Re: EMF.edit icons in extra plug-in [message #1018862 is a reply to message #1018770] |
Thu, 14 March 2013 15:28 |
Ed Merks Messages: 33141 Registered: July 2009 |
Matthias,
So this other plugin isn't one you depend on, it's just one that might
be installed...
Perhaps you can just specialize the
XyzEditPlugin.Implementation.getImage to do that optional delegation
step to this other. Looking at
org.eclipse.emf.common.EMFPlugin.InternalHelper.getImage(String) will
help understand how the framework converts these keys into URLs...
On 14/03/2013 1:47 PM, Matthias N wrote:
> I have an EMF project and generate .model and .edit plug-in.
> In ItemProvider the generated icon is used:
> public Object getImage(Object object) {
> return
> overlayImage(object,getResourceLocator().getImage("full/obj16/MYICON"));
> I want to add some additional logic: - check in another plug-in called
> "my-icons" "full/obj16" if MYICON exists, if so use it.
> - if it does not exist, use the generated one
> However I don't know how to access the "my-icons" plug-in from the
> ItemProvider. Any suggestions?
Ed Merks
FUDForum. Page generated in 0.02897 seconds
