Home » Eclipse Projects » Gemini » Moving from persistence.xml to ConfigurationAdmin
Moving from persistence.xml to ConfigurationAdmin [message #1016269] Tue, 05 March 2013 13:25 Go to next message
I was dealing with this problem: http://www.eclipse.org/forums/index.php/t/457852/
and probably came to a solution. As I described on the other topic, I need to create plug-ins to some clients, and these plug-ins will create new tables on our base. I just created a fragment with these new models, and need to make the 'core' plugin scan this fragment too, and add those classes to the current persitent unit...
I came across Standalone Configuration (http://wiki.eclipse.org/Gemini/JPA/Documentation/OtherTopics#Standalone_Configuration) but I need to know how to make this works with our current code...by now, we have a persitence.xml file, and a EntityManagerHelper class that creates the EMF and the EM too, like this
package br.com.germantech.ecf.infraestrutura.persistencia.entityManager;
import java.util.HashMap;
import java.util.Map;
import javax.persistence.EntityManager;
import javax.persistence.EntityManagerFactory;
import org.apache.log4j.Logger;
import org.eclipse.persistence.config.PersistenceUnitProperties;
import org.eclipse.persistence.config.TargetDatabase;
import org.eclipse.persistence.internal.jpa.EntityManagerImpl;
import org.eclipse.persistence.jpa.PersistenceProvider;
import org.eclipse.persistence.sessions.UnitOfWork;
import org.postgresql.Driver;
import br.com.germantech.ecf.Bootstrap;
import br.com.germantech.ecf.aplicacao.helpers.PropertiesHelper;
public abstract class GermantechEntityManager {
	private static Logger log = Logger.getLogger(GermantechEntityManager.class);
	private static EntityManagerFactory emf = null;
	private static Map<String, Object> properties = new HashMap<String, Object>();
	private static UnitOfWork uow;
	private static final ThreadLocal<EntityManager> ENTITY_MANAGER_CACHE = new ThreadLocal<EntityManager>();
	private synchronized static void init() {
		properties.put(PersistenceUnitProperties.TARGET_DATABASE, TargetDatabase.PostgreSQL);
		properties.put(PersistenceUnitProperties.JDBC_DRIVER, Driver.class.getCanonicalName());
		properties.put(PersistenceUnitProperties.JDBC_URL, PropertiesHelper.getProperty(PropertiesHelper.URL));
		properties.put(PersistenceUnitProperties.JDBC_USER, PropertiesHelper.getProperty(PropertiesHelper.USUARIO));
		properties.put(PersistenceUnitProperties.JDBC_PASSWORD, PropertiesHelper.getProperty(PropertiesHelper.SENHA));
		properties.put(PersistenceUnitProperties.CONNECTION_POOL_MIN, "1");
		properties.put(PersistenceUnitProperties.CONNECTION_POOL_MAX, "10");
		properties.put(PersistenceUnitProperties.CACHE_STATEMENTS, "true");
		properties.put(PersistenceUnitProperties.BATCH_WRITING, "JDBC");
		properties.put(PersistenceUnitProperties.CLASSLOADER, Bootstrap.class.getClassLoader());
		// Cria tabelas novas (mas não atualiza)
		if("true".equalsIgnoreCase(PropertiesHelper.getProperty(PropertiesHelper.GERAR_TABELAS))){
			log.info("Gerando tabelas...");
			properties.put(PersistenceUnitProperties.DDL_GENERATION, PersistenceUnitProperties.CREATE_OR_EXTEND);
		// Cria os arquivos de geração do banco de dados
//		properties.put(PersistenceUnitProperties.CREATE_JDBC_DDL_FILE, "createDDL_ddlGeneration.jdbc");
//		properties.put(PersistenceUnitProperties.DDL_GENERATION_MODE, PersistenceUnitProperties.DDL_BOTH_GENERATION);
		properties.put("eclipselink.logging.level", "FINE");
		properties.put("eclipselink.logging.timestamp", "true");
		properties.put("eclipselink.logging.session", "true");
		properties.put("eclipselink.logging.thread", "true");
		properties.put("eclipselink.logging.exceptions", "true");
		emf = new PersistenceProvider().createEntityManagerFactory("gtech", properties);
	 * Retorna um {@link EntityManager}. Caso não exista, cria um novo
	public synchronized static EntityManager getEntityManager() {
		EntityManager entityManager = ENTITY_MANAGER_CACHE.get();
		if (entityManager == null) {
			log.info("entityManager é null");
			init();
			ENTITY_MANAGER_CACHE.set(entityManager = emf.createEntityManager());
		return entityManager;
any idea is much appreciated
[Updated on: Tue, 05 March 2013 13:29] by Moderator
Re: Moving from persistence.xml to ConfigurationAdmin [message #1019028 is a reply to message #1016269] Thu, 14 March 2013 18:55 Go to previous message
Luiz, after what you learned from the other thread did you still need the config admin feature?
Previous Topic:Installing features in integration tests.
Next Topic:[Gemini-naming] Referecing an Osgi service with filter fails
Current Time: Sun Nov 09 11:22:15 EST 2025
Powered by FUDForum. Page generated in 0.03680 seconds
