO: teneo.naming.strategy: lowercase
INFO: teneo.naming.join_table_naming_strategy: unique
INFO: hibernate.hbm2ddl.auto: update
INFO: teneo.mapping.XSDDateClass: javax.xml.datatype.XMLGregorianCalendar
INFO: teneo.naming.sql_index_name_prefix:
INFO: teneo.mapping.extra_annotation_sources:
INFO: hibernate.connection.driver_class: com.mysql.jdbc.Driver
INFO: teneo.naming.sql_fk_name_prefix:
INFO: hibernate.dialect: org.hibernate.dialect.MySQL5InnoDBDialect
INFO: teneo.mapping.map_document_root: false
INFO: teneo.mapping.max_comment_length: 0
INFO: teneo.naming.max_sql_name_length: -1
INFO: teneo.naming.default_id_column: e_id
INFO: teneo.mapping.always_map_list_as_bag: false
INFO: teneo.mapping.force_lazy: false
INFO: teneo.mapping.also_map_as_class: true
INFO: teneo.mapping.default_temporal: TIMESTAMP
INFO: teneo.naming.auditing.entity.prefix:
INFO: econtainer_class_column: econtainer_class
INFO: teneo.mapping.persistence_xml.parse.lenient: false
INFO: teneo.mapping.fetch_containment_eagerly: false
INFO: teneo.mapping.map_embeddable_as_embedded: false
INFO: teneo.mapping.sql_name_escape_character: `
INFO: teneo.mapping.eav_mapping: false
INFO: teneo.mapping.optimistic_locking: true
INFO: teneo.mapping.cascade_all_on_containment:
INFO: teneo.naming.sql_table_name_prefix:
INFO: teneo.runtime.convert_unset_to_null: false
INFO: teneo.mapping.cascade_policy_on_containment: ALL
INFO: teneo.mapping.default_cache_strategy: NONE
INFO: teneo.mapping.auditing.database.schema:
INFO: teneo.mapping.featuremap_as_component: false
INFO: teneo.naming.auditing.entity.postfix: Auditing
INFO: teneo.mapping.join_table_for_non_contained_associations: true
INFO: teneo.mapping.auto_add_referenced_epackages: false
Apr 11, 2013 1:09:22 PM org.hibernate.service.jdbc.connections.internal.DriverManagerConnectionProviderImpl configure
INFO: HHH000402: Using Hibernate built-in connection pool (not for production use!)
INFO: HHH000115: Hibernate connection pool size: 20
INFO: HHH000006: Autocommit mode: false
INFO: HHH000401: using driver [com.mysql.jdbc.Driver] at URL [jdbc:mysql://127.0.0.1:3306/glucose]
INFO: HHH000046: Connection properties: {user=root, password=****}
Apr 11, 2013 1:09:22 PM org.hibernate.dialect.Dialect <init>
INFO: HHH000400: Using dialect: org.hibernate.dialect.MySQL5InnoDBDialect
Apr 11, 2013 1:09:22 PM org.hibernate.engine.jdbc.internal.LobCreatorBuilder useContextualLobCreation
INFO: HHH000423: Disabling contextual LOB creation as JDBC driver reported JDBC version [3] less than 4
Apr 11, 2013 1:09:22 PM org.hibernate.engine.transaction.internal.TransactionFactoryInitiator initiateService
INFO: HHH000399: Using default transaction strategy (direct JDBC transactions)
Apr 11, 2013 1:09:22 PM org.hibernate.hql.internal.ast.ASTQueryTranslatorFactory <init>
INFO: HHH000397: Using ASTQueryTranslatorFactory
Apr 11, 2013 1:09:22 PM org.hibernate.tool.hbm2ddl.SchemaUpdate execute
INFO: HHH000228: Running hbm2ddl schema update
INFO: HHH000102: Fetching database metadata
INFO: HHH000396: Updating schema
Apr 11, 2013 1:09:22 PM org.hibernate.tool.hbm2ddl.DatabaseMetadata getTableMetadata
INFO: HHH000262: Table not found: clinicaldecision
INFO: HHH000262: Table not found: intensivecareunit
INFO: HHH000262: Table not found: person
INFO: HHH000232: Schema update complete
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD 3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<hibernate-mapping auto-import="false">
<class name="glucose.impl.PersonImpl" entity-name="Person" abstract="false" lazy="false" discriminator-value="Person" table="`person`">
<meta attribute="eclassName" inherit="false">Person</meta>
<meta attribute="epackage" inherit="false">http://edu/utah/cdmcc/glucose</meta>
<id name="personID" type="java.lang.String">
<column not-null="true" unique="false" name="`personid`"/>
</id>
<discriminator type="string">
<column name="`dtype`" index="persondtype" length="255" not-null="true"/>
</discriminator>
<version name="e_version" column="e_version" access="org.eclipse.emf.teneo.hibernate.mapping.property.VersionPropertyHandler">
<meta attribute="syntheticVersion" inherit="false">true</meta>
</version>
<property name="lastName" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`lastname`"/>
</property>
