Home » Archived » AMW » weaving model(how to create a weaving model with matching automatically)
weaving model [message #1018880] Thu, 14 March 2013 12:02 Go to next message
I want to generate automatically a weaving model with matchings between given metamodels.
I create a weaving model and i use the context menu : metamodel match (name equality for example) it generate an empty file
Can someone help me
Re: weaving model [message #1021269 is a reply to message #1018880] Tue, 19 March 2013 15:19 Go to previous messageGo to next message
you need to execute the matching transformations according to the dependencies between them.
You can find a description in the AMW wiki.
Marcos
Re: weaving model [message #1021621 is a reply to message #1021269] Wed, 20 March 2013 08:07 Go to previous messageGo to next message
Thanks for ur answer
Im trying to execute matching transformations in this order :
Cartesian product, Name equality, Propagation, Similarity flooding, Threshold then Link rewriting
but when i arrive at the third step (generation of propagation graph) i get an empty model (DiagramToDiagram2_cp_equal_prop.amw)
plz can u tell me what the problem may be
[Updated on: Wed, 20 March 2013 09:38] by Moderator
Re: weaving model [message #1022387 is a reply to message #1021621] Thu, 21 March 2013 15:26 Go to previous messageGo to next message
Can you check the execution log of Eclipse?
This can help you to discover the problem.
Marcos.
Re: weaving model [message #1022391 is a reply to message #1022387] Thu, 21 March 2013 15:31 Go to previous messageGo to next message
Btw, you need to have a couple of weaving extensions installed (mmw_match and mmw_propagation).
The extensions are explained in the following link.
http://www.eclipse.org/gmt/amw/usecases/matching/matching_exec.php
Marcos.
Re: weaving model [message #1022706 is a reply to message #1022391] Fri, 22 March 2013 07:40 Go to previous messageGo to next message
Hi !
I get no messages in the execution log of eclipse when i launch a matching transformation. but the model takes too long to load when i click on.
I load, in the first wizard, (just for instance) the couple of weaving extensions : mmw_match and mmw_propagation in order to create a cartesian product.
In the second, i choose the panel (TransformationWeavingPanelExtension) and the WModel (MatchModel).
then, i choose the left and right metamodels. (to simplify, i created a slight change between the two metamodels)
i execute the cartesian product transformation, i get a model with an empty method cartesian product and other links all with sim = 0. when i try to click on, there is an error in execution log with the following messages :
at org.eclipse.gmt.weaver.editors.weaving.GenericWeavingPanel.setWLinkEndSelection(GenericWeavingPanel.java:366)
at org.eclipse.gmt.weaver.editors.weaving.GenericWeavingPanel.setViewersSelection(GenericWeavingPanel.java:244)
at org.eclipse.gmt.weaver.editors.weaving.GenericWeavingPanel.wSelectionChanged(GenericWeavingPanel.java:224)
at org.eclipse.gmt.weaver.editors.weaving.GenericWeavingPanel$2.selectionChanged(GenericWeavingPanel.java:155)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:160)
at org.eclipse.gmt.weaver.editors.weaving.SelectionTreeViewer.updateSelection(SelectionTreeViewer.java:50)
at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1138)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1168)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:227)
at org.eclipse.jface.util.OpenStrategy.access$3(OpenStrategy.java:221)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:388)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2200)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:490)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
can u tell me what does it mean ?
i also have this line in the metadata file :
<model-relative-path>null</model-relative-path>
does this have any relation with the problem ?
thank you for ur help
Re: weaving model [message #1042621 is a reply to message #1022706] Tue, 16 April 2013 13:07 Go to previous messageGo to next message
You are weaving metamodels, right? In this case, the .metadata file has a 'null' value for the models relative path. So this is not an issue.
About the error, it seems taht there is some unresolved references in your metamodel. This may be connected to the way the model elements are identified: either by XMI-IDs or by XPointer.
Marcos.
Re: weaving model [message #1058253 is a reply to message #1042621] Mon, 13 May 2013 07:12 Go to previous message
Hello!
i used an other version of eclipse. Now, AMW works good.
Thanks a lot for your help
Previous Topic:How to create atl file from amw
Next Topic:Validating links
Current Time: Mon Oct 27 18:11:09 EDT 2025
Powered by FUDForum. Page generated in 0.05279 seconds
