Home » Modeling » M2T (model-to-text transformation) » Papyrus UML to Java using Acceleo
Papyrus UML to Java using Acceleo [message #1016638] Thu, 07 March 2013 03:42 Go to next message
I want to convert the papyrus UML model to java using Acceleo.
I followed the steps at http://wiki.eclipse.org/Acceleo/Getting_Started
, but get this error when i run generate.mtl "An internal error occurred during: "Launching Generate".
Could not find public template generateElement in module generate."
Here is the template file I use. What could be the issue?
[comment encoding = UTF-8 /]
[module generate('http://www.eclipse.org/uml2/4.0.0/UML')/]
[template public generate(aClass : Class)]
[file (aClass.name.concat('.java'), false)]
public class [aClass.name.toUpperFirst()/] {
[for (p: Property | aClass.attribute) separator('\n')]
private [p.type.name/] [p.name/];
[/for]
public [p.type.name/] get[p.name.toUpperFirst()/]() {
return this.[p.name/];
[/for]
[for (o: Operation | aClass.ownedOperation) separator('\n')]
public [o.type.name/] [o.name/]() {
// TODO should be implemented
[/for]
[/file]
[/template]
Re: Papyrus UML to Java using Acceleo [message #1017131 is a reply to message #1016638] Sat, 09 March 2013 12:48 Go to previous messageGo to next message
Hi Roshni,
It seems you forgot to add the @main annotation.
[comment @main /]
Re: Papyrus UML to Java using Acceleo [message #1794552 is a reply to message #1017131] Sun, 02 September 2018 14:46 Go to previous messageGo to next message
André Ribeiro wrote on Sat, 09 March 2013 17:48
Hi Roshni,
[comment @main /]
Thank you so much sir! This is solved my problem! Thank you very much!.
But why this commet is needed ?
[Updated on: Sun, 02 September 2018 14:47] by Moderator
Re: Papyrus UML to Java using Acceleo [message #1794560 is a reply to message #1794552] Mon, 03 September 2018 01:30 Go to previous message
It looks like a design decision. The main template is different. It could have a special name such as Java's "main". it could have a reserved position - first. It could have a non-standard syntax. The designers chose an @main comment. (It might help if there was a warning for no-@main-comment.)
Ed Willink
Previous Topic:Load 2 differents input models an Acceleo template
Next Topic:Papyrus SysML model to text
Current Time: Wed Sep 24 01:02:12 EDT 2025
Powered by FUDForum. Page generated in 0.06336 seconds
