Home » Modeling » GMF (Graphical Modeling Framework) » GMF vs MegaEdit+
GMF vs MegaEdit+ [message #1017278] Mon, 11 March 2013 09:12 Go to next message
Hi all,
I'm currently working on a research project and i must compare GMF vs MetaEdit+
I have already search some comparison beetween them. And just found MegaEdit+ better
than GMF for Industry. Can't find objective comparison. They all glorify MetaEdit+
So i want to ask u, what kind of differences exists between this 2, what is the The
strengths of the GMF(topics: Graphical, Operations, Constraints).
Serhat GEZGİN
Re: GMF vs MegaEdit+ [message #1017296 is a reply to message #1017278] Mon, 11 March 2013 10:20 Go to previous messageGo to next message
GMF is free and Open-source and benefits from Eclipse Community.
I think you should consider Obeo designer, which is based on GMF, to compare to MegaEdit+.
Re: GMF vs MegaEdit+ [message #1017297 is a reply to message #1017278] Mon, 11 March 2013 10:20 Go to previous messageGo to next message
Re: GMF vs MegaEdit+ [message #1017303 is a reply to message #1017297] Mon, 11 March 2013 10:41 Go to previous messageGo to next message
if i correct, Obeo based on GMF but not free is that clear ? I can found obeo from
eclipse market place how it works dont understand Smile
Re: GMF vs MegaEdit+ [message #1017433 is a reply to message #1017278] Mon, 11 March 2013 16:28 Go to previous messageGo to next message
There's a useful comparison by Eclipse modeling project committers of GMF, Obeo, RSA, GME and MetaEdit+: tinyurl.com/gerard12 . To make the comparison objective rather than just opinions, they implemented the same language in all the tools, giving scores for the results and timing how long it took.
If you're interested in the expressiveness of the metamodeling languages (meta-metamodels), there's also a comparison by Heiko Kern for MetaEdit+ (GOPPRR), GMF (Ecore), ARIS, MS DSL Tools & Visio: www.dsmforum.org/events/DSM11/Papers/kern.pdf
What other comparisons do people know?
All the best,
Steve
[cross-posted from same question under Epsilon]
Re: GMF vs MegaEdit+ [message #1019389 is a reply to message #1017303] Fri, 15 March 2013 11:25 Go to previous message
> eclipse market place how it works dont understand :)
Disclaimer: I am the tech lead of Obeo Designer.
You are right, Obeo Designer is not free, although many of its parts are
(for example Acceleo). It uses GMF Runtime (not the Tooling part) at
least for the graphical diagrams support.
It is a generic tool with which you can create your own modelers for
your Domain Specific Models using a dynamic approach. You describe how
you want your modelers to look and behave in a configuration file (which
is it itself a model) and the tool adapts dynamically.
Have a look at UML Designer [1] (which uses Obeo Designer underneath but
is free), to get an idea of what is possible. Feel free to contact me
privately if you want more details (pierre-charles.david at obeo dot fr).
PS: "Obeo" is the name of the company, "Obeo Designer" the name of the
product.
[1] http://marketplace.obeonetwork.com/module/uml
Previous Topic:GMF Saving issue
Next Topic:Sub Tool Group in Tool Group on Palette
Current Time: Tue Oct 28 03:18:11 EDT 2025
Powered by FUDForum. Page generated in 0.04453 seconds
