Home » Newcomers » Newcomers » Immediate crash at start up on WinXP after latest 4.2.x auto update
Immediate crash at start up on WinXP after latest 4.2.x auto update [message #1016959] Fri, 08 March 2013 06:04 Go to next message
Anyone got any ideas what on earth this log means ?
!ENTRY org.eclipse.equinox.event 2 0 2013-03-08 10:54:14.299
!MESSAGE Found components with duplicated names! Details:
Component1 : Component[
name = org.eclipse.equinox.event
activate = activate
deactivate = deactivate
modified =
configuration-policy = optional
factory = null
autoenable = true
immediate = false
implementation = org.eclipse.equinox.internal.event.EventComponent
state = Unsatisfied
properties =
serviceFactory = false
serviceInterface =
references = null
located in bundle = org.eclipse.equinox.event_1.2.100.v20110502
Component2: Component[
activate = activate
modified =
factory = null
autoenable = true
immediate = false
state = Unsatisfied
properties =
serviceInterface =
references = null
located in bundle = org.eclipse.equinox.event_1.2.200.v20120522-2049
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2013-03-08 10:54:14.330
name = org.eclipse.equinox.p2.transport.ecf
activate = activate
modified =
factory = null
autoenable = true
immediate = false
implementation = org.eclipse.equinox.internal.p2.transport.ecf.ECFTransportComponent
state = Unsatisfied
properties = {p2.agent.servicename=org.eclipse.equinox.internal.p2.repository.Transport}
serviceInterface =
references = null
located in bundle = org.eclipse.equinox.p2.transport.ecf_1.0.100.v20120913-155635
activate = activate
modified =
factory = null
autoenable = true
immediate = false
state = Unsatisfied
serviceInterface =
references = null
located in bundle = org.eclipse.equinox.p2.transport.ecf_1.0.0.v20110510
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-03-08 10:54:26.420
!MESSAGE Unable to create class 'org.eclipse.e4.core.commands.CommandServiceAddon' from bundle '271'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.ClassCastException
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:861)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:113)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:321)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:255)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:185)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:49)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:258)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:557)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.ClassCastException
at java.lang.Class.cast(Class.java:2999)
at org.eclipse.e4.core.internal.contexts.EclipseContext.get(EclipseContext.java:561)
at org.eclipse.e4.core.commands.CommandServiceAddon.init(CommandServiceAddon.java:30)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 27 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-03-08 10:54:26.436
!MESSAGE Unable to create class 'org.eclipse.e4.ui.internal.workbench.addons.CommandProcessingAddon' from bundle '297'
!STACK 0
org.eclipse.e4.core.di.InjectionException: Unable to process "CommandProcessingAddon.commandService": no actual value was found for the argument "ECommandService".
at org.eclipse.e4.core.internal.di.InjectorImpl.reportUnresolvedArgument(InjectorImpl.java:396)
at org.eclipse.e4.core.internal.di.InjectorImpl.resolveRequestorArgs(InjectorImpl.java:387)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:102)
!MESSAGE Unable to create class 'org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon' from bundle '303'
!STACK 0
org.eclipse.e4.core.di.InjectionException: Unable to process "BindingProcessingAddon.commandService": no actual value was found for the argument "ECommandService".
!ENTRY org.eclipse.osgi 2 0 2013-03-08 10:54:26.639
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-03-08 10:54:26.639
!MESSAGE Bundle reference:file:../Program Files/Adobe/Adobe Flash Builder 4.7/eclipse/plugins/org.eclipse.jdt.compiler.apt.nl1_3.7.0.v20110716043402.jar was not resolved.
!SUBENTRY 2 org.eclipse.jdt.compiler.apt.nl1_3.7.0.v20110716043402 2 0 2013-03-08 10:54:26.639
!MESSAGE Missing host org.eclipse.jdt.compiler.apt_ was not resolved.
!SUBENTRY 2 org.eclipse.core.filesystem.win32.x86.nl1_3.7.0.v20110716043402 2 0 2013-03-08 10:54:26.686
!MESSAGE Missing host org.eclipse.core.filesystem.win32.x86_[0.0.0,9.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-03-08 10:54:26.686
!MESSAGE Bundle org.eclipse.core.net.win32.x86.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 was not resolved.
!SUBENTRY 2 org.eclipse.core.net.win32.x86.nl1_3.7.0.v20110716043402 2 0 2013-03-08 10:54:26.686
!MESSAGE Missing host org.eclipse.core.net.win32.x86_[0.0.0,9.0.0).
!MESSAGE Bundle org.eclipse.core.runtime.compatibility.registry_3.5.0.v20110505 was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime.compatibility.registry 2 0 2013-03-08 10:54:26.686
!MESSAGE Missing required capability Require-Capability: osgi.ee; filter="(|(&(osgi.ee=CDC/Foundation)(version=1.0))(&(osgi.ee=JavaSE)(version=1.3)))".
