Home » Modeling » EMF » EMF.edit icons in extra plug-in
EMF.edit icons in extra plug-in [message #1018770] Thu, 14 March 2013 08:47 Go to next message
I have an EMF project and generate .model and .edit plug-in.
In ItemProvider the generated icon is used:
public Object getImage(Object object) {
 return overlayImage(object,getResourceLocator().getImage("full/obj16/MYICON"));
I want to add some additional logic:
- check in another plug-in called "my-icons" "full/obj16" if MYICON exists, if so use it.
- if it does not exist, use the generated one
However I don't know how to access the "my-icons" plug-in from the ItemProvider. Any suggestions?
Re: EMF.edit icons in extra plug-in [message #1018862 is a reply to message #1018770] Thu, 14 March 2013 11:28 Go to previous message
Matthias,
So this other plugin isn't one you depend on, it's just one that might
be installed...
Perhaps you can just specialize the
XyzEditPlugin.Implementation.getImage to do that optional delegation
step to this other. Looking at
org.eclipse.emf.common.EMFPlugin.InternalHelper.getImage(String) will
help understand how the framework converts these keys into URLs...
On 14/03/2013 1:47 PM, Matthias N wrote:
> return
> I want to add some additional logic: - check in another plug-in called
Previous Topic:[CDO] Possible bug in CDORepositorySynchronizer?
Next Topic:NO_MODIFICATION_ALLOWED_ERR error when building GWT app
Current Time: Fri Nov 07 10:13:28 EST 2025
Powered by FUDForum. Page generated in 0.02848 seconds