<property name="firstName" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`firstname`"/>
</property>
</class>
<subclass name="glucose.impl.PatientImpl" entity-name="Patient" abstract="false" lazy="false" extends="Person" discriminator-value="Patient">
<meta attribute="eclassName" inherit="false">Patient</meta>
<property name="weight" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Double">
<column not-null="false" unique="false" name="`weight`"/>
</property>
<property name="medRecNum" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`medrecnum`"/>
</property>
<property name="studyID" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`studyid`"/>
</property>
<property name="birthdate" lazy="false" insert="true" update="true" not-null="false" unique="false" type="calendar">
<column not-null="false" unique="false" name="`birthdate`"/>
</property>
<property name="height" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Double">
<column not-null="false" unique="false" name="`height`"/>
</property>
<property name="status" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`status`"/>
<type name="org.eclipse.emf.teneo.hibernate.mapping.ENumUserType">
<param name="enumClass">glucose.StatusType</param>
<param name="eclassifier">StatusType</param>
<param name="epackage">http://edu/utah/cdmcc/glucose</param>
</type>
</property>
<list name="decisions" lazy="true" cascade="all,delete-orphan">
<key foreign-key="patient_decisions_key" update="true">
<column name="`patient_decisions_personid`" unique="false"/>
</key>
<list-index column="`patient_decisions_idx`"/>
<one-to-many entity-name="GlucoseDecision"/>
</list>
<many-to-one name="createdBy" entity-name="User" lazy="false" cascade="merge,persist,save-update,lock,refresh" foreign-key="patient_createdby" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`user_createdby_personid`"/>
</many-to-one>
</subclass>
<subclass name="glucose.impl.UserImpl" entity-name="User" abstract="false" lazy="false" extends="Person" discriminator-value="User">
<meta attribute="eclassName" inherit="false">User</meta>
<property name="accountRights" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`accountrights`"/>
<param name="enumClass">glucose.AccessType</param>
<param name="eclassifier">AccessType</param>
</type>
</property>
<property name="accountName" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`accountname`"/>
</property>
<property name="passwordDigest" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`passworddigest`"/>
</property>
<many-to-one name="createdBy" entity-name="User" lazy="false" cascade="merge,persist,save-update,lock,refresh" foreign-key="user_createdby" insert="true" update="true" not-null="false">
</many-to-one>
</subclass>
<class name="glucose.impl.ClinicalDecisionImpl" entity-name="ClinicalDecision" abstract="false" lazy="false" discriminator-value="ClinicalDecision" table="`clinicaldecision`">
<meta attribute="eclassName" inherit="false">ClinicalDecision</meta>
<id type="long" name="e_id" column="e_id" access="org.eclipse.emf.teneo.hibernate.mapping.identifier.IdentifierPropertyHandler">
<meta attribute="syntheticId" inherit="false">true</meta>
<generator class="native"/>
</id>
<column name="`dtype`" index="clinicaldecisiondtype" length="255" not-null="true"/>
</discriminator>
</version>
<property name="decisionTimeStamp" lazy="false" insert="true" update="true" not-null="false" unique="false" type="calendar">
<column not-null="false" unique="false" name="`decisiontimestamp`"/>
</property>
<property name="observationDate" lazy="false" insert="true" update="true" not-null="false" unique="false" type="calendar">
<column not-null="false" unique="false" name="`observationdate`"/>
</property>
<property name="patientWeight" lazy="false" insert="true" update="true" not-null="false" unique="false" type="double">
<column not-null="false" unique="false" name="`patientweight`"/>
</property>
<property name="patientHeight" lazy="false" insert="true" update="true" not-null="false" unique="false" type="double">
<column not-null="false" unique="false" name="`patientheight`"/>
</property>
<property name="patientAgeDays" lazy="false" insert="true" update="true" not-null="false" unique="false" type="int">
<column not-null="false" unique="false" name="`patientagedays`"/>
</property>