!MESSAGE Bundle org.eclipse.core.runtime.compatibility.registry.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime.compatibility.registry.nl1_3.7.0.v20110716043402 2 0 2013-03-08 10:54:26.686
!MESSAGE Missing host org.eclipse.core.runtime.compatibility.registry_[0.0.0,9.0.0).
!MESSAGE Bundle org.eclipse.ecf.provider.filetransfer.httpclient.ssl_1.0.0.v20110531-2218 was not resolved.
!SUBENTRY 2 org.eclipse.ecf.provider.filetransfer.httpclient.ssl 2 0 2013-03-08 10:54:26.686
!MESSAGE Missing required capability Require-Capability: osgi.ee; filter="(|(&(osgi.ee=CDC/Foundation)(version=1.1))(&(osgi.ee=JavaSE)(version=1.4)))".
!MESSAGE Bundle org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20110531-2218 was not resolved.
!MESSAGE Bundle org.eclipse.ecf.ssl_1.0.100.v20110531-2218 was not resolved.
!MESSAGE Bundle org.eclipse.equinox.http.jetty_2.0.100.v20110502 was not resolved.
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2013-03-08 10:54:26.686
!MESSAGE Package uses conflict: Import-Package: org.mortbay.jetty; version=" was not resolved.
!SUBENTRY 2 org.eclipse.equinox.launcher.win32.win32.x86.nl1_3.7.0.v20110716043402 2 0 2013-03-08 10:54:26.686
!MESSAGE Missing host org.eclipse.equinox.launcher.win32.win32.x86_[0.0.0,9.0.0).
!MESSAGE Bundle org.eclipse.equinox.security.win32.x86.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 was not resolved.
!SUBENTRY 2 org.eclipse.equinox.security.win32.x86.nl1_3.7.0.v20110716043402 2 0 2013-03-08 10:54:26.686
!MESSAGE Missing host org.eclipse.equinox.security.win32.x86_[0.0.0,9.0.0).
!MESSAGE Bundle org.eclipse.jdt.compiler.apt.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 was not resolved.
!SUBENTRY 2 org.eclipse.jdt.compiler.apt.nl1_3.7.0.v20110716043402 2 0 2013-03-08 10:54:26.686
!MESSAGE Missing host org.eclipse.jdt.compiler.apt_[0.0.0,9.0.0).
!MESSAGE Bundle org.eclipse.swt.win32.win32.x86.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 was not resolved.
!SUBENTRY 2 org.eclipse.swt.win32.win32.x86.nl1_3.7.0.v20110716043402 2 0 2013-03-08 10:54:26.686
!MESSAGE Missing host org.eclipse.swt.win32.win32.x86_[0.0.0,9.0.0).
!MESSAGE Bundle org.eclipse.ui.win32_3.2.200.I20100509-0800 was not resolved.
!MESSAGE Bundle org.eclipse.ui.win32.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 was not resolved.
!SUBENTRY 2 org.eclipse.ui.win32.nl1_3.7.0.v20110716043402 2 0 2013-03-08 10:54:26.686
!MESSAGE Missing host org.eclipse.ui.win32_[0.0.0,9.0.0).
!MESSAGE Bundle org.eclipse.ui.workbench.compatibility.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 [712] was not resolved.
!SUBENTRY 2 org.eclipse.ui.workbench.compatibility.nl1_3.7.0.v20110716043402 2 0 2013-03-08 10:54:26.686
!MESSAGE Missing host org.eclipse.ui.workbench.compatibility_[0.0.0,9.0.0).
!ENTRY org.eclipse.osgi 4 0 2013-03-08 10:54:26.686
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.internal.workbench.E4Workbench.processHierarchy(E4Workbench.java:172)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.init(E4Workbench.java:118)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.<init>(E4Workbench.java:69)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:306)
icon9.gif  Re: Immediate crash at start up on WinXP after latest 4.2.x auto update [message #1053606 is a reply to message #1016959] Mon, 06 May 2013 15:02 Go to previous messageGo to next message
I'm getting the same message on Win 7 after trying to upgrade WindowsBuilder...
icon3.gif  Re: Immediate crash at start up on WinXP after latest 4.2.x auto update [message #1053676 is a reply to message #1016959] Tue, 07 May 2013 04:31 Go to previous message
Remove the file in ...eclipse\dropins and it should start. Shut Eclipse down and put the file back.
Worked for me. There's a bug logged with Eclipse here : https://bugs.eclipse.org/bugs/show_bug.cgi?id=391495
Previous Topic:*SOLVED* Yellow confirmation box on ALL shortcuts
Next Topic:BIRTV2.6.2 Installation
Current Time: Thu Nov 06 21:10:57 EST 2025
Powered by FUDForum. Page generated in 0.10103 seconds
