Home » Newcomers » Newcomers » cannot run jar file
icon5.gif  cannot run jar file [message #1017548] Mon, 11 March 2013 23:47 Go to next message
good day,
i created a simple game program. It runs without problems in eclipse. I created a runnable jar file by:
1 right click java folder
2 click export
3 select "Runnable JAR file" [next]
4 [my export destination is my desktop]
5 [library handling: extract required libraries...]
when i double click the jar file, it says "A Java Exception has occurred", so i tried to open it to cmd and it says: "Error: Unable to access jarfile rpsBETA.jar"
rpsBETA.jar is the name of my jarfile. i reinstalled my java and still show the same error.. my version of java is the java 7 update 17 [prolly the latest since i downloaded it yesterday]
most solution i searched said is to reinstall/update my java...so what should i do now??
Re: cannot run jar file [message #1021052 is a reply to message #1017548] Tue, 19 March 2013 08:46 Go to previous messageGo to next message
From what I'm aware the issue is with the way Eclipse executes and creates runnable .JAR files, but then again I could be wrong.
Try another runnable JAR compilation program, as I know there are many out there which may be able to help you (providing you set it up correctly).
Re: cannot run jar file [message #1021156 is a reply to message #1021052] Tue, 19 March 2013 11:28 Go to previous messageGo to next message
Joe Norman wrote on Tue, 19 March 2013 08:46
hi,
can you provide some references or something that will help me? thanks
oh btw
my setup is similar to how i saw it in youtube, provided by sir thenewboston's java game development tutorial
Re: cannot run jar file [message #1021186 is a reply to message #1017548] Tue, 19 March 2013 12:08 Go to previous message
On 3/12/2013 7:21 AM, Ronnel Aldrin Capati wrote:
> good day,
> 2 click export
> should i do now??
I've never had any trouble creating JARs, runnable or not, in Eclipse,
though I admit I do it more often using ant because my code is used in
continuous deployment (via Jenkins) more and more.
http://www.javahotchocolate.com/tutorials/jars-and-wars.html
Previous Topic:Project Needs Guidance
Next Topic:turning off "content assist" or "completion"
Current Time: Tue Sep 09 22:44:17 EDT 2025
Powered by FUDForum. Page generated in 0.07282 seconds