<property name="adviceText" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`advicetext`"/>
</property>
<property name="rulesFiredText" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`rulesfiredtext`"/>
</property>
<property name="rationaleText" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`rationaletext`"/>
</property>
<property name="declineComment" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`declinecomment`"/>
</property>
<property name="acceptComment" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`acceptcomment`"/>
</property>
<property name="otherComment" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`othercomment`"/>
</property>
<property name="userAction" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`useraction`"/>
<param name="enumClass">glucose.UserActionType</param>
<param name="eclassifier">UserActionType</param>
</type>
</property>
<property name="minutesToNextEvaluation" lazy="false" insert="true" update="true" not-null="false" unique="false" type="int">
<column not-null="false" unique="false" name="`minutestonextevaluation`"/>
</property>
<many-to-one name="createdBy" entity-name="User" lazy="false" cascade="merge,persist,save-update,lock,refresh" foreign-key="clinicaldecision_createdby" insert="true" update="true" not-null="false">
</many-to-one>
</class>
<subclass name="glucose.impl.GlucoseDecisionImpl" entity-name="GlucoseDecision" abstract="false" lazy="false" extends="ClinicalDecision" discriminator-value="GlucoseDecision">
<meta attribute="eclassName" inherit="false">GlucoseDecision</meta>
<property name="previousGlucoseConcentration" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Integer">
<column not-null="false" unique="false" name="`previousglucoseconcentration`"/>
</property>
<property name="previousObservationTime" lazy="false" insert="true" update="true" not-null="false" unique="false" type="calendar">
<column not-null="false" unique="false" name="`previousobservationtime`"/>
</property>
<property name="serumGlucoseConcentration" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Integer">
<column not-null="false" unique="false" name="`serumglucoseconcentration`"/>
</property>
<property name="currentInsulinDripRate" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Double">
<column not-null="false" unique="false" name="`currentinsulindriprate`"/>
</property>
<property name="carbohydrateStatus" lazy="false" not-null="false" insert="true" update="true" unique="false">
<column not-null="false" unique="false" name="`carbohydratestatus`"/>
<param name="enumClass">glucose.CarbohydrateStatusType</param>
<param name="eclassifier">CarbohydrateStatusType</param>
</type>
</property>
<property name="recommendedInsulinDripRate" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Double">
<column not-null="false" unique="false" name="`recommendedinsulindriprate`"/>
</property>
<property name="recommendedInsulinBolus" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Double">
<column not-null="false" unique="false" name="`recommendedinsulinbolus`"/>
</property>
<property name="recommendedGlucoseBolus" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.Double">
<column not-null="false" unique="false" name="`recommendedglucosebolus`"/>
</property>
<property name="insulinMode" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`insulinmode`"/>
</property>
</subclass>
<class name="glucose.impl.IntensiveCareUnitImpl" entity-name="IntensiveCareUnit" abstract="false" lazy="false" discriminator-value="IntensiveCareUnit" table="`intensivecareunit`">
<meta attribute="eclassName" inherit="false">IntensiveCareUnit</meta>
</id>
<column name="`dtype`" index="intensivecareunitdtype" length="255" not-null="true"/>
</discriminator>
</version>
<list name="patients" lazy="true" cascade="all,delete-orphan">
<key foreign-key="intensivecareunit_patients_key" update="true">
<column name="`intensivecareunit_patients_e_id`" unique="false"/>
</key>
<list-index column="`intensivecareunit_patients_idx`"/>
<one-to-many entity-name="Patient"/>
</list>
<list name="users" lazy="true" cascade="all,delete-orphan">
<key foreign-key="intensivecareunit_users_key" update="true">
<column name="`intensivecareunit_users_e_id`" unique="false"/>
</key>
<list-index column="`intensivecareunit_users_idx`"/>
<one-to-many entity-name="User"/>
</list>
</class>
