RenderTask - Failed to load class "org.eclipse.emf.oda.ecore.impl.ResultSet$JavaObject" [message #1018157] |
Wed, 13 March 2013 09:30  |
I'm trying to use separated Run and Render task to generate a report, in an Eclipse RCP application.
Our reports where previously generated with a RunAndRenderTask, created with the method createRunAndRenderTask of the Engine. This was working well.
Now that we try to use separated Run and Render tasks, we have this error during the rendering execution :
Table (id = 894):
+ A report document error occurred when loading: Result Data.
Failed to load class "org.eclipse.emf.oda.ecore.impl.ResultSet$JavaObject" for "null" type column "EMF-TestCasesInProject::@self". please make sure class "org.eclipse.emf.oda.ecore.impl.ResultSet$JavaObject" is included in BIRT engines class loading path.
org.eclipse.emf.oda.ecore.impl.ResultSet$JavaObject (Element ID:894)
data.engine.LoadReportDocumentError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: A report document error occurred when loading: Result Data.
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1237)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1216)
at org.eclipse.birt.report.engine.internal.document.v4.ReportItemExecutor.executeQuery(ReportItemExecutor.java:429)
at org.eclipse.birt.report.engine.internal.document.v4.TableItemExecutor.doExecute(TableItemExecutor.java:72)
at org.eclipse.birt.report.engine.internal.document.v4.ReportItemExecutor.execute(ReportItemExecutor.java:294)
at org.eclipse.birt.report.engine.internal.document.v4.ContainerExecutor.prepareChildExecutor(ContainerExecutor.java:226)
at org.eclipse.birt.report.engine.internal.document.v4.ContainerExecutor.hasNextChild(ContainerExecutor.java:110)
at org.eclipse.birt.report.engine.internal.document.v4.ReportPageExecutorV4.hasNextChild(ReportPageExecutorV4.java:110)
at org.eclipse.birt.report.engine.internal.document.ReportExecutorWrapper.hasNextChild(ReportExecutorWrapper.java:110)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportExecutor.hasNextChild(WrappedReportExecutor.java:75)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM$1.hasNextChild(HTMLPageLM.java:68)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:62)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRangeRender.render(RenderTask.java:641)
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:294)
at (...)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:173)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:388)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1029)
at (...)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at (...)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at (...)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: org.eclipse.birt.data.engine.core.DataException: A report document error occurred when loading: Result Data.
at org.eclipse.birt.data.engine.impl.document.viewing.DataSetResultSet.next(DataSetResultSet.java:191)
at org.eclipse.birt.data.engine.impl.document.util.ExprDataReader1.next(ExprDataReader1.java:201)
at org.eclipse.birt.data.engine.impl.document.util.ExprResultSet.next(ExprResultSet.java:177)
at org.eclipse.birt.data.engine.impl.document.ResultIterator.next(ResultIterator.java:167)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.next(QueryResultSet.java:191)
at org.eclipse.birt.report.engine.internal.document.v4.ReportItemExecutor.executeQuery(ReportItemExecutor.java:424)
... 72 more
Caused by: org.eclipse.birt.data.engine.core.DataException: Failed to load class "org.eclipse.emf.oda.ecore.impl.ResultSet$JavaObject" for "null" type column "EMF-TestCasesInProject::@self". please make sure class "org.eclipse.emf.oda.ecore.impl.ResultSet$JavaObject" is included in BIRT engines class loading path.
at org.eclipse.birt.data.engine.executor.cache.ResultSetUtil.readResultObject(ResultSetUtil.java:184)
at org.eclipse.birt.data.engine.impl.document.viewing.DataSetResultSet.next(DataSetResultSet.java:178)
... 77 more
Caused by: java.io.IOException: org.eclipse.emf.oda.ecore.impl.ResultSet$JavaObject
at org.eclipse.birt.core.util.IOUtil.readObject(IOUtil.java:637)
at org.eclipse.birt.data.engine.executor.cache.ResultSetUtil.readResultObject(ResultSetUtil.java:173)
... 78 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.emf.oda.ecore.impl.ResultSet$JavaObject
at org.eclipse.birt.core.framework.URLClassLoader.findClass1(URLClassLoader.java:188)
at org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClassLoader.java:156)
at org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClassLoader.java:1)
at org.eclipse.birt.core.framework.URLClassLoader.findClass(URLClassLoader.java:151)
at org.eclipse.birt.report.engine.executor.ApplicationClassLoader.loadClass(ApplicationClassLoader.java:79)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at org.eclipse.birt.core.util.IOUtil$1.resolveClass(IOUtil.java:627)
at java.io.ObjectInputStream.readNonProxyDesc(Unknown Source)
at java.io.ObjectInputStream.readClassDesc(Unknown Source)
at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.io.ObjectInputStream.readObject0(Unknown Source)
at java.io.ObjectInputStream.readObject(Unknown Source)
at org.eclipse.birt.core.util.IOUtil.readObject(IOUtil.java:633)
... 79 more
Indeed, the data source that we use is created with the ECore ODA Driver, but I don't understand why it should work with a single RunAndRenderTask, and not with seperated Run and Render...
I have found this post about this problem, but to be honnest I don't find the solution :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=375995
Thanks for you help
ALL4TEC
Re: RenderTask - Failed to load class "org.eclipse.emf.oda.ecore.impl.ResultSet$JavaObject" [message #1018165 is a reply to message #1018157] |
Wed, 13 March 2013 09:45   |
After some debugging, it seems that when I use a RunAndRender task, it don't create a rptDocument. With the separated tasks, the Run create a file rptDocument containing all the needed data for the rendering operation.
Then, during the render, this file is analysed to create the final report. And the error that I have occured during the parsing of this rptDocument, as it try to deserialize an object org.eclipse.emf.oda.ecore.impl.ResultSet$JavaObject but it don't find the corresponding class. In the stack trace, it's when this is called by ResultSetUtil :
IOUtil.readObject(dis, DataEngineSession.getCurrentClassLoader( ) );
The question is .... how can I configure my projet or my engine to have the needed class in its class path ?
ALL4TEC
FUDForum. Page generated in 0.02016 seconds