</hibernate-mapping>
Exception in thread "main" org.hibernate.id.IdentifierGenerationException: ids for this class must be manually assigned before calling save(): Person
at org.hibernate.id.Assigned.generate(Assigned.java:52)
at org.hibernate.event.internal.AbstractSaveEventListener.saveWithGeneratedId(AbstractSaveEventListener.java:118)
at org.hibernate.event.internal.DefaultSaveOrUpdateEventListener.saveWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener.java:204)
at org.hibernate.event.internal.DefaultSaveOrUpdateEventListener.entityIsTransient(DefaultSaveOrUpdateEventListener.java:189)
at org.hibernate.event.internal.DefaultSaveOrUpdateEventListener.performSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:114)
at org.hibernate.event.internal.DefaultSaveOrUpdateEventListener.onSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:90)
at org.hibernate.internal.SessionImpl.fireSaveOrUpdate(SessionImpl.java:641)
at org.hibernate.internal.SessionImpl.saveOrUpdate(SessionImpl.java:633)
at org.hibernate.engine.spi.CascadingAction$5.cascade(CascadingAction.java:259)
at org.hibernate.engine.internal.Cascade.cascadeToOne(Cascade.java:380)
at org.hibernate.engine.internal.Cascade.cascadeAssociation(Cascade.java:323)
at org.hibernate.engine.internal.Cascade.cascadeProperty(Cascade.java:208)
at org.hibernate.engine.internal.Cascade.cascadeCollectionElements(Cascade.java:409)
at org.hibernate.engine.internal.Cascade.cascadeCollection(Cascade.java:350)
at org.hibernate.engine.internal.Cascade.cascadeAssociation(Cascade.java:326)
at org.hibernate.engine.internal.Cascade.cascade(Cascade.java:165)
at org.hibernate.event.internal.AbstractFlushingEventListener.cascadeOnFlush(AbstractFlushingEventListener.java:160)
at org.hibernate.event.internal.AbstractFlushingEventListener.prepareEntityFlushes(AbstractFlushingEventListener.java:151)
at org.hibernate.event.internal.AbstractFlushingEventListener.flushEverythingToExecutions(AbstractFlushingEventListener.java:88)
at org.hibernate.event.internal.DefaultFlushEventListener.onFlush(DefaultFlushEventListener.java:51)
at org.hibernate.internal.SessionImpl.flush(SessionImpl.java:1127)
at org.hibernate.internal.SessionImpl.managedFlush(SessionImpl.java:325)
at org.hibernate.engine.transaction.internal.jdbc.JdbcTransaction.beforeTransactionCommit(JdbcTransaction.java:101)
at org.hibernate.engine.transaction.spi.AbstractTransactionImpl.commit(AbstractTransactionImpl.java:175)
at examples.QuickStart.doQuickStart(QuickStart.java:155)
at examples.QuickStart.main(QuickStart.java:56)/**
* <copyright>
* Copyright (c) 2010 Springsite BV (The Netherlands) and others
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Martin Taal
* </copyright>
* $Id: QuickStart.java,v 1.7 2010/11/11 10:28:15 mtaal Exp $
* Adapted by J. Michael Dean for gluose insulin model 2013/03/27
package examples;
import glucose.AccessType;
import glucose.CarbohydrateStatusType;
import glucose.GlucoseDecision;
import glucose.GlucoseFactory;
import glucose.GlucosePackage;
import glucose.IntensiveCareUnit;
import glucose.Patient;
import glucose.StatusType;
import glucose.User;
import java.util.Calendar;
import java.util.Properties;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.teneo.PersistenceOptions;
import org.eclipse.emf.teneo.hibernate.HbDataStore;
import org.eclipse.emf.teneo.hibernate.HbHelper;
import org.hibernate.Session;
import org.hibernate.SessionFactory;
import org.hibernate.Transaction;
import org.hibernate.cfg.Environment;
* Quick Start Tutorial for the <a href="http://wiki.eclipse.org/Teneo">Teneo</a> project.
* @author <a href="mailto:mtaal@xxxxxxxx">Martin Taal</a>
* @version $Revision: 1.7 $
public class QuickStart {
/** The main method */
// the name of the database, this database should exist but does not
// need to contain tables
String dbName = "glucose";
doQuickStart(dbName); // ignore return
* The method performing the real action. This method is used by other tutorials therefore has it
* been made public and expects the database name and returns an instance of the HbDataStore.
public static HbDataStore doQuickStart(String dbName) {
// The hibernate properties can be set by having a hibernate.properties
// file in the root of
// the classpath.
// Another approach is setting the properties in the HbDataStore.
// For more information see section 3.1 of the Hibernate manual
final Properties props = new Properties();
props.setProperty(Environment.DRIVER, "com.mysql.jdbc.Driver");
props.setProperty(Environment.USER, "root");
props.setProperty(Environment.URL, "jdbc:mysql://127.0.0.1:3306/" +
dbName);
props.setProperty(Environment.PASS, "root");
props.setProperty(Environment.DIALECT,
org.hibernate.dialect.MySQL5InnoDBDialect.class.getName());
// props.setProperty(Environment.DRIVER, "org.hsqldb.jdbcDriver");
// props.setProperty(Environment.USER, "sa");
// props.setProperty(Environment.URL, "jdbc:hsqldb:mem:library");
// props.setProperty(Environment.PASS, "");
// props.setProperty(Environment.DIALECT, org.hibernate.dialect.HSQLDialect.class.getName());
// set a specific option
// see this page
// http://wiki.eclipse.org/Teneo/Hibernate/Configuration_Options
// for all the available options
props
.setProperty(PersistenceOptions.CASCADE_POLICY_ON_NON_CONTAINMENT, "REFRESH,PERSIST,MERGE");
// the name of the session factory
String hbName = "Glucose";
// create the HbDataStore using the name
final HbDataStore hbds = HbHelper.INSTANCE.createRegisterDataStore(hbName);
// set the properties
hbds.setDataStoreProperties(props);
// sets its epackages stored in this datastore
hbds.setEPackages(new EPackage[] { GlucosePackage.eINSTANCE });
// initialize, also creates the database tables
try {
hbds.initialize();
} finally {
// print the generated mapping
System.err.println(hbds.getMappingXML());
SessionFactory sessionFactory = hbds.getSessionFactory();
// Create a session and a transaction
Transaction tx = session.getTransaction();
// Start a transaction, create a library and make it persistent
tx.begin();
IntensiveCareUnit picu = GlucoseFactory.eINSTANCE.createIntensiveCareUnit();
session.save(picu);
// create a user
User user = GlucoseFactory.eINSTANCE.createUser();
user.setAccountName("mdean");
user.setAccountRights(AccessType.NORMAL);
user.setFirstName("Michael");
user.setLastName("Dean");
//picu.getUsers().add(user);
//session.save(user);
Patient patient = GlucoseFactory.eINSTANCE.createPatient();
//patient.setBirthdate(new GregorianCalendar());
patient.setBirthdate(Calendar.getInstance());
patient.setCreatedBy(user);
patient.setFirstName("Sally Jo");
patient.setLastName("Zuspan");
patient.setHeight(150.);
patient.setWeight(57.6);
patient.setMedRecNum("12-34-56");
patient.setStatus(StatusType.CURRENT);
patient.setStudyID("CHOM0003");
//session.save(patient);
GlucoseDecision decision = GlucoseFactory.eINSTANCE.createGlucoseDecision();
decision.setCreatedBy(user);
decision.setCarbohydrateStatus(CarbohydrateStatusType.UNCHANGED);
// add the user and patient to the intensive care unit
picu.getPatients().add(patient);
// at commit the objects will be present in the database
tx.commit();
// and close of, this should actually be done in a finally block
session.close();
return hbds;
Re: [Teneo] - Howto copy EMF model from one database to another one [message #1039201 is a reply to message #1039120] |
Thu, 11 April 2013 22:32 |
Hi Mike,
Ok, np, I will try to spend some time on this over the weekend..
gr. Martin
>> Hi Mike,
>> ecore:
>> gr. Martin
>>> following snippets:
>>> @MappedSuperclass
>>> strategy = "uuid")
>>> private String id;
>>> this.valid = true;
>>> @Id
>>> return id;
>>> @Entity
>>> strategy = "uuid")
>>> etc.
>>> model itself.
>>> - Mike
> Thanks for your response. I think I have annotated things correctly, but the generated classes do not have annotations
> in the implementation files, and the interface files don't seem right. I am undoubtedly doing something ridiculous. When
> the code is generated and I exercise it with an adaptation of your Quickstart.java tutorial application, the hibernate
> mapping file is generated but does not indicate anything about a uuid generator, etc. I also receive an exception that
> ids for this class must be manually assigned before calling save() - this error occurs when the hibernate session is
> committed.
> My model is actually simple, so I am attaching it to this post, hoping you might see something obviously wrong. The
> only place I have an ID is in the Person class that is at the top; I have indicated the annotation source as teneo.jpa,
> and called the key "body" and the value the text of the annotation. I have also attached the console output and the
> I understand if you do not have time to open the model, but again if you get a chance, I appreciate your help!
> - Mike
The Netherlands
Current Time: Fri Apr 26 09:14:00 GMT 2024
Powered by FUDForum. Page generated in 0.05169 seconds
